此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Integration 6.3.1
以下清单显示了 AMQP 入站通道适配器的可能配置选项:
  • Java DSL
  • Java
  • XML
public IntegrationFlow amqpInbound(ConnectionFactory connectionFactory) {
    return IntegrationFlow.from(Amqp.inboundAdapter(connectionFactory, "aName"))
            .handle(m -> System.out.println(m.getPayload()))
            .get();
public MessageChannel amqpInputChannel() {
    return new DirectChannel();
public AmqpInboundChannelAdapter inbound(SimpleMessageListenerContainer listenerContainer,
        @Qualifier("amqpInputChannel") MessageChannel channel) {
    AmqpInboundChannelAdapter adapter = new AmqpInboundChannelAdapter(listenerContainer);
    adapter.setOutputChannel(channel);
    return adapter;
public SimpleMessageListenerContainer container(ConnectionFactory connectionFactory) {
    SimpleMessageListenerContainer container =
                               new SimpleMessageListenerContainer(connectionFactory);
    container.setQueueNames("aName");
    container.setConcurrentConsumers(2);
    return container;
@ServiceActivator(inputChannel = "amqpInputChannel")
public MessageHandler handler() {
    return new MessageHandler() {
        public void handleMessage(Message<?> message) throws MessagingException {
            System.out.println(message.getPayload());
<int-amqp:inbound-channel-adapter
                                  id="inboundAmqp"                (1)
                                  channel="inboundChannel"        (2)
                                  queue-names="si.test.queue"     (3)
                                  acknowledge-mode="AUTO"         (4)
                                  advice-chain=""                 (5)
                                  channel-transacted=""           (6)
                                  concurrent-consumers=""         (7)
                                  connection-factory=""           (8)
                                  error-channel=""                (9)
                                  expose-listener-channel=""      (10)
                                  header-mapper=""                (11)
                                  mapped-request-headers=""       (12)
                                  listener-container=""           (13)
                                  message-converter=""            (14)
                                  message-properties-converter="" (15)
                                  phase=""                        (16)
                                  prefetch-count=""               (17)
                                  receive-timeout=""              (18)
                                  recovery-interval=""            (19)
                                  missing-queues-fatal=""         (20)
                                  shutdown-timeout=""             (21)
                                  task-executor=""                (22)
                                  transaction-attribute=""        (23)
                                  transaction-manager=""          (24)
                                  tx-size=""                      (25)
                                  consumers-per-queue             (26)
                                  batch-mode="MESSAGES"/>         (27)
<1> The unique ID for this adapter.
Optional.
<2> Message channel to which converted messages should be sent.
Required.
<3> Names of the AMQP queues (comma-separated list) from which messages should be consumed.
Required.
<4> Acknowledge mode for the `MessageListenerContainer`.
When set to `MANUAL`, the delivery tag and channel are provided in message headers `amqp_deliveryTag` and `amqp_channel`, respectively.
The user application is responsible for acknowledgement.
`NONE` means no acknowledgements (`autoAck`).
`AUTO` means the adapter's container acknowledges when the downstream flow completes.
Optional (defaults to AUTO).
See xref:amqp/inbound-ack.adoc[Inbound Endpoint Acknowledge Mode].
<5> Extra AOP Advices to handle cross-cutting behavior associated with this inbound channel adapter.
Optional.
<6> Flag to indicate that channels created by this component are transactional.
If true, it tells the framework to use a transactional channel and to end all operations (send or receive) with a commit or rollback, depending on the outcome, with an exception that signals a rollback.
Optional (Defaults to false).
<7> Specify the number of concurrent consumers to create.
The default is `1`.
We recommend raising the number of concurrent consumers to scale the consumption of messages coming in from a queue.
However, note that any ordering guarantees are lost once multiple consumers are registered.
In general, use one consumer for low-volume queues.
Not allowed when 'consumers-per-queue' is set.
Optional.
<8> Bean reference to the RabbitMQ `ConnectionFactory`.
Optional (defaults to `connectionFactory`).
<9> Message channel to which error messages should be sent.
Optional.
<10> Whether the listener channel (com.rabbitmq.client.Channel) is exposed to a registered `ChannelAwareMessageListener`.
