Testing Spring Applications
One of the major advantages of dependency injection is that it should make your code easier to unit test. You can instantiate objects by using the new operator without even involving Spring. You can also use mock objects instead of real dependencies.spring-doc.cn
Often, you need to move beyond unit testing and start integration testing (with a Spring ApplicationContext). It is useful to be able to perform integration testing without requiring deployment of your application or needing to connect to other infrastructure.spring-doc.cn
The Spring Framework includes a dedicated test module for such integration testing. You can declare a dependency directly to org.springframework:spring-test or use the spring-boot-starter-test starter to pull it in transitively.spring-doc.cn
If you have not used the spring-test module before, you should start by reading the relevant section of the Spring Framework reference documentation.spring-doc.cn
