Environment (env
The env
endpoint provides information about the application’s Environment
Retrieving the Entire Environment
To retrieve the entire environment, make a GET
request to /actuator/env
, as shown in the following curl-based example:
$ curl 'http://localhost:8080/actuator/env' -i -X GET
The resulting response is similar to the following:
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 78411
"activeProfiles" : [ ],
"defaultProfiles" : [ "default" ],
"propertySources" : [ {
"name" : "servletContextInitParams",
"properties" : { }
"name" : "systemProperties",
"properties" : {
"java.specification.version" : {
"value" : "17"
"java.class.path" : {
"value" : "/home/runner/.gradle/caches/8.11/workerMain/gradle-worker.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator-autoconfigure/build/classes/java/test:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator-autoconfigure/build/resources/test:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator-autoconfigure/build/classes/java/main:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator-autoconfigure/build/resources/main:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-tools/spring-boot-test-support/build/libs/spring-boot-test-support-3.4.0.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-actuator/build/libs/spring-boot-actuator-3.4.0.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-autoconfigure/build/libs/spring-boot-autoconfigure-3.4.0.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot-test/build/libs/spring-boot-test-3.4.0.jar:/home/runner/work/spring-boot/spring-boot/spring-boot-project/spring-boot/build/libs/spring-boot-3.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.dataformat/jackson-dataformat-xml/2.18.1/f85fc7ce244ab3e7de8e6a8f74fca99f7127d378/jackson-dataformat-xml-2.18.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.flywaydb/flyway-core/10.20.1/27c35cad285433947ef986c615ce2742f69145de/flyway-core-10.20.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-wavefront/1.14.1/c53f6283643b7b4225a8d12de5bbfa7099a51110/micrometer-registry-wavefront-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-tracing-reporter-wavefront/1.4.0/13fab21d7d1472c2c248994b56cd0c89d3f2d04e/micrometer-tracing-reporter-wavefront-1.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.wavefront/wavefront-internal-reporter-java/1.7.16/135f9be9f149a6f0614db155ddf51e216d0d2891/wavefront-internal-reporter-java-1.7.16.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.wavefront/wavefront-sdk-java/3.4.3/48a767aa5aa56b56e09c88e8be87de8707cafe77/wavefront-sdk-java-3.4.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.datatype/jackson-datatype-jsr310/2.18.1/36e49c07197395164d50df4b8ed17f5fc05430f0/jackson-datatype-jsr310-2.18.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-cassandra/4.4.0/e186b2ee296a055ab8f23e9772f8656d50cb43e6/spring-data-cassandra-4.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.cassandra/java-driver-query-builder/4.18.1/a771500f0d15729c740c43711f684a605157d5f7/java-driver-query-builder-4.18.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.cassandra/java-driver-core/4.18.1/1b80caa76a9b4f88b5adf866799aaa4a80f378f7/java-driver-core-4.18.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-elasticsearch/5.4.0/8672d8f72a07a4c31f162e6d701a52b94d8ce3dc/spring-data-elasticsearch-5.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.dataformat/jackson-dataformat-toml/2.18.1/33139517e6dd7089c610cb9f4c2100e7cfb9790b/jackson-dataformat-toml-2.18.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.media/jersey-media-json-jackson/3.1.9/3493bbe7cd33624ebcb976e566d41ea5a94947e0/jersey-media-json-jackson-3.1.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.module/jackson-module-jakarta-xmlbind-annotations/2.18.1/87b5c8da837659df2b3bdf1a1fbfb51fe896217e/jackson-module-jakarta-xmlbind-annotations-2.18.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.dataformat/jackson-dataformat-yaml/2.18.1/71bf4432cc97bb989b3d5356a96aa2efdaa26d74/jackson-dataformat-yaml-2.18.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-rest-webmvc/4.4.0/f3694843f29e894bc315c56868080fb89833413c/spring-data-rest-webmvc-4.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-rest-core/4.4.0/98d17b633ff96fd54f06f546a8131721523aee11/spring-data-rest-core-4.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.datatype/jackson-datatype-jdk8/2.18.1/944810b96bfe1d149ecdafb1228537610e14367a/jackson-datatype-jdk8-2.18.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.core/jackson-core/2.18.1/9e2284c539e2dedd2aa1487c781e20a0f575d695/jackson-core-2.18.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.kafka/kafka-streams/3.8.1/9e054a4e7b88bc80f069e22045826013b7b697ec/kafka-streams-3.8.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.core/jackson-annotations/2.18.1/8f9aa97e7fb44d4bea829061625472b0f6199923/jackson-annotations-2.18.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/activemq-broker/6.1.4/9e2f6c9f16b78524551fbc53941706f8ead157f3/activemq-broker-6.1.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-couchbase/5.4.0/474e6cd3de613cf5a18c75e6c69f9bda00ccd225/spring-data-couchbase-5.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.restdocs/spring-restdocs-mockmvc/3.0.3/ac8256fceb81f1022c80b2de1541e4618874d437/spring-restdocs-mockmvc-3.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.restdocs/spring-restdocs-webtestclient/3.0.3/448b2289eebf06828d02d5dfded008c5ec8b33f4/spring-restdocs-webtestclient-3.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.restdocs/spring-restdocs-core/3.0.3/8d3f5bcc661cda01b5d70672a1112ed9e83fbbb9/spring-restdocs-core-3.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.jackson.core/jackson-databind/2.18.1/66547d0c6c2f9e022019499308f09bebbf30ab2e/jackson-databind-2.18.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/ch.qos.logback/logback-classic/1.5.12/3790d1a62e868f7915776dfb392bd9a29ce8d954/logback-classic-1.5.12.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-jakarta-server/2.37.0/b2395f7fdd9f692987d81836c59be11f72312311/artemis-jakarta-server-2.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-server/2.37.0/d830695125020e520303a7d8e91990c2dacf7eac/artemis-server-2.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.ben-manes.caffeine/caffeine/3.1.8/24795585df8afaf70a2cd534786904ea5889c047/caffeine-3.1.8.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.hazelcast/hazelcast-spring/5.5.0/be80826e47712a9f1cf66b9a3f790a6584810fb2/hazelcast-spring-5.5.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.hazelcast/hazelcast/5.5.0/e838d3f54dc1900310b5caff87ff25a5d3ed0d4b/hazelcast-5.5.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.zaxxer/HikariCP/5.1.0/8c96e36c14461fc436bb02b264b96ef3ca5dca8c/HikariCP-5.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.lettuce/lettuce-core/6.4.1.RELEASE/5e4483ac2281c76bd89754ce0192b3663b5cf68/lettuce-core-6.4.1.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.kafka/spring-kafka/3.3.0/fcafcea56825daf58dee1cc6d5449d22d7f839fb/spring-kafka-3.3.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-jakarta9/1.14.1/67da7ae0c8da78a97062f3169e31b3b634c1cd78/micrometer-jakarta9-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-observation-test/1.14.1/6599a3d4f92a444ed2fd940561e7b95dfee425a0/micrometer-observation-test-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-tracing-bridge-brave/1.4.0/57dff2584ad4c98d73dae2024af21d4a18bb977d/micrometer-tracing-bridge-brave-1.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-tracing-bridge-otel/1.4.0/263518b7c81a9fc647943ae2e015eda65e694cb2/micrometer-tracing-bridge-otel-1.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-tracing/1.4.0/3caa5ea2e0ccb9a563929eb78e289e92e08b849/micrometer-tracing-1.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.amqp/spring-rabbit/3.2.0/62455b9040a899ecdc6629e5a7e11c6a3321cb17/spring-rabbit-3.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.batch/spring-batch-core/5.2.0/c4871f7d9f8c32fcf9236d93af0d86d2050816d9/spring-batch-core-5.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.graphql/spring-graphql/1.3.3/6b523a06386935e861e1c64617f07d1f4d768357/spring-graphql-1.3.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-jpa/3.4.0/b4eba91ce346e78f66dcada67fc493b8acaeac69/spring-data-jpa-3.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-mongodb/4.4.0/d9235775ca25760af47900cb250f3087f8ef74c5/spring-data-mongodb-4.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-ldap/3.4.0/c0ad246458f6f3c9cfd5974e1033176b238735a/spring-data-ldap-3.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-webmvc/6.2.0/2eddfeb4d7a12b1ed301bc07abc7e73bca94c2e9/spring-webmvc-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.integration/spring-integration-jmx/6.4.0/b6dfcb13cc0a1262f071a166a9589d484fcc4c2a/spring-integration-jmx-6.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.integration/spring-integration-core/6.4.0/741b72ae0d35108d2d2c93365393eced163499ff/spring-integration-core-6.