Optional (defaults to true).
<11> A reference to an `AmqpHeaderMapper` to use when receiving AMQP Messages.
Optional.
By default, only standard AMQP properties (such as `contentType`) are copied to Spring Integration `MessageHeaders`.
Any user-defined headers within the AMQP `MessageProperties` are NOT copied to the message by the default `DefaultAmqpHeaderMapper`.
Not allowed if 'request-header-names' is provided.
<12> Comma-separated list of the names of AMQP Headers to be mapped from the AMQP request into the `MessageHeaders`.
This can only be provided if the 'header-mapper' reference is not provided.
The values in this list can also be simple patterns to be matched against the header names (such as "\*" or "thing1*, thing2" or "*something").
<13> Reference to the `AbstractMessageListenerContainer` to use for receiving AMQP Messages.
If this attribute is provided, no other attribute related to the listener container configuration should be provided.
In other words, by setting this reference, you must take full responsibility for the listener container configuration.
The only exception is the `MessageListener` itself.
Since that is actually the core responsibility of this channel adapter implementation, the referenced listener container must not already have its own `MessageListener`.
Optional.
<14> The `MessageConverter` to use when receiving AMQP messages.
Optional.
<15> The `MessagePropertiesConverter` to use when receiving AMQP messages.
Optional.
<16> Specifies the phase in which the underlying `AbstractMessageListenerContainer` should be started and stopped.
The startup order proceeds from lowest to highest, and the shutdown order is the reverse of that.
By default, this value is `Integer.MAX_VALUE`, meaning that this container starts as late as possible and stops as soon as possible.
Optional.
<17> Tells the AMQP broker how many messages to send to each consumer in a single request.
Often, you can set this value high to improve throughput.
It should be greater than or equal to the transaction size (see the `tx-size` attribute, later in this list).
Optional (defaults to `1`).
<18> Receive timeout in milliseconds.
Optional (defaults to `1000`).
<19> Specifies the interval between recovery attempts of the underlying `AbstractMessageListenerContainer` (in milliseconds).
Optional (defaults to `5000`).
<20> If 'true' and none of the queues are available on the broker, the container throws a fatal exception during startup and stops if the queues are deleted when the container is running (after making three attempts to passively declare the queues).
If `false`, the container does not throw an exception and goes into recovery mode, attempting to restart according to the `recovery-interval`.
Optional (defaults to `true`).
<21> The time to wait for workers (in milliseconds) after the underlying `AbstractMessageListenerContainer` is stopped and before the AMQP connection is forced closed.
If any workers are active when the shutdown signal comes, they are allowed to finish processing as long as they can finish within this timeout.
Otherwise, the connection is closed and messages remain unacknowledged (if the channel is transactional).
<22> By default, the underlying `AbstractMessageListenerContainer` uses a `SimpleAsyncTaskExecutor` implementation, that fires up a new thread for each task, running it asynchronously.
By default, the number of concurrent threads is unlimited.
Note that this implementation does not reuse threads.
Consider using a thread-pooling `TaskExecutor` implementation as an alternative.
Optional (defaults to `SimpleAsyncTaskExecutor`).
<23> By default, the underlying `AbstractMessageListenerContainer` creates a new instance of the `DefaultTransactionAttribute` (it takes the EJB approach to rolling back on runtime but not checked exceptions).
Optional (defaults to `DefaultTransactionAttribute`).
<24> Sets a bean reference to an external `PlatformTransactionManager` on the underlying `AbstractMessageListenerContainer`.
The transaction manager works in conjunction with the `channel-transacted` attribute.
If there is already a transaction in progress when the framework is sending or receiving a message and the `channelTransacted` flag is `true`, the commit or rollback of the messaging transaction is deferred until the end of the current transaction.
If the `channelTransacted` flag is `false`, no transaction semantics apply to the messaging operation (it is auto-acked).
For further information, see
https://docs.spring.io/spring-amqp/reference/html/%255Freference.html#%5Ftransactions[Transactions with Spring AMQP].
Optional.
<25> Tells the `SimpleMessageListenerContainer` how many messages to process in a single transaction (if the channel is transactional).
