Jersey
Secure Jersey Endpoints with Spring Security
Spring Security can be used to secure a Jersey-based web application in much the same way as it can be used to secure a Spring MVC-based web application. However, if you want to use Spring Security’s method-level security with Jersey, you must configure Jersey to use setStatus(int) rather sendError(int). This prevents Jersey from committing the response before Spring Security has had an opportunity to report an authentication or authorization failure to the client.spring-doc.cn
The jersey.config.server.response.setStatusOverSendError property must be set to true on the application’s ResourceConfig bean, as shown in the following example:spring-doc.cn
import java.util.Collections;
import org.glassfish.jersey.server.ResourceConfig;
@Component
public class JerseySetStatusOverSendErrorConfig extends ResourceConfig {
	public JerseySetStatusOverSendErrorConfig() {
		register(Endpoint.class);
		setProperties(Collections.singletonMap("jersey.config.server.response.setStatusOverSendError", true));
Use Jersey Alongside Another Web Framework
To use Jersey alongside another web framework, such as Spring MVC, it should be configured so that it will allow the other framework to handle requests that it cannot handle. First, configure Jersey to use a filter rather than a servlet by configuring the spring.jersey.type application property with a value of filter. Second, configure your ResourceConfig to forward requests that would have resulted in a 404, as shown in the following example.spring-doc.cn
import org.glassfish.jersey.servlet.ServletProperties;
@Component
public class JerseyConfig extends ResourceConfig {
	public JerseyConfig() {
		property(ServletProperties.FILTER_FORWARD_ON_404, true);