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-config/6.4.1/99a10c3cf8d9ecf6da3170dd281f2a46cfc0393c/spring-security-config-6.4.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-oauth2-resource-server/6.4.1/d1928e0a9e525dfa8f43f796c231ad3aed6fd231/spring-security-oauth2-resource-server-6.4.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-saml2-service-provider/6.4.1/4eb4598183961d01d74aae6ee21de95bc5b60f29/spring-security-saml2-service-provider-6.4.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-test/6.4.1/4b8c6eaccae67ea51b350e174b8ff330cae5a42b/spring-security-test-6.4.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-web/6.4.1/8dafeff9aa4e87c38b70d78e56388c50953549be/spring-security-web-6.4.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-redis/3.4.0/d59875676ff290082e3432c5035adc6323cdcc73/spring-data-redis-3.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-context-support/6.2.0/dc8c4dcd60296c8d1d2429a839581bf8f457c1ab/spring-context-support-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-keyvalue/3.4.0/aee37bd009436511694e4639964c75f20a522997/spring-data-keyvalue-3.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-oauth2-jose/6.4.1/760b475847757507c471dd1b092cba2268475e30/spring-security-oauth2-jose-6.4.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-oauth2-core/6.4.1/f800d5b830b6dd1e12a72355c3def01a950cdec6/spring-security-oauth2-core-6.4.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-core/6.4.1/237c40a19bd02fa7d09e1b9456d6c603c6777e60/spring-security-core-6.4.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.hateoas/spring-hateoas/2.4.0/a5c3b35a9ef9c3ba835ec36c88692cbe3746d8ca/spring-hateoas-2.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.plugin/spring-plugin-core/3.0.0/d56aa02dd7272dca30aa598dc8b72e823227046a/spring-plugin-core-3.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-context/6.2.0/c08dc2bbbe833de7ceda56e8b8bbcc7014413a2a/spring-context-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-jms/6.2.0/3a384d46c422a123852eacfe462be7b3dbf35f45/spring-jms-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cache2k/cache2k-micrometer/2.6.1.Final/58731da010cc872915e012325027954bdc3122c8/cache2k-micrometer-2.6.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hibernate.orm/hibernate-micrometer/6.6.2.Final/2dd010610d1d0f7f6fcfd299635284d20be8308a/hibernate-micrometer-6.6.2.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-stackdriver/1.14.1/a59b846090eeb5858706d44fb355d9b1c827c0e5/micrometer-registry-stackdriver-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.ext/jersey-micrometer/3.1.9/c4431d1f3eb13a3a701a133de478b731ef85063a/jersey-micrometer-3.1.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-appoptics/1.14.1/da4c7b9407e4db80fa7467ca9d6c8dd3f340bd2/micrometer-registry-appoptics-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-atlas/1.14.1/4ef41e4bad410119274644f985fd9308257be98/micrometer-registry-atlas-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-datadog/1.14.1/605a95d051d04d4237a063ccada49cd749921d04/micrometer-registry-datadog-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-dynatrace/1.14.1/8911f5d93961e2bf3d11ac98618bb9d92dd9a3d6/micrometer-registry-dynatrace-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-elastic/1.14.1/34d77789ce6a410aa41a5fdca2406cc38a533990/micrometer-registry-elastic-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-ganglia/1.14.1/1f4599bc34711010e8ff14ecc7e1b5591069af4b/micrometer-registry-ganglia-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-graphite/1.14.1/18c28fd5a953a6d17bee41667a25bd04c3154288/micrometer-registry-graphite-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-humio/1.14.1/6118ade39d6d512151b6c3d8223634eb249513ae/micrometer-registry-humio-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-influx/1.14.1/a7ccee0b7ff6a72fe2b363b8de9c4305d7281e98/micrometer-registry-influx-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-jmx/1.14.1/2af2e6f737dbb87aa70c63f638f6bb6910ae02dc/micrometer-registry-jmx-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-kairos/1.14.1/95106c92b62e20d9c30dc391e3b9f89f617da7f1/micrometer-registry-kairos-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-new-relic/1.14.1/ca9902e2a8cc7e305a88d1265e8812a08d73ce1b/micrometer-registry-new-relic-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-otlp/1.14.1/4593d2b78bf6db99029c5309ef42b9406e62ab3f/micrometer-registry-otlp-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-prometheus/1.14.1/34c861713df186f2efeb0b4beb213ea5e8a8d36f/micrometer-registry-prometheus-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-prometheus-simpleclient/1.14.1/60e6edb6c170cf6ded98cc9f8cdf8618e759c6e0/micrometer-registry-prometheus-simpleclient-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-signalfx/1.14.1/5ba758bc73cf84738898082c29e2ec4613ea841e/micrometer-registry-signalfx-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-registry-statsd/1.14.1/365dd28414fde0d5dbb18f96e6af81e054b06f8e/micrometer-registry-statsd-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-core/1.14.1/a0a96755baff09a8f87e16e974920b42fbaa9d59/micrometer-core-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-webflux/6.2.0/e94a99e1442f2215599f6977d1d02101e7e8ae87/spring-webflux-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-web/6.2.0/e1b702476fe83b2354baf88b8179f71c53fbbfae/spring-web-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-observation/1.14.1/db326347a09c9c18b4149aae98b38d280cafdeb9/micrometer-observation-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/simpleclient_pushgateway/0.16.0/65935d9855ece6f85c21ad38634703d0917bf88c/simpleclient_pushgateway-0.16.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.reporter2/zipkin-reporter-brave/3.4.2/9d972583ad89aeb1c7ce163dfc711366728e4cec/zipkin-reporter-brave-3.4.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.reporter2/zipkin-sender-urlconnection/3.4.2/2762b8290baf9518677d2472199bc889a2c7a0f7/zipkin-sender-urlconnection-3.4.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-zipkin/1.43.0/a7b09f8bb96e3a592e2682b4d25f11429667309e/opentelemetry-exporter-zipkin-1.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-otlp/1.43.0/6049b76571db09b2694ce96a177b2ee1322a4588/opentelemetry-exporter-otlp-1.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor.netty/reactor-netty-http/1.2.0/cc05be22b2e9ee88be29ccc7c8b13aa227572b5c/reactor-netty-http-1.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.r2dbc/r2dbc-pool/1.0.2.RELEASE/c6a07e2e312e9bc8a897759a1004023187451c4f/r2dbc-pool-1.0.2.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.r2dbc/r2dbc-proxy/1.1.5.RELEASE/ca3de357825915774cf2464deeaf470c368c7cd7/r2dbc-proxy-1.1.5.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.r2dbc/r2dbc-h2/1.0.0.RELEASE/b99b52c87e7f32136f58131ad7b7a3e2eb168f75/r2dbc-h2-1.0.0.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.r2dbc/r2dbc-spi/1.0.0.RELEASE/e3d15b2d27fdb8fdb76a181b21d5c752adf1d165/r2dbc-spi-1.0.0.RELEASE.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/activemq-openwire-legacy/6.1.4/2e98d998acdb56a9b500f5e8d0ea25bd3c03f46f/activemq-openwire-legacy-6.1.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/activemq-client/6.1.4/89c19738541bff9fbc8aa6696d9e86fbbeadfcd8/activemq-client-6.1.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-jakarta-service-extensions/2.37.0/434b61cb824db57fcb7c7f41f80472fc8a638a1b/artemis-jakarta-service-extensions-2.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-jakarta-client/2.37.0/313a3342089f9aa925a5d71af015b8cff69b64a2/artemis-jakarta-client-2.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.jms/jakarta.jms-api/3.1.0/e194cf91a3f908e4846542849ac11a8e0b3c68ad/jakarta.jms-api-3.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hibernate.orm/hibernate-core/6.6.2.Final/eb4edddac5d31e47c367dde7d7b53a2a87f364a6/hibernate-core-6.6.2.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.persistence/jakarta.persistence-api/3.1.0/66901fa1c373c6aff65c13791cc11da72060a8d6/jakarta.persistence-api-3.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.undertow/undertow-servlet/2.3.18.Final/d54a5f19d47abc27d11610f8af7dcb9eda000992/undertow-servlet-2.3.18.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty.ee10/jetty-ee10-webapp/12.0.15/3cab18bda612ecc54bca0fd4fe4453df4d53e5ce/jetty-ee10-webapp-12.0.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty.ee10/jetty-ee10-servlet/12.0.15/a9362717fa1756f9f1f18e0ef2ce671e742b7afb/jetty-ee10-servlet-12.0.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.servlet/jakarta.servlet-api/6.0.0/abecc699286e65035ebba9844c03931357a6a963/jakarta.servlet-api-6.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/javax.cache/cache-api/1.1.1/c56fb980eb5208bfee29a9a5b9d951aba076bd91/cache-api-1.1.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-jdbc-store/2.37.0/722d7827e01adf29b3bf60a18134d45cea0b9698/artemis-jdbc-store-2.