Running Your Application
One of the biggest advantages of packaging your application as a jar and using an embedded HTTP server is that you can run your application as you would any other. The same applies to debugging Spring Boot applications. You do not need any special IDE plugins or extensions.spring-doc.cn
The options below are best suited for running an application locally for development. For production deployment, see Packaging Your Application for Production.
This section only covers jar-based packaging. If you choose to package your application as a war file, see your server and IDE documentation.
Running From an IDE
You can run a Spring Boot application from your IDE as a Java application. However, you first need to import your project. Import steps vary depending on your IDE and build system. Most IDEs can import Maven projects directly. For example, Eclipse users can select Import…​Existing Maven Projects from the File menu.spring-doc.cn
If you cannot directly import your project into your IDE, you may be able to generate IDE metadata by using a build plugin. Maven includes plugins for Eclipse and IDEA. Gradle offers plugins for various IDEs.spring-doc.cn
If you accidentally run a web application twice, you see a “Port already in use” error. Spring Tools users can use the Relaunch button rather than the Run button to ensure that any existing instance is closed.
Running as a Packaged Application
If you use the Spring Boot Maven or Gradle plugins to create an executable jar, you can run your application using java -jar, as shown in the following example:spring-doc.cn
$ java -jar target/myapplication-0.0.1-SNAPSHOT.jar
It is also possible to run a packaged application with remote debugging support enabled. Doing so lets you attach a debugger to your packaged application, as shown in the following example:spring-doc.cn
$ java -agentlib:jdwp=server=y,transport=dt_socket,address=8000,suspend=n \
Using the Maven Plugin
The Spring Boot Maven plugin includes a run goal that can be used to quickly compile and run your application. Applications run in an exploded form, as they do in your IDE. The following example shows a typical Maven command to run a Spring Boot application:spring-doc.cn
$ mvn spring-boot:run
You might also want to use the MAVEN_OPTS operating system environment variable, as shown in the following example:spring-doc.cn
$ export MAVEN_OPTS=-Xmx1024m
Using the Gradle Plugin
The Spring Boot Gradle plugin also includes a bootRun task that can be used to run your application in an exploded form. The bootRun task is added whenever you apply the org.springframework.boot and java plugins and is shown in the following example:spring-doc.cn
$ gradle bootRun
You might also want to use the JAVA_OPTS operating system environment variable, as shown in the following example:spring-doc.cn
$ export JAVA_OPTS=-Xmx1024m
Hot Swapping
Since Spring Boot applications are plain Java applications, JVM hot-swapping should work out of the box. JVM hot swapping is somewhat limited with the bytecode that it can replace. For a more complete solution, JRebel can be used.spring-doc.cn
The spring-boot-devtools module also includes support for quick application restarts. See the Hot Swapping section in “How-to Guides” for details.spring-doc.cn
