HTTP Clients
Spring Boot offers a number of starters that work with HTTP clients. This section answers questions related to using them.spring-doc.cn
Configure RestTemplate to Use a Proxy
As described in RestTemplate Customization, you can use a RestTemplateCustomizer with RestTemplateBuilder to build a customized RestTemplate. This is the recommended approach for creating a RestTemplate configured to use a proxy.spring-doc.cn
The exact details of the proxy configuration depend on the underlying client request factory that is being used.spring-doc.cn
Configure the TcpClient used by a Reactor Netty-based WebClient
When Reactor Netty is on the classpath a Reactor Netty-based WebClient is auto-configured. To customize the client’s handling of network connections, provide a ClientHttpConnector bean. The following example configures a 60 second connect timeout and adds a ReadTimeoutHandler:spring-doc.cn
import io.netty.channel.ChannelOption;
import io.netty.handler.timeout.ReadTimeoutHandler;
import reactor.netty.http.client.HttpClient;
import org.springframework.http.client.ReactorResourceFactory;
import org.springframework.http.client.reactive.ClientHttpConnector;
import org.springframework.http.client.reactive.ReactorClientHttpConnector;
public class MyReactorNettyClientConfiguration {
	ClientHttpConnector clientHttpConnector(ReactorResourceFactory resourceFactory) {
		HttpClient httpClient = HttpClient.create(resourceFactory.getConnectionProvider())
				.runOn(resourceFactory.getLoopResources())
				.option(ChannelOption.CONNECT_TIMEOUT_MILLIS, 60000)
				.doOnConnected((connection) -> connection.addHandlerLast(new ReadTimeoutHandler(60)));
		return new ReactorClientHttpConnector(httpClient);
	fun clientHttpConnector(resourceFactory: ReactorResourceFactory): ClientHttpConnector {
		val httpClient = HttpClient.create(resourceFactory.connectionProvider)
			.runOn(resourceFactory.loopResources)
			.doOnConnected { connection ->
				connection.addHandlerLast(ReadTimeoutHandler(60))
		return ReactorClientHttpConnector(httpClient)
Note the use of ReactorResourceFactory for the connection provider and event loop resources. This ensures efficient sharing of resources for the server receiving requests and the client making requests.