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-dbcp2/2.12.0/45698ece9fda230d0b1c96282c03ce1ebbd6c3ce/commons-dbcp2-2.12.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.kafka/kafka-clients/3.8.1/fd79e3aa252c6d818334e9c0bac8166b426e498c/kafka-clients-3.8.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.logging.log4j/log4j-to-slf4j/2.24.1/fc8228007ccbf3bcdd9c6045de2c20bd03dbcf6e/log4j-to-slf4j-2.24.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.logging.log4j/log4j-api/2.24.1/7ebeb12c20606373005af4232cd0ecca72613dda/log4j-api-2.24.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat.embed/tomcat-embed-core/10.1.33/d4d10b953164db057e4a803506e4552731e5a6a0/tomcat-embed-core-10.1.33.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat.embed/tomcat-embed-el/10.1.33/6cdf9afcb8577309fae1181e0a5f2f8cff559d97/tomcat-embed-el-10.1.33.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat/tomcat-jdbc/10.1.33/e4692cf04d56eb68cda109aa2c23b568b465f826/tomcat-jdbc-10.1.33.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-aspects/6.2.0/b26611284cc7a5540c7dea3788cf79b1fa872f8b/spring-aspects-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.aspectj/aspectjweaver/1.9.22.1/bca243d0af0db4758fbae45c5f4995cb5dabb612/aspectjweaver-1.9.22.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cache2k/cache2k-spring/2.6.1.Final/cd312efb1645de91bdd8571b98273cb0acf52d15/cache2k-spring-2.6.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.angus/angus-mail/2.0.3/56f811522d693700013768db83b741a65da6c61c/angus-mail-2.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty.http2/jetty-http2-server/12.0.15/268a1e70655478eb288d3ff7956f34065e83c88c/jetty-http2-server-12.0.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-ee/12.0.15/81b836bd4b358b4057efe681528e41ca93634bac/jetty-ee-12.0.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-session/12.0.15/2819021282ff2f7fbaa53feb2fe063130bd4613c/jetty-session-12.0.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-security/12.0.15/e15efd84ed53277f8e893574edaed4734c161f44/jetty-security-12.0.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-server/12.0.15/2bd3742c6831e42c6ebfa9c990386a8dca71dee8/jetty-server-12.0.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/co.elastic.clients/elasticsearch-java/8.15.4/de950724aab02da9877a96b901fdfcc42e67ed15/elasticsearch-java-8.15.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.elasticsearch.client/elasticsearch-rest-client/8.15.4/32fb45ff0e3880f8fdd1eb86fc3a7a31aac709d5/elasticsearch-rest-client-8.15.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.ext/jersey-spring6/3.1.9/e2ee21d8409f3bd0d81c5d93d7fec976e1a5a1ac/jersey-spring6-3.1.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.containers/jersey-container-servlet-core/3.1.9/b3e44d2491adddc8aca8357d672999e944f05199/jersey-container-servlet-core-3.1.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.core/jersey-server/3.1.9/67dd52a347528af973c3215dcf2bc5eba6bbed70/jersey-server-3.1.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hibernate.validator/hibernate-validator/8.0.1.Final/e49e116b3d3928060599b176b3538bb848718e95/hibernate-validator-8.0.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.influxdb/influxdb-java/2.24/638b1ca7c63aa94ce7024fc7bebb1e458a3fb6f6/influxdb-java-2.24.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.jupiter/junit-jupiter/5.11.3/992ed024f7cef51ef8dfb3f6828c2f8917cc9640/junit-jupiter-5.11.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mockito/mockito-junit-jupiter/5.14.2/3cfc377d4bb9fe729f3dd9098d9a9b27da58324a/mockito-junit-jupiter-5.14.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-core-test/6.2.0/3e256b4cf36ff48513accd7d9e313f7754d3ee2/spring-core-test-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.jupiter/junit-jupiter-params/5.11.3/a54ff747e4ad98b1d49ee1e73f502def701516b5/junit-jupiter-params-5.11.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.jupiter/junit-jupiter-engine/5.11.3/78392fae7f493f92618b837610c2915d0528b4fa/junit-jupiter-engine-5.11.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.jupiter/junit-jupiter-api/5.11.3/89b1b4f707e19ed1c594c2d782987a6954226aec/junit-jupiter-api-5.11.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.platform/junit-platform-engine/1.11.3/b2b5f1af958609110c1f4ce055b9050fec77fbda/junit-platform-engine-1.11.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.platform/junit-platform-commons/1.11.3/71eaa12ce1322069c712d1d557a5e95324a8a84c/junit-platform-commons-1.11.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.junit.platform/junit-platform-launcher/1.11.3/a49b9aa3ddd206121b643ba556bc3420129c47d/junit-platform-launcher-1.11.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.liquibase/liquibase-core/4.29.2/bc4d7a9247ee41a1a467aae2fbe69094e354cac5/liquibase-core-4.29.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/mongodb-driver-reactivestreams/5.2.1/eab6074c877b0e3a36984bb8efb89f0ce4c7c314/mongodb-driver-reactivestreams-5.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/mongodb-driver-sync/5.2.1/c837fdf64de3e0211553e1f28ae433ab245fbbc2/mongodb-driver-sync-5.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.neo4j.driver/neo4j-java-driver/5.25.0/387d463fe24ad5d389ae29b993499fdbcb6ad7f2/neo4j-java-driver-5.25.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.quartz-scheduler/quartz/2.3.2/18a6d6b5a40b77bd060b34cb9f2acadc4bae7c8a/quartz-2.3.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-orm/6.2.0/e02bdeb64ee3986d0e8cf0b53dbb4ca89d25f606/spring-orm-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-jdbc/6.2.0/3907c5ca693671d164fbb056e40146a80c1c39ee/spring-jdbc-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-messaging/6.2.0/b76f7778525e40af36e93ade58f202c737d45d34/spring-messaging-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.session/spring-session-core/3.4.0/2a3d7325ba006a1fd6b404271f83835fcd30758d/spring-session-core-3.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/redis.clients/jedis/5.2.0/a3e3905dcc06a48738783883d13f43873df22e31/jedis-5.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor/reactor-test/3.7.0/578c0e0f599e22b7552bbe1b25176d013621a/reactor-test-3.7.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-exposition-formats/1.3.3/da466ac4c78663715ff2494b3ec04d2c815962b8/prometheus-metrics-exposition-formats-1.3.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.okhttp3/mockwebserver/4.12.0/3bc54cc5c87cd632031d0881f3c313d3799a1476/mockwebserver-4.12.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.jayway.jsonpath/json-path/2.9.0/37fe2217f577b0b68b18e62c4d17a8858ecf9b69/json-path-2.9.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.undertow/undertow-core/2.3.18.Final/981cd13a9f0a626c9365a83d7f8ce1e932d5e4de/undertow-core-2.3.18.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-oxm/6.2.0/6e6d69ba286bf9cedb2e469b8b1457c73ccfa61a/spring-oxm-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jaxb/jaxb-runtime/4.0.5/ca84c2a7169b5293e232b9d00d1e4e36d4c3914a/jaxb-runtime-4.0.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jaxb/jaxb-core/4.0.5/7b4b11ea5542eea4ad55e1080b23be436795b3/jaxb-core-4.0.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.xml.bind/jakarta.xml.bind-api/4.0.2/6cd5a999b834b63238005b7144136379dc36cad2/jakarta.xml.bind-api-4.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.aspectj/aspectjrt/1.9.22.1/2b4f27c886fe697fc042f1f67eff7aa6e17e9473/aspectjrt-1.9.22.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.assertj/assertj-core/3.26.3/d26263eb7524252d98e602fc6942996a3195e29/assertj-core-3.26.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.awaitility/awaitility/4.2.2/7336242073ebf83fe034e42b46a403c5501b63c9/awaitility-4.2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cache2k/cache2k-core/2.6.1.Final/7e333caaafa2bf4e489b58537b5c4218a4e6505/cache2k-core-2.6.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cache2k/cache2k-api/2.6.1.Final/6afd23d7897fff56515f0cefa6a846bdebe10bce/cache2k-api-2.6.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hamcrest/hamcrest-library/2.2/cf530c8a0bc993487c64e940ae639bb4a6104dc6/hamcrest-library-2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/junit/junit/4.13.2/8ac9e16d933b6fb43bc7f576336b8f4d7eb5ba12/junit-4.13.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hamcrest/hamcrest-core/2.2/3f2bd07716a31c395e2837254f37f21f0f0ab24b/hamcrest-core-2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hamcrest/hamcrest/2.2/1820c0968dba3a11a1b30669bb1f01978a91dedc/hamcrest-2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hsqldb/hsqldb/2.7.3/85b49338b36f3051d217295596cf92beb92e4bfb/hsqldb-2.7.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mockito/mockito-core/5.14.2/f7bf936008d7664e2002c3faf0c02071c8d10e7c/mockito-core-5.14.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.skyscreamer/jsonassert/1.5.3/aaa43e0823d2a0e106e8754d6a9c4ab24e05e9bc/jsonassert-1.5.