Ahead-of-Time Processing
A number of questions often arise when people use the ahead-of-time processing of Spring Boot applