For the latest stable version, please use Spring Framework 6.2.0! |
Type Conversion
Some annotated controller method arguments that represent String-based request input (for example,
@RequestParam
, @RequestHeader
, @PathVariable
, @MatrixVariable
, and @CookieValue
can require type conversion if the argument is declared as something other than String
For such cases, type conversion is automatically applied based on the configured converters.
By default, simple types (such as int
, long
, Date
, and others) are supported. Type conversion
can be customized through a WebDataBinder
(see DataBinder
) or by registering
Formatters
with the FormattingConversionService
(see Spring Field Formatting).
A practical issue in type conversion is the treatment of an empty String source value.
Such a value is treated as missing if it becomes null
as a result of type conversion.
This can be the case for Long
, UUID
, and other target types. If you want to allow null
to be injected, either use the required
flag on the argument annotation, or declare the
argument as @Nullable