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-test/6.2.0/b18c80e3c6c253ba9ba5d4487efa4e951f1d89db/spring-test-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.yaml/snakeyaml/2.3/936b36210e27320f920536f695cf1af210c44586/snakeyaml-2.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.management.j2ee/jakarta.management.j2ee-api/1.1.4/dbbe7575f97efd0b04f3a8455cf82c256c853055/jakarta.management.j2ee-api-1.1.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.transaction/jakarta.transaction-api/2.0.1/51a520e3fae406abb84e2e1148e6746ce3f80a1a/jakarta.transaction-api-2.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-saml-impl/4.0.1/995986fd848ede1443469f3aff1f82b740224262/opensaml-saml-impl-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-saml-api/4.0.1/2205aba935f4da468382a3dc5f32c3821ec1564c/opensaml-saml-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-soap-impl/4.0.1/38bfaf5fc189774e94ead218bd1c754da295c226/opensaml-soap-impl-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-profile-api/4.0.1/bece5f6d30d4051e6eeaf2b88dd1e5a13f6b28b7/opensaml-profile-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-soap-api/4.0.1/d8e11e31cb5164788a530478e1831969e94a38b6/opensaml-soap-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-xmlsec-impl/4.0.1/efa15ba85127ac3b20c75b8d4f04c7e92325a00a/opensaml-xmlsec-impl-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-xmlsec-api/4.0.1/edb4365d3d183933cf0d0b31966ea352b8d20c60/opensaml-xmlsec-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-security-impl/4.0.1/64568e9aa8bd7bcd76983e462f9eb2c3dcacbdce/opensaml-security-impl-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-security-api/4.0.1/f3d33ca18cde2a7c7e3643aeca9f03974be9577d/opensaml-security-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-messaging-api/4.0.1/eb9c9971f6bd2a6681a2a692a1f29a35874de389/opensaml-messaging-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-core/4.0.1/ec3d1734137d6ccabba7d6d5e149f571beeaa673/opensaml-core-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.ldap/spring-ldap-core/3.2.8/6edd7cce57879e1978b9b0b516685c75030f4580/spring-ldap-core-3.2.8.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-tx/6.2.0/940031e305c992e11d52cb3e75fb71f71bf5a19d/spring-tx-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.amqp/spring-amqp/3.2.0/d6ce712490fd3ff8c25a8f2a2fd81033ba1882ad/spring-amqp-3.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.data/spring-data-commons/3.4.0/18db6a4614e253a642b06a38a359b8d56b855be1/spring-data-commons-3.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-aop/6.2.0/999012dfb56640f7babdf4f6c55b3f59c1596f3f/spring-aop-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-beans/6.2.0/972694ca3c2f44d64d55429dfcc6ca2dfa9fddf/spring-beans-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.batch/spring-batch-infrastructure/5.2.0/a384d18caa0ae81473d5456bf744c2fdc77d900/spring-batch-infrastructure-5.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-expression/6.2.0/7e92dcd147157641446081db281e9437d8f4dcd/spring-expression-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-core/6.2.0/b0d65768b9f99204857dc9a5548443c04ba61c79/spring-core-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.vaadin.external.google/android-json/0.0.20131108.vaadin1/fa26d351fe62a6a17f5cda1287c1c6110dec413f/android-json-0.0.20131108.vaadin1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.mchange/c3p0/0.9.5.5/37dfc3021e5589d65ff2ae0becf811510b87ab01/c3p0-0.9.5.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-resolver-provider/3.9.4/d5e38634c1251e000f7718437973a730346bc336/maven-resolver-provider-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-model-builder/3.9.4/b12e45736ddfb51f648e1579877a293659e5a96e/maven-model-builder-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-connector-basic/1.9.14/ffeb368f5587513b29ef9771514ec36d246e65f5/maven-resolver-connector-basic-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-impl/1.9.14/2aa090aca572f7061e5c57f714ef0445bbb4555f/maven-resolver-impl-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-transport-http/1.9.14/1eb4acdce7f21526bd06654b3d7b1edf80370ce8/maven-resolver-transport-http-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-spi/1.9.14/a190c3d49791240c87799f29848505fc9fd8be11/maven-resolver-spi-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-util/1.9.14/ea6fd2997903700191711dee4448746ed30fe4b9/maven-resolver-util-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-api/1.9.14/bd5b7cd9d15c2efcab4d8c8215e769523e8843e4/maven-resolver-api-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/context-propagation/1.1.2/771c187140f7610260020f63d2ac6548d72204d1/context-propagation-1.1.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.core/jersey-client/3.1.9/ebe456a09787bfd731d0bf4dd7e1051b05f2b761/jersey-client-3.1.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.inject/jersey-hk2/3.1.9/34639897202b779b4bcd2a9a5dc41b99b1e46fec/jersey-hk2-3.1.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.core/jersey-common/3.1.9/10b2e59a4e8d942187df102fb80fa21b1da21e36/jersey-common-3.1.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2/3.0.6/12187beb6321e6a7fdc2ef4d196e16c8c58a3a1/hk2-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-core/3.0.6/78dfb2117c3148e357a0cec8f514e60bbf689efd/hk2-core-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-runlevel/3.0.6/3c347e9bb20f13d98b72ae2b4fc84f14bcbb187e/hk2-runlevel-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-locator/3.0.6/92d5c92c9f23bea4b8681c6f8d6ba3d708619f81/hk2-locator-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-api/3.0.6/5a5152dea2c43384f5c07985eb27140134074ecb/hk2-api-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/hk2-utils/3.0.6/b3187d0673c0fd52de197e52c62545c34d4eda29/hk2-utils-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.inject/jakarta.inject-api/2.0.1/4c28afe1991a941d7702fe1362c365f0a8641d1e/jakarta.inject-api-2.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opensaml/opensaml-storage-api/4.0.1/4e46a7f965ac9f91976b0f298fd4d4e69e9056db/opensaml-storage-api-4.0.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.shibboleth.utilities/java-support/8.0.0/298f946e93922d789b6231599a446cea9dbbe80e/java-support-8.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.santuario/xmlsec/2.1.4/cb43326f02e3e77526c24269c8b5d3cc3f7f6653/xmlsec-2.1.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.cloud/google-cloud-monitoring/3.54.0/62d79caf8c62132cb883652449365237a25c9a71/google-cloud-monitoring-3.54.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.auth/google-auth-library-oauth2-http/1.29.0/2a42aead6cdc5d2cd22cdda1b9d7922e6135240f/google-auth-library-oauth2-http-1.29.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.http-client/google-http-client-gson/1.45.0/98af6041ca1d4654a2210cf1c6c06a9401ac6c90/google-http-client-gson-1.45.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.http-client/google-http-client/1.45.0/63eb7643e01797d6aa67c75ae31ffcc6c365db18/google-http-client-1.45.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.httpcomponents/httpclient/4.5.14/1194890e6f56ec29177673f2f12d0b8e627dec98/httpclient-4.5.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/commons-codec/commons-codec/1.17.1/973638b7149d333563584137ebf13a691bb60579/commons-codec-1.17.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opencensus/opencensus-contrib-http-util/0.31.1/3c13fc5715231fadb16a9b74a44d9d59c460cfa8/opencensus-contrib-http-util-0.31.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.guava/guava/33.3.1-jre/852f8b363da0111e819460021ca693cacca3e8db/guava-33.3.1-jre.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api.grpc/proto-google-cloud-monitoring-v3/3.54.0/67b27f202d3f2e06492a4776b7f8eccb56f6fbf0/proto-google-cloud-monitoring-v3-3.54.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.code.findbugs/jsr305/3.0.2/25ea2e8b0c338a877313bd4672d3fe056ea78f0d/jsr305-3.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.dropwizard.metrics/metrics-graphite/4.2.28/ccd58fde40720a5695fbecfa344ba22ef35536cf/metrics-graphite-4.2.28.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.dropwizard.metrics/metrics-jmx/4.2.28/1b72fe2feec99de4c7c82ae35d80b037a249eef5/metrics-jmx-4.2.28.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.dropwizard.metrics/metrics-core/4.2.28/4b66ce1c97c2ad0160e19235e2c899ba20b0f54a/metrics-core-4.2.28.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.velocity/velocity-engine-core/2.2/68d899cb70cd27d495562fa808feb2da4926d38f/velocity-engine-core-2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven.resolver/maven-resolver-named-locks/1.9.14/71cf74d91b4f6de1bff8fc1fafb401d9ac42b1b8/maven-resolver-named-locks-1.9.14.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.zaxxer/HikariCP-java7/2.4.13/3e441eddedb374d4de8e3abbb0c90997f51cc97b/HikariCP-java7-2.4.13.