Using the CLI
Once you have installed the CLI, you can run it by typing spring
and pressing Enter at the command line.
If you run spring
without any arguments, a help screen is displayed, as follows:
$ spring
usage: spring [--help] [--version]
<command> [<args>]
Available commands are:
init [options] [location]
Initialize a new project using Spring Initializr (start.spring.io)
encodepassword [options] <password to encode>
Encode a password for use with Spring Security
shell
Start a nested shell
Common options:
--debug Verbose mode
Print additional status information for the command you are running
See 'spring help <command>' for more information on a specific command.
You can type spring help
to get more details about any of the supported commands, as shown in the following example:
$ spring help init
spring init - Initialize a new project using Spring Initializr (start.spring.io)
usage: spring init [options] [location]
Option Description
-a, --artifact-id <String> Project coordinates; infer archive name (for
example 'test')
-b, --boot-version <String> Spring Boot version (for example '1.2.0.RELEASE')
--build <String> Build system to use (for example 'maven' or
'gradle') (default: maven)
-d, --dependencies <String> Comma-separated list of dependency identifiers to
include in the generated project
--description <String> Project description
-f, --force Force overwrite of existing files
--format <String> Format of the generated content (for example
'build' for a build file, 'project' for a
project archive) (default: project)
-g, --group-id <String> Project coordinates (for example 'org.test')
-j, --java-version <String> Language level (for example '1.8')
-l, --language <String> Programming language (for example 'java')
--list List the capabilities of the service. Use it to
discover the dependencies and the types that are
available
-n, --name <String> Project name; infer application name
-p, --packaging <String> Project packaging (for example 'jar')
--package-name <String> Package name
-t, --type <String> Project type. Not normally needed if you use --
build and/or --format. Check the capabilities of
the service (--list) for more details
--target <String> URL of the service to use (default: https://start.
spring.io)
-v, --version <String> Project version (for example '0.0.1-SNAPSHOT')
-x, --extract Extract the project archive. Inferred if a
location is specified without an extension
examples:
To list all the capabilities of the service:
$ spring init --list
To creates a default project:
$ spring init
To create a web my-app.zip:
$ spring init -d=web my-app.zip
To create a web/data-jpa gradle project unpacked:
$ spring init -d=web,jpa --build=gradle my-dir
The version
command provides a quick way to check which version of Spring Boot you are using, as follows:
$ spring version
Spring CLI v3.4.0
Initialize a New Project
The init
command lets you create a new project by using start.spring.io without leaving the shell, as shown in the following example:
$ spring init --dependencies=web,data-jpa my-project
Using service at https://start.spring.io
Project extracted to '/Users/developer/example/my-project'
The preceding example creates a my-project
directory with a Maven-based project that uses spring-boot-starter-web
and spring-boot-starter-data-jpa
You can list the capabilities of the service by using the --list
flag, as shown in the following example:
Capabilities of https://start.spring.io
Available dependencies:
actuator - Actuator: Production ready features to help you monitor and manage your application
web - Web: Support for full-stack web development, including Tomcat and spring-webmvc
websocket - Websocket: Support for WebSocket development
ws - WS: Support for Spring Web Services
Available project types:
gradle-build - Gradle Config [format:build, build:gradle]
gradle-project - Gradle Project [format:project, build:gradle]
maven-build - Maven POM [format:build, build:maven]
maven-project - Maven Project [format:project, build:maven] (default)
The init
command supports many options.
See the help
output for more details.
For instance, the following command creates a Gradle project that uses Java 17 and war
packaging:
$ spring init --build=gradle --java-version=17 --dependencies=websocket --packaging=war sample-app.zip
Content saved to 'sample-app.zip'
Using the Embedded Shell
Spring Boot includes command-line completion scripts for the BASH and zsh shells.
If you do not use either of these shells (perhaps you are a Windows user), you can use the shell
command to launch an integrated shell, as shown in the following example:
$ spring shell
Spring Boot (v3.4.0)
Hit TAB to complete. Type \'help' and hit RETURN for help, and \'exit' to quit.
From inside the embedded shell, you can run other commands directly:
$ version
Spring CLI v3.4.0
The embedded shell supports ANSI color output as well as tab
completion.
If you need to run a native command, you can use the !
prefix.
To exit the embedded shell, press ctrl-c