For best results, it should be less than or equal to the value set in `prefetch-count`.
<26> Indicates that the underlying listener container should be a `DirectMessageListenerContainer` instead of the default `SimpleMessageListenerContainer`.
See the https://docs.spring.io/spring-amqp/reference/html/[Spring AMQP Reference Manual] for more information.
<27> When the container's `consumerBatchEnabled` is `true`, determines how the adapter presents the batch of messages in the message payload.
When set to `MESSAGES` (default), the payload is a `List<Message<?>>` where each message has headers mapped from the incoming AMQP `Message` and the payload is the converted `body`.
When set to `EXTRACT_PAYLOADS`, the payload is a `List<?>` where the elements are converted from the AMQP `Message` body.
`EXTRACT_PAYLOADS_WITH_HEADERS` is similar to `EXTRACT_PAYLOADS` but, in addition, the headers from each message are mapped from the `MessageProperties` into a `List<Map<String, Object>` at the corresponding index; the header name is `AmqpInboundChannelAdapter.CONSOLIDATED_HEADERS`.
容器
请注意,使用 XML 配置外部容器时,不能使用 Spring AMQP 命名空间来定义容器。 这是因为命名空间至少需要一个元素。 在此环境中,侦听器位于适配器内部。 因此,您必须使用普通的 Spring 定义来定义容器,如以下示例所示:<listener/><bean/>
<bean id="container"
 class="org.springframework.amqp.rabbit.listener.SimpleMessageListenerContainer">
    <property name="connectionFactory" ref="connectionFactory" />
    <property name="queueNames" value="aName.queue" />
    <property name="defaultRequeueRejected" value="false"/>
</bean>
尽管 Spring Integration JMS 和 AMQP 支持相似,但存在重要差异。 JMS 入站通道适配器正在使用一个底层,并且需要一个配置的轮询器。 AMQP 入站通道适配器使用 和 是消息驱动的。 在这方面,它更类似于 JMS 消息驱动的通道适配器。JmsDestinationPollingSourceAbstractMessageListenerContainer
从版本 5.5 开始,可以使用在内部调用重试操作时使用的策略进行配置。 有关更多信息,请参阅 JavaDocs。AmqpInboundChannelAdapterorg.springframework.amqp.rabbit.retry.MessageRecovererRecoveryCallbacksetMessageRecoverer()
注释还可以与以下内容结合使用:@Publisher@RabbitListener
@EnableIntegration
@EnableRabbit
@EnablePublisher
public static class ContextConfiguration {
    QueueChannel fromRabbitViaPublisher() {
        return new QueueChannel();
    @RabbitListener(queuesToDeclare = @Queue("publisherQueue"))
    @Publisher("fromRabbitViaPublisher")
    @Payload("#args.payload.toUpperCase()")
    public void consumeForPublisher(String payload) {
默认情况下,AOP 侦听器处理来自方法调用的返回值。 但是,方法的返回值被视为 AMQP 回复消息。 因此,这种方法不能与 一起使用,因此对于此组合,建议使用针对方法参数的相应 SpEL 表达式的注释。 有关注释驱动配置部分的详细信息。@Publisher@RabbitListener@Publisher@Payload@Publisher
在侦听器容器中使用独占或单活动使用者时,建议将容器属性设置为 。 这将防止出现争用条件,即在停止容器后,另一个使用者可以在此实例完全停止之前开始使用消息。forceStoptrue
容器
</bean>
批处理消息
有关批处理消息的更多信息,请参阅 Spring AMQP 文档
要使用 Spring Integration 生成批处理消息,只需使用 .BatchingRabbitTemplate
在接收批处理消息时,默认情况下,侦听器容器会提取每个片段消息,适配器将为每个片段生成一个。 从版本 5.2 开始,如果容器的属性设置为 ,则由适配器执行反批处理,并生成一个有效负载为片段有效负载列表(如果适用,则在转换后)。Message<?>deBatchingEnabledfalseMessage<List<?>>
默认值为 ,但可以在适配器上覆盖。BatchingStrategySimpleBatchingStrategy
当重试操作需要恢复时,必须与批处理一起使用。org.springframework.amqp.rabbit.retry.MessageBatchRecoverer