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-core-client/2.37.0/fa0e8aac1d0db695995c2616120345c2bcd77326/artemis-core-client-2.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-selector/2.37.0/4ece0fb9fbdd4df8bb643478d7c0d8a6051a8b9b/artemis-selector-2.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-journal/2.37.0/9083858a5fd032a8993a736752ab31a2c497698a/artemis-journal-2.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-lockmanager-api/2.37.0/f236a517f9b9a4550b97325ea854484998ead4a7/artemis-lockmanager-api-2.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/artemis-commons/2.37.0/f504f11c93d3f9614f042f72ef6fe4999b4f278c/artemis-commons-2.37.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-xml/12.0.15/39541ff8d256f505ca5b3c790f83e959a8f24439/jetty-xml-12.0.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty.http2/jetty-http2-common/12.0.15/324e4d4e51f312070d6e92392901fca57006b79d/jetty-http2-common-12.0.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty.http2/jetty-http2-hpack/12.0.15/6f6671128cbb70eb12c6cfb26047f70995d9c0ab/jetty-http2-hpack-12.0.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-http/12.0.15/a36fcfde8316b374102c5b43d7247ec501e906d8/jetty-http-12.0.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-io/12.0.15/e1657f842a0e362171a8a41f35d85cdba1a47872/jetty-io-12.0.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.netflix.spectator/spectator-reg-atlas/1.8.2/ed080fb9ca90dd1e2f5b8dd01c07156108af4dfc/spectator-reg-atlas-1.8.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.rabbitmq/amqp-client/5.22.0/d5bf5f55022e14c7bc889fd8750b21cb60db064a/amqp-client-5.22.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.graphql-java/graphql-java/22.3/d61a6f4abd6feb50d5ac9ff3c16eb72df72351bb/graphql-java-22.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.graphql-java/java-dataloader/3.3.0/1786c5efbf871395a32cbce1a2114d6788ac4f53/java-dataloader-3.3.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.jetty/jetty-util/12.0.15/9fbd3ac58607af034ad065b366798798bb5f7b5e/jetty-util-12.0.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.netflix.spectator/spectator-ext-ipc/1.8.2/26531dd6ba21f02bc3bfb475549241b3951bc092/spectator-ext-ipc-1.8.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.netflix.spectator/spectator-api/1.8.2/aa6993a7a1556c096ea111fd04bc8724f3c3bcd3/spectator-api-1.8.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.couchbase.client/java-client/3.7.5/2f2c25fa521237b4fc2d052a23f1f45b2634aa19/java-client-3.7.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.couchbase.client/core-io/3.7.5/e80d12f307e1f6c7fe98b4c740337f8c5eb14a95/core-io-3.7.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.slf4j/slf4j-api/2.0.16/172931663a09a1fa515567af5fbef00897d3c04/slf4j-api-2.0.16.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.httpcomponents/httpcore/4.4.16/51cf043c87253c9f58b539c9f7e44c8894223850/httpcore-4.4.16.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.okhttp3/logging-interceptor/4.12.0/e922c1f14d365c0f2bed140cc0825e18462c2778/logging-interceptor-4.12.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.reporter2/zipkin-sender-okhttp3/3.4.2/f447dcc8709713f63404f711781f697cd7ae21f8/zipkin-sender-okhttp3-3.4.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-sender-okhttp/1.43.0/c583b782dc2e8e631d590f1734bf0767769d8507/opentelemetry-exporter-sender-okhttp-1.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.retrofit2/converter-moshi/2.9.0/db0979801926e6d39bc2478736145f9761c3e034/converter-moshi-2.9.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.retrofit2/retrofit/2.9.0/d8fdfbd5da952141a665a403348b74538efc05ff/retrofit-2.9.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.okhttp3/okhttp/4.12.0/2f4525d4a200e97e1b87449c2cd9bd2e25b7e8cd/okhttp-4.12.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.bytebuddy/byte-buddy/1.15.10/635c873fadd853c084f84fdc3cbd58c5dd8537f9/byte-buddy-1.15.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.bytebuddy/byte-buddy-agent/1.15.10/e8eb255b2c378b9a6c7341e7b0e12f0a5636377/byte-buddy-agent-1.15.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml/classmate/1.7.0/e98374da1f2143ac8e6e0a95036994bb19137a3/classmate-1.7.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.opencsv/opencsv/5.9/284ea0b60a24b71a530100783185e7d547ab5339/opencsv-5.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-configuration2/2.11.0/af5a2c6abe587074c0be1107fcb27fa2fad91304/commons-configuration2-2.11.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-text/1.12.0/66aa90dc099701c4d3b14bd256c328f592ccf0d6/commons-text-1.12.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-artifact/3.9.4/9738999a0459221e758ebe728449c43567d7fecc/maven-artifact-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-lang3/3.17.0/b17d2136f0460dcc0d2016ceefca8723bdf4ee70/commons-lang3-3.17.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-pool2/2.12.0/458563f69fbdaebf7daadfe10dc3a22e42a7de50/commons-pool2-2.12.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.code.gson/gson/2.11.0/527175ca6d81050b53bdd4c457a6d6e017626b0e/gson-2.11.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.h2database/h2/2.3.232/4fcc05d966ccdb2812ae8b9a718f69226c0cf4e2/h2-2.3.232.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.httpcomponents/httpasyncclient/4.1.5/cd18227f1eb8e9a263286c1d7362ceb24f6f9b32/httpasyncclient-4.1.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.httpcomponents/httpcore-nio/4.4.16/cd21c80a9956be48c4c1cfd2f594ba02857d0927/httpcore-nio-4.4.16.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.angus/angus-activation/2.0.2/41f1e0ddd157c856926ed149ab837d110955a9fc/angus-activation-2.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.mail/jakarta.mail-api/2.1.3/a327aa5f514ba86e80d54584417d7376ed2bde0e/jakarta.mail-api-2.1.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.activation/jakarta.activation-api/2.1.3/fa165bd70cda600368eee31555222776a46b881f/jakarta.activation-api-2.1.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.annotation/jakarta.annotation-api/2.1.1/48b9bda22b091b1f48b13af03fe36db3be6e1ae3/jakarta.annotation-api-2.1.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.parsson/parsson/1.0.5/f68020271ff70f79412f70ca45973703b6e907c/parsson-1.0.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.json/jakarta.json-api/2.1.3/4febd83e1d9d1561d078af460ecd19532383735c/jakarta.json-api-2.1.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.validation/jakarta.validation-api/3.0.2/92b6631659ba35ca09e44874d3eb936edfeee532/jakarta.validation-api-3.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jersey.ext/jersey-entity-filtering/3.1.9/20c6e17ff1e0c5e29199b18b25f393e7c6eb514d/jersey-entity-filtering-3.1.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/jakarta.ws.rs/jakarta.ws.rs-api/3.1.0/15ce10d249a38865b58fc39521f10f29ab0e3363/jakarta.ws.rs-api-3.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jboss.xnio/xnio-nio/3.8.16.Final/9aab17706a371a212fd051b09c7959d29d051379/xnio-nio-3.8.16.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jboss.xnio/xnio-api/3.8.16.Final/7c98c649a4583523c23cc0a7e62ddace1f486b54/xnio-api-3.8.16.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.wildfly.client/wildfly-client-config/1.0.1.Final/2a803b23c40a0de0f03a90d1fd3755747bc05f4b/wildfly-client-config-1.0.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jboss.threads/jboss-threads/3.5.0.Final/dd23d4788b3eafe9597ef3fe028e46ceb293ba8d/jboss-threads-3.5.0.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jboss.logging/jboss-logging/3.6.1.Final/886afbb445b4016a37c8960a7aef6ebd769ce7e5/jboss-logging-3.6.1.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.minidev/json-smart/2.5.1/4c11d2808d009132dfbbf947ebf37de6bf266c8e/json-smart-2.5.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/ch.qos.logback/logback-core/1.5.12/65b1fa25fe8d8e4bdc140e79eb67ac6741f775e2/logback-core-1.5.12.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/mongodb-driver-core/5.2.1/34aa1e29cdab75c2fd912a6b853319d6936515c6/mongodb-driver-core-5.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/bson-record-codec/5.2.1/47a9b8ef55b63b6a66e1fd69bcf62a6f547468c8/bson-record-codec-5.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.mongodb/bson/5.2.1/a45b5955870d5c9325531a2fef5fbef1329b7e8a/bson-5.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor.addons/reactor-pool/1.1.0/6380e909c09fef1169970d701e06b12ffe38103b/reactor-pool-1.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor.netty/reactor-netty-core/1.2.0/ae640e8b88f2beeaf752411dbf3b09008cfe8dd4/reactor-netty-core-1.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.projectreactor/reactor-core/3.7.0/e98fd1c48144d43f48141b9ebd6723da3b88fb77/reactor-core-3.7.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.reactivestreams/reactive-streams/1.0.4/3864a1320d97d7b045f729a326e1e077661f31b7/reactive-streams-1.0.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.retry/spring-retry/2.0.10/2990d2957ef0988dd243d06e04d357eace43a522/spring-retry-2.0.