For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
@SqlMergeMode
@SqlMergeMode is used to annotate a test class or test method to configure whether method-level @Sql declarations are merged with class-level @Sql declarations. If @SqlMergeMode is not declared on a test class or test method, the OVERRIDE merge mode will be used by default. With the OVERRIDE mode, method-level @Sql declarations will effectively override class-level @Sql declarations.spring-doc.cn
Note that a method-level @SqlMergeMode declaration overrides a class-level declaration.spring-doc.cn
The following example shows how to use @SqlMergeMode at the class level.spring-doc.cn
@SpringJUnitConfig(TestConfig.class)
@Sql("/test-schema.sql")
@SqlMergeMode(MERGE) (1)
class UserTests {
	@Test
	@Sql("/user-test-data-001.sql")
	void standardUserProfile() {
		// run code that relies on test data set 001
1 Set the @Sql merge mode to MERGE for all test methods in the class.
@SpringJUnitConfig(TestConfig::class)
class UserTests {
	@Test
	fun standardUserProfile() {
The following example shows how to use @SqlMergeMode at the method level.spring-doc.cn
class UserTests {
	@Test
1 Set the @Sql merge mode to MERGE for a specific test method.
class UserTests {
	@Test
