System Requirements
Spring Boot 3.4.0 requires at least Java 17 and is compatible with versions up to and including Java 23. Spring Framework 6.2.0 or above is also required.spring-doc.cn
Explicit build support is provided for the following build tools:spring-doc.cn
Build Tool Version
Mavenspring-doc.cn
3.6.3 or laterspring-doc.cn
Gradlespring-doc.cn
Gradle 7.x (7.6.4 or later) or 8.x (8.4 or later)spring-doc.cn
Servlet Containers
Spring Boot supports the following embedded servlet containers:spring-doc.cn
Name Servlet Version
Tomcat 10.1 (10.1.25 or later)spring-doc.cn
6.0spring-doc.cn
Jetty 12.0spring-doc.cn
6.0spring-doc.cn
Undertow 2.3spring-doc.cn
6.0spring-doc.cn
You can also deploy Spring Boot applications to any servlet 5.0+ compatible container.spring-doc.cn
GraalVM Native Images
Spring Boot applications can be converted into a Native Image using GraalVM 22.3 or above.spring-doc.cn
Images can be created using the native build tools Gradle/Maven plugins or native-image tool provided by GraalVM. You can also create native images using the native-image Paketo buildpack.spring-doc.cn
The following versions are supported:spring-doc.cn
Name Version
GraalVM Communityspring-doc.cn
22.3spring-doc.cn
Native Build Toolsspring-doc.cn
0.10.3spring-doc.cn