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat/tomcat-annotations-api/10.1.33/26781124f2fa2e8b277e1ae214660fc3774a7daf/tomcat-annotations-api-10.1.33.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-model/3.9.4/5b79d873cf6d13b3fc4020eac04e2a62ebbfa0aa/maven-model-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-repository-metadata/3.9.4/ef368d45a2caa54634de221540994ca2d810c4c9/maven-repository-metadata-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.codehaus.plexus/plexus-utils/3.5.1/c6bfb17c97ecc8863e88778ea301be742c62b06d/plexus-utils-3.5.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.guava/failureaccess/1.0.2/c4a06a64e650562f30b7bf9aaec1bfed43aca12b/failureaccess-1.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.guava/listenablefuture/9999.0-empty-to-avoid-conflict-with-guava/b421526c5f297295adef1c886e5246c39d4ac629/listenablefuture-9999.0-empty-to-avoid-conflict-with-guava.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.checkerframework/checker-qual/3.47.0/2b3cbe34a6af46bb3692aac208caa4f55cd28584/checker-qual-3.47.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.errorprone/error_prone_annotations/2.35.1/c36f9e12192226278c2b163bf61990b131e59903/error_prone_annotations-2.35.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.j2objc/j2objc-annotations/3.0.0/7399e65dd7e9ff3404f4535b2f017093bdb134c7/j2objc-annotations-3.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.cryptacular/cryptacular/1.2.4/4994c015d87886212683245d13e87f6fb903a760/cryptacular-1.2.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.bouncycastle/bcpkix-jdk15on/1.64/3dac163e20110817d850d17e0444852a6d7d0bd7/bcpkix-jdk15on-1.64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.bouncycastle/bcprov-jdk15on/1.64/1467dac1b787b5ad2a18201c0c281df69882259e/bcprov-jdk15on-1.64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.fasterxml.woodstox/woodstox-core/7.0.0/beb19c02e7e28a8a4acf4a9cc8c3280ec3b94722/woodstox-core-7.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jetbrains.kotlin/kotlin-stdlib-jdk7/1.9.25/1c166692314a2639e5edfed0d23ed7eee4a5c7a5/kotlin-stdlib-jdk7-1.9.25.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.okio/okio-jvm/3.6.0/5600569133b7bdefe1daf9ec7f4abeb6d13e1786/okio-jvm-3.6.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jetbrains.kotlin/kotlin-stdlib/1.9.25/f700a2f2b8f0d6d0fde48f56d894dc722fb029d7/kotlin-stdlib-1.9.25.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jetbrains.kotlin/kotlin-stdlib-jdk8/1.9.25/20d44e880a284f7b5cd99dd69450b403073f49b2/kotlin-stdlib-jdk8-1.9.25.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.reporter2/zipkin-reporter/3.4.2/8be3231724bc6f24a6bf5e0466b5c7b563c29cd9/zipkin-reporter-3.4.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.zipkin2/zipkin/2.27.1/74b5227ae2fe515217107fd228707e4d960ec3ec/zipkin-2.27.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.aws/brave-propagation-aws/1.2.5/828490df0b6be58b6de4d3dd3b3a395fb8243f45/brave-propagation-aws-1.2.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.brave/brave-context-slf4j/6.0.3/a863730f5af570514b4fa4b920c8455c9556d9cd/brave-context-slf4j-6.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.brave/brave-instrumentation-http/6.0.3/bc58655bd14d2f8e8975c5951fecab202e1a1e5/brave-instrumentation-http-6.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.brave/brave/6.0.3/2d626aaf5162463edefcc88291799d5ea9204630/brave-6.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.datastax.oss/native-protocol/1.5.1/97e812373a5fe7667384e7ad67819d2c71878bf8/native-protocol-1.5.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.datastax.oss/java-driver-shaded-guava/25.1-jre-graal-sub-1/522771d14d6b7dba67056a39db33f205ffbed6a4/java-driver-shaded-guava-25.1-jre-graal-sub-1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.jaxb/txw2/4.0.5/f36a4ef12120a9bb06d766d6a0e54b144fd7ed98/txw2-4.0.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.sun.istack/istack-commons-runtime/4.1.2/18ec117c85f3ba0ac65409136afa8e42bc74e739/istack-commons-runtime-4.1.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.micrometer/micrometer-commons/1.14.1/b7cf441e6c9de70794b09086751a8ec0e311d47e/micrometer-commons-1.14.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec-http2/4.1.115.Final/bc474c27c96e3a309da73160fbcfe0bd3aa85bc/netty-codec-http2-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-handler-proxy/4.1.115.Final/5f61f44704a09b373167f1c0b1854bdcd880a8cb/netty-handler-proxy-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec-http/4.1.115.Final/80f0dece29a2c0269217e8dd1b6db6ff9710781f/netty-codec-http-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-resolver-dns-native-macos/4.1.115.Final/f26e44e39a65570d01ca52f7eab17a9983a1b91d/netty-resolver-dns-native-macos-4.1.115.Final-osx-x86_64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-resolver-dns-classes-macos/4.1.115.Final/70dcbd4a64caa48a3149d0b166c5f5367a2ca2f8/netty-resolver-dns-classes-macos-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-resolver-dns/4.1.115.Final/33b0636c6fe36c7f41d9da204aa1ad94ff244ac7/netty-resolver-dns-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-handler/4.1.115.Final/d54dbf68b9d88a98240107758c6b63da5e46e23a/netty-handler-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-native-epoll/4.1.115.Final/a6cc58c4a259bad159cbb06120cea9b3474e86a0/netty-transport-native-epoll-4.1.115.Final-linux-x86_64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-classes-epoll/4.1.115.Final/11fea00408ecbd8b8d1f0698d708e37db4a01841/netty-transport-classes-epoll-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-native-kqueue/4.1.115.Final/b2c2de9435b3c7f9bbf09cfa44cf62cb000dde72/netty-transport-native-kqueue-4.1.115.Final-osx-x86_64.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-classes-kqueue/4.1.115.Final/e912effa0f6e58525a72a57727051d8c2e31b56d/netty-transport-classes-kqueue-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport-native-unix-common/4.1.115.Final/dc96c67d06cd6b5eb677f2728f27bf2e3d9a7284/netty-transport-native-unix-common-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec-socks/4.1.115.Final/955faadc8f5b1ca41881398043b62ce1a245800c/netty-codec-socks-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec-dns/4.1.115.Final/d39b9866939cbbb8ae3a1af5c1df5ddf93656d47/netty-codec-dns-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-codec/4.1.115.Final/d326bf3a4c785b272da3db6941779a1bd5448378/netty-codec-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-transport/4.1.115.Final/39cef77c1a25908ac1abf4960c2e789f0bf70ff9/netty-transport-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-buffer/4.1.115.Final/d5daf1030e5c36d198caf7562da2441a97ec0df6/netty-buffer-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-resolver/4.1.115.Final/e33b4d476c03975957f5d8d0319d592bf2bc5e96/netty-resolver-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-common/4.1.115.Final/9da10a9f72e3f87e181d91b525174007a6fc4f11/netty-common-4.1.115.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.netty/netty-tcnative-classes/2.0.69.Final/f018f36b688bafabe4573af230a8b59cf3c0713/netty-tcnative-classes-2.0.69.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-otlp-common/1.43.0/230fc6ddbd76fedea346ce7dff5d4fa2d13f7f4a/opentelemetry-exporter-otlp-common-1.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-exporter-common/1.43.0/7ce251b8a5eae17b744faaaced857f4a3e79aeb6/opentelemetry-exporter-common-1.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-extension-autoconfigure-spi/1.43.0/ef96761d2234ab0973aea432d74ddb6cf4589ca/opentelemetry-sdk-extension-autoconfigure-spi-1.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk/1.43.0/5e4e695beb5400c1866dcf800f08ca8307405b3b/opentelemetry-sdk-1.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-trace/1.43.0/69619c6433ebf0fe5196f7c3fe18bd543279b451/opentelemetry-sdk-trace-1.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-metrics/1.43.0/ca508a02ef7bb96678d054de264fcc0bf41e729c/opentelemetry-sdk-metrics-1.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-logs/1.43.0/e613c8ecf1efc1a275c7fe744773035df954c291/opentelemetry-sdk-logs-1.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-sdk-common/1.43.0/8f2bb94d9d9fe070de698b973c1f1f247a166dcf/opentelemetry-sdk-common-1.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-extension-trace-propagators/1.43.0/70b813daf4b298a950fd0652305912cf1275c0dc/opentelemetry-extension-trace-propagators-1.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry.instrumentation/opentelemetry-instrumentation-api-incubator/2.9.0-alpha/e9cd5f29fec417794432a80afa8f9e7ef42ca813/opentelemetry-instrumentation-api-incubator-2.9.0-alpha.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry.instrumentation/opentelemetry-instrumentation-api/2.9.0/d5d9208c35e53bca234a7badee709976464614c8/opentelemetry-instrumentation-api-2.9.