Internationalization
Spring Boot supports localized messages so that your application can cater to users of different language preferences.
By default, Spring Boot looks for the presence of a messages
resource bundle at the root of the classpath.
The auto-configuration applies when the default properties file for the configured resource bundle is available (messages.properties by default).
If your resource bundle contains only language-specific properties files, you are required to add the default.
If no properties file is found that matches any of the configured base names, there will be no auto-configured MessageSource .
The basename of the resource bundle as well as several other attributes can be configured using the spring.messages
namespace, as shown in the following example:
Properties
YAML
spring.messages.basename=messages, config.i18n.messages
spring.messages.common-messages=classpath:my-common-messages.properties
spring.messages.fallback-to-system-locale=false
spring:
basename: "messages, config.i18n.messages"
common-messages: "classpath:my-common-messages.properties"
fallback-to-system-locale: false
The spring.messages.basename property supports a list of locations, either a package qualifier or a resource resolved from the classpath root.
The spring.messages.common-messages property supports a list of property file resources.
See MessageSourceProperties
for more supported options.
