Spring Boot AntLib Module
The Spring Boot AntLib module provides basic Spring Boot support for Apache Ant.
You can use the module to create executable jars.
To use the module, you need to declare an additional spring-boot
namespace in your build.xml
, as shown in the following example:
<project xmlns:ivy="antlib:org.apache.ivy.ant"
xmlns:spring-boot="antlib:org.springframework.boot.ant"
name="myapp" default="build">
</project>
You need to remember to start Ant using the -lib
option, as shown in the following example:
$ ant -lib <directory containing spring-boot-antlib-3.4.0.jar>
The “Using Spring Boot” section includes a more complete example of using Apache Ant with spring-boot-antlib .
Spring Boot Ant Tasks
Once the spring-boot-antlib
namespace has been declared, the following additional tasks are available:
Using the “exejar” Task
You can use the exejar
task to create a Spring Boot executable jar.
The following attributes are supported by the task:
Attribute | Description | Required |
The destination jar file to create |
Yes |
The root directory of Java class files |
Yes |
The main application class to run |
No (the default is the first class found that declares a |
The following nested elements can be used with the task:
Element | Description |
One or more Resource Collections describing a set of Resources that should be added to the content of the created jar file. |
One or more Resource Collections that should be added to the set of jar libraries that make up the runtime dependency classpath of the application. |
Examples
This section shows two examples of Ant tasks.
<spring-boot:exejar destfile="target/my-application.jar"
classes="target/classes" start-class="com.example.MyApplication">
<resources>
<fileset dir="src/main/resources" />
</resources>
<lib>
<fileset dir="lib" />
</lib>
</spring-boot:exejar>
<exejar destfile="target/my-application.jar" classes="target/classes">
<lib>
</lib>
</exejar>
Using the “findmainclass” Task
The findmainclass
task is used internally by exejar
to locate a class declaring a main
If necessary, you can also use this task directly in your build.
The following attributes are supported:
Yes (unless |
Can be used to short-circuit the |
No |
The Ant property that should be set with the result |
No (result will be logged if unspecified) |
Examples
This section contains three examples of using findmainclass
<findmainclass classesroot="target/classes" />
<findmainclass classesroot="target/classes" property="main-class" />
<findmainclass mainclass="com.example.MainClass" property="main-class" />