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-api-incubator/1.43.0-alpha/2dcee00ad7552d9190857e271f6066e655c6c719/opentelemetry-api-incubator-1.43.0-alpha.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-api/1.43.0/ce6889e709baac891833dc1c718702661650b3b3/opentelemetry-api-1.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry/opentelemetry-context/1.43.0/473c7a67d2d587f7faefe7b6d9c00743e82819ee/opentelemetry-context-1.43.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-core/1.3.3/e8d20d61aa23f0207edfc603686cfb7217007ed4/prometheus-metrics-core-1.3.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-config/1.3.3/39cc3406e1f7149e50bb2eed86d17a10aad69620/prometheus-metrics-config-1.3.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-model/1.3.3/dc7965de784eebabeb66f5f5043075797d19616/prometheus-metrics-model-1.3.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/prometheus-metrics-tracer-common/1.3.3/85c94f2973d0c727f5fbfa28be51885a3330d2e0/prometheus-metrics-tracer-common-1.3.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/simpleclient_common/0.16.0/a09a8c790a20309b942a9fdbfe77da22407096e6/simpleclient_common-0.16.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/simpleclient/0.16.0/28b0eaf7c500c506976da8d0fc9cad6c278e8d87/simpleclient-0.16.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/simpleclient_tracer_otel/0.16.0/cc3d2b7b7cb6f077e3b1ee1d3e99eb54fddfa151/simpleclient_tracer_otel-0.16.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/simpleclient_tracer_otel_agent/0.16.0/9d724771e339ff7ec6cd7c0cc170d3470904c5/simpleclient_tracer_otel_agent-0.16.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.prometheus/simpleclient_tracer_common/0.16.0/dec00ef7c6155c4ca1109ec8248f7ff58d8f6cd3/simpleclient_tracer_common-0.16.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework/spring-jcl/6.2.0/2b8e7bb1e751bf585e7db6de1d375c599e0c8cf5/spring-jcl-6.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.springframework.security/spring-security-crypto/6.4.1/f5a3c34ffb1ff2650724f25586326cd78778eacc/spring-security-crypto-6.4.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.typesafe/config/1.4.1/19058a07624a87f90d129af7cd9c68bee94535a9/config-1.4.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-posix/3.1.15/f7d6737adcbd5925d625b8f99166de2cbf13caac/jnr-posix-3.1.15.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hdrhistogram/HdrHistogram/2.2.2/7959933ebcc0f05b2eaa5af0a0c8689fa257b15c/HdrHistogram-2.2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.hibernate.common/hibernate-commons-annotations/7.0.3.Final/e183c4be8bb41d12e9f19b374e00c34a0a85f439/hibernate-commons-annotations-7.0.3.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.smallrye/jandex/3.2.0/f17ad860f62a08487b9edabde608f8ac55c62fa7/jandex-3.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.antlr/antlr4-runtime/4.13.0/5a02e48521624faaf5ff4d99afc88b01686af655/antlr4-runtime-4.13.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.msgpack/msgpack-core/0.9.6/d829f746a66769787e5d7ecab47ba0e4477050e2/msgpack-core-0.9.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.json/json/20240303/ebb88e8fb5122b7506d5cf1d69f1ccdb790d22a/json-20240303.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.luben/zstd-jni/1.5.6-4/ba9e303e0b5e94cdd0017390d7d8c06f47fd61f7/zstd-jni-1.5.6-4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.lz4/lz4-java/1.8.0/4b986a99445e49ea5fbf5d149c4b63f6ed6c6780/lz4-java-1.8.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.xerial.snappy/snappy-java/1.1.10.5/ac605269f3598506196e469f1fb0d7ed5c55059e/snappy-java-1.1.10.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.rocksdb/rocksdbjni/7.9.2/6409b667493149191b09fe1fce94bada6096a3e9/rocksdbjni-7.9.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/commons-io/commons-io/2.16.1/377d592e740dc77124e0901291dbfaa6810a200e/commons-io-2.16.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.commons/commons-collections4/4.4/62ebe7544cb7164d87e0637a2a6a2bdc981395e8/commons-collections4-4.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.mchange/mchange-commons-java/0.2.19/7a4bee38ea02bd7dee776869b19fb3f6861d6acf/mchange-commons-java-0.2.19.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.tomcat/tomcat-juli/10.1.33/116c37561ba783c00e7c6b40a5e61d70c2327e7f/tomcat-juli-10.1.33.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.codehaus.plexus/plexus-interpolation/1.26/25b919c664b79795ccde0ede5cee0fd68b544197/plexus-interpolation-1.26.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.maven/maven-builder-support/3.9.4/671110e56110d5c89eda904f198719a2b5fa4a21/maven-builder-support-3.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.eclipse.sisu/org.eclipse.sisu.inject/0.3.5/d4265dd4f0f1d7a06d80df5a5f475d5ff9c17140/org.eclipse.sisu.inject-0.3.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.codehaus.woodstox/stax2-api/4.2.2/b0d746cadea928e5264f2ea294ea9a1bf815bbde/stax2-api-4.2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.fusesource.hawtbuf/hawtbuf/1.11/8f0e50ad8bea37b84b698ec40cce09e47714a63e/hawtbuf-1.11.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/spring-bridge/3.0.6/e7047f31108550310f1ed9c2814caea58d875ccc/spring-bridge-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.dynatrace.metric.util/dynatrace-metric-utils-java/2.2.1/a25d8db688874b00aef7539d3bcefda603024c60/dynatrace-metric-utils-java-2.2.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/info.ganglia.gmetric4j/gmetric4j/1.0.10/3d62003123b586adb86cb028cc0f8a8c3a701d81/gmetric4j-1.0.10.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry.proto/opentelemetry-proto/1.3.2-alpha/6b1ebd548f788bdc3c3acd5e5df6902ee7694944/opentelemetry-proto-1.3.2-alpha.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.signalfx.public/signalfx-java/1.0.47/31749f3b5da4cc77aa9cee446e5a6a23de9c7c9f/signalfx-java-1.0.47.jar:/home/runner/.gradle/caches/modules-2/files-2.1/aopalliance/aopalliance/1.0/235ba8b489512805ac13a8f9ea77a1ca5ebe3e8/aopalliance-1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.zipkin.contrib.brave-propagation-w3c/brave-propagation-tracecontext/0.2.0/bdc26787eb3bf99e7172b53df4e170e9a067b44/brave-propagation-tracecontext-0.2.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opentelemetry.semconv/opentelemetry-semconv/1.25.0-alpha/76b3d4ca0a8f20b27c1590ceece54f0c7fb5857e/opentelemetry-semconv-1.25.0-alpha.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.objenesis/objenesis/3.3/1049c09f1de4331e8193e579448d0916d75b7631/objenesis-3.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.thoughtworks.qdox/qdox/2.1.0/64dd4d16364d1eaecba9f6c4c0d6dbcef8e8160/qdox-2.1.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.nimbusds/nimbus-jose-jwt/9.37.3/700f71ffefd60c16bd8ce711a956967ea9071cec/nimbus-jose-jwt-9.37.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.latencyutils/LatencyUtils/2.0.3/769c0b82cb2421c8256300e907298a9410a2a3d3/LatencyUtils-2.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-ffi/2.2.11/bcf004ce358c87fc4cd2853b658d336348d0370f/jnr-ffi-2.2.11.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-constants/0.10.3/af19ec7359dd72cbc7869c00bf7cdfa4c308e985/jnr-constants-0.10.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.squareup.moshi/moshi/1.8.0/752e7b187599d3ccb174d00ba7235e29add736be/moshi-1.8.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.opencensus/opencensus-api/0.31.1/66a60c7201c2b8b20ce495f0295b32bb0ccbbc57/opencensus-api-0.31.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-context/1.67.1/7dde554dda7efaff5ee7bc2f38783c72be3b996f/grpc-context-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-api/1.67.1/d897b56d469d366660affffb69c9d58149b93505/grpc-api-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-stub/1.67.1/d035e33a23045b8cffc3e9c96f5f9a0a6ad9d1c5/grpc-stub-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-protobuf/1.67.1/3b8ef38636f9f8ca07d762cd2d2dba247771311e/grpc-protobuf-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-protobuf-lite/1.67.1/55ae1c465f7389f4c91eb238152c4e1482eb21e6/grpc-protobuf-lite-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api/api-common/2.40.0/5e4274c3e865795de36ad117d1b461abbe565e03/api-common-2.40.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.auto.value/auto-value-annotations/1.11.0/f0d047931d07cfbc6fa4079854f181ff62891d6f/auto-value-annotations-1.11.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.protobuf/protobuf-java/3.25.5/5ae5c9ec39930ae9b5a61b32b93288818ec05ec1/protobuf-java-3.25.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api.grpc/proto-google-common-protos/2.48.0/86b550469172d830d174d7434c318d7dff179910/proto-google-common-protos-2.48.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api/gax/2.57.0/e8dbb1f2bf140068246e7a4cc9e2d21904f93eb5/gax-2.57.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.auth/google-auth-library-credentials/1.29.0/19af4907301816d9328c1eb1fcc6dd05c8a0b544/google-auth-library-credentials-1.29.