Installing the CLI
The Spring Boot CLI (Command-Line Interface) can be installed manually by using SDKMAN! (the SDK Manager) or by using Homebrew or MacPorts if you are an OSX user. See Installing the Spring Boot CLI in the “Getting Started” section for comprehensive installation instructions.spring-doc.cn
