Web
Spring Boot is well suited for web application development. You can create a self-contained HTTP server by using embedded Tomcat, Jetty, Undertow, or Netty. Most web applications use the spring-boot-starter-web module to get up and running quickly. You can also choose to build reactive web applications by using the spring-boot-starter-webflux module.spring-doc.cn
If you have not yet developed a Spring Boot web application, you can follow the “Hello World!” example in the Getting started section.spring-doc.cn