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.api/gax-grpc/2.57.0/89d01e2b1908d291c6671e7edb8791cab473b743/gax-grpc-2.57.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-inprocess/1.67.1/311dfbe3254cb4ec13fe68259f29f0aea2eed4ae/grpc-inprocess-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-core/1.67.1/bc20b275303dfdad7fd2daaf5cca6e4fd91439ae/grpc-core-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.android/annotations/4.1.1.4/a1678ba907bf92691d879fef34e1a187038f9259/annotations-4.1.1.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.codehaus.mojo/animal-sniffer-annotations/1.24/aa9ba58d30e0aad7f1808fce9c541ea3760678d8/animal-sniffer-annotations-1.24.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-alts/1.67.1/2f0801d5e1ac4d3627c3ffe4a20828b600399cfc/grpc-alts-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-grpclb/1.67.1/cf8871db2ba0a1f75292579a395c7181818594c8/grpc-grpclb-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.protobuf/protobuf-java-util/3.25.5/38cc5ce479603e36466feda2a9f1dfdb2210ef00/protobuf-java-util-3.25.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.conscrypt/conscrypt-openjdk-uber/2.5.2/d858f142ea189c62771c505a6548d8606ac098fe/conscrypt-openjdk-uber-2.5.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-auth/1.67.1/4a84fbffe3d9bac50751d3efd4a91c00ba1f40ca/grpc-auth-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-netty-shaded/1.67.1/8cc4f36b2a9799126651db9eb8d89183b720ec36/grpc-netty-shaded-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-util/1.67.1/6d0608ab58365deb080980c3c32230be644c3110/grpc-util-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.perfmark/perfmark-api/0.27.0/f86f575a41b091786a4b027cd9c0c1d2e3fc1c01/perfmark-api-0.27.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-googleapis/1.67.1/89b75588084abf669d2c05213381aa0153a1b30e/grpc-googleapis-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-xds/1.67.1/2bb94b8f1c4560b52abe4830b75f692a8da7da09/grpc-xds-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/io.grpc/grpc-services/1.67.1/c5abeec1cc2893e45164ea79ae3b72c85b27f4d6/grpc-services-1.67.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.google.re2j/re2j/1.7/2949632c1b4acce0d7784f28e3152e9cf3c2ec7a/re2j-1.7.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.threeten/threetenbp/1.7.0/8703e893440e550295aa358281db468625bc9a05/threetenbp-1.7.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.wildfly.common/wildfly-common/1.5.4.Final/735ceee5616d5143bac1bc740e444697073c002f/wildfly-common-1.5.4.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/net.minidev/accessors-smart/2.5.1/19b820261eb2e7de7d5bde11d1c06e4501dd7e5f/accessors-smart-2.5.1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jgroups/jgroups/5.3.10.Final/80ea94ab9ffa73f091b10705965a1e894c556f97/jgroups-5.3.10.Final.jar:/home/runner/.gradle/caches/modules-2/files-2.1/de.dentrassi.crypto/pem-keystore/2.4.0/a4ba3c7b740b9dada642e1b219d537bafd8c237c/pem-keystore-2.4.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/commons-beanutils/commons-beanutils/1.9.4/d52b9abcd97f38c81342bb7e7ae1eee9b73cba51/commons-beanutils-1.9.4.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jctools/jctools-core/4.0.5/9ab38ca19877236986db4894ef1400a7ca23db80/jctools-core-4.0.5.jar:/home/runner/.gradle/caches/modules-2/files-2.1/commons-collections/commons-collections/3.2.2/8ad72fe39fa8c91eaaf12aadb21e0c3661fe26d5/commons-collections-3.2.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.apache.activemq/activemq-artemis-native/2.0.0/a1bdd3cea7822f3b90063456b0c9928702076bd1/activemq-artemis-native-2.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/osgi-resource-locator/1.0.3/de3b21279df7e755e38275137539be5e2c80dd58/osgi-resource-locator-1.0.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2/class-model/3.0.6/cdb59ed7b763f2fbee0a5595b2d1bad91d22f27f/class-model-3.0.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.javassist/javassist/3.30.2-GA/284580b5e42dfa1b8267058566435d9e93fae7f7/javassist-3.30.2-GA.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.opentest4j/opentest4j/1.3.0/152ea56b3a72f655d4fd677fc0ef2596c3dd5e6e/opentest4j-1.3.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.jetbrains/annotations/13.0/919f0dfe192fb4e063e7dacadee7f8bb9a2672a9/annotations-13.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.acplt.remotetea/remotetea-oncrpc/1.1.2/705c490ad22ff4627389853439f9decf5ee69be/remotetea-oncrpc-1.1.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.tdunning/t-digest/3.2/2ab94758b0276a8a26102adf8d528cf6d0567b9a/t-digest-3.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.atteo/evo-inflector/1.3/4cf8b5f363c60e63f8b7688ac053590460f2768e/evo-inflector-1.3.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.stephenc.jcip/jcip-annotations/1.0-1/ef31541dd28ae2cefdd17c7ebf352d93e9058c63/jcip-annotations-1.0-1.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jffi/1.3.9/b776ea131fa693af2c943368b52acf94131cbd7/jffi-1.3.9.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jffi/1.3.9/163d683f80c06911f3e770c723d6e399e4c59448/jffi-1.3.9-native.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm-util/9.2/fbc178fc5ba3dab50fd7e8a5317b8b647c8e8946/asm-util-9.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm-commons/9.6/f1a9e5508eff490744144565c47326c8648be309/asm-commons-9.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm-analysis/9.2/7487dd756daf96cab9986e44b9d7bcb796a61c10/asm-analysis-9.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm-tree/9.6/c0cdda9d211e965d2a4448aa3fd86110f2f8c2de/asm-tree-9.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.ow2.asm/asm/9.6/aa205cf0a06dbd8e04ece91c0b37c3f5d567546a/asm-9.6.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-a64asm/1.0.0/a1cb8dbe71b5a6a0288043c3ba3ca64545be165/jnr-a64asm-1.0.0.jar:/home/runner/.gradle/caches/modules-2/files-2.1/com.github.jnr/jnr-x86asm/1.0.2/6936bbd6c5b235665d87bd450f5e13b52d4b48/jnr-x86asm-1.0.2.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.bouncycastle/bcpkix-jdk18on/1.78/dd61bcdb87678451dd42d42e267979bd4b4451a1/bcpkix-jdk18on-1.78.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.bouncycastle/bcutil-jdk18on/1.78/81c1f5e06f206be5dad137d563609dbe66c81d31/bcutil-jdk18on-1.78.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.bouncycastle/bcprov-jdk18on/1.78/619aafb92dc0b4c6cc4cf86c487ca48ee2d67a8e/bcprov-jdk18on-1.78.jar:/home/runner/.gradle/caches/modules-2/files-2.1/org.glassfish.hk2.external/aopalliance-repackaged/3.0.6/e3c3f17b649c97155640616026bd32b1043b3c1d/aopalliance-repackaged-3.0.6.jar"
"java.vm.vendor" : {
"value" : "BellSoft"
"name" : "systemEnvironment",
"properties" : {
"JAVA_HOME" : {
"value" : "/opt/hostedtoolcache/Java_Liberica_jdk/17.0.13-12/x64",
"origin" : "System Environment Property \"JAVA_HOME\""
"name" : "Config resource 'class path resource [application.properties]' via location 'classpath:/'",
"properties" : {
"com.example.cache.max-size" : {
"value" : "1000",
"origin" : "class path resource [application.properties] - 1:29"
"name" : "logCorrelation",
"properties" : { }
"name" : "applicationInfo",
"properties" : { }
Sanitization of sensitive values has been switched off for this example. |
Response Structure
The response contains details of the application’s Environment
The following table describes the structure of the response:
Path | Type | Description |
Names of the active profiles, if any. |
Names of the default profiles, if any. |
Property sources in order of precedence. |
Name of the property source. |
Properties in the property source keyed by property name. |
Value of the property. |
Origin of the property, if any. |
Retrieving a Single Property
To retrieve a single property, make a GET
request to /actuator/env/{property.name}
, as shown in the following curl-based example:
$ curl 'http://localhost:8080/actuator/env/com.example.cache.max-size' -i -X GET
The preceding example retrieves information about the property named com.example.cache.max-size
The resulting response is similar to the following:
HTTP/1.1 200 OK
Content-Disposition: inline;filename=f.txt
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 538
{"property":{"source":"Config resource 'class path resource [application.properties]' via location 'classpath:/'","value":"1000"},"activeProfiles":[],"defaultProfiles":["default"],"propertySources":[{"name":"servletContextInitParams"},{"name":"systemProperties"},{"name":"systemEnvironment"},{"name":"Config resource 'class path resource [application.properties]' via location 'classpath:/'","property":{"value":"1000","origin":"class path resource [application.properties] - 1:29"}},{"name":"logCorrelation"},{"name":"applicationInfo"}]}
Response Structure
The response contains details of the requested property. The following table describes the structure of the response:
Property from the environment, if found. |
Name of the source of the property. |
Property in the property source, if any. |
