Gradle Plugin
The Spring Boot Gradle Plugin provides Spring Boot support in Gradle. It allows you to package executable jar or war archives, run Spring Boot applications, and use the dependency management provided by spring-boot-dependencies. Spring Boot’s Gradle plugin requires Gradle 7.x (7.5 or later) or 8.x and can be used with Gradle’s configuration cache.spring-doc.cn
In addition to this user guide, API documentation is also available.spring-doc.cn
