Sending Email
The Spring Framework provides an abstraction for sending email by using the JavaMailSender interface, and Spring Boot provides auto-configuration for it as well as a starter module.spring-doc.cn
See the reference documentation for a detailed explanation of how you can use JavaMailSender.
If spring.mail.host and the relevant libraries (as defined by spring-boot-starter-mail) are available, a default JavaMailSender is created if none exists. The sender can be further customized by configuration items from the spring.mail namespace. See MailProperties for more details.spring-doc.cn
In particular, certain default timeout values are infinite, and you may want to change that to avoid having a thread blocked by an unresponsive mail server, as shown in the following example:spring-doc.cn
spring.mail.properties[mail.smtp.connectiontimeout]=5000
spring.mail.properties[mail.smtp.timeout]=3000
spring.mail.properties[mail.smtp.writetimeout]=5000
spring:
  mail:
    properties:
      "[mail.smtp.connectiontimeout]": 5000
      "[mail.smtp.timeout]": 3000
      "[mail.smtp.writetimeout]": 5000
It is also possible to configure a JavaMailSender with an existing Session from JNDI:spring-doc.cn
spring.mail.jndi-name=mail/Session
spring:
  mail:
    jndi-name: "mail/Session"
When a jndi-name is set, it takes precedence over all other Session-related settings.spring-doc.cn
