For the latest stable version, please use Spring Framework 6.2.0!spring-doc.cn
@BootstrapWith
@BootstrapWith is a class-level annotation that you can use to configure how the Spring TestContext Framework is bootstrapped. Specifically, you can use @BootstrapWith to specify a custom TestContextBootstrapper. See the section on bootstrapping the TestContext framework for further details.spring-doc.cn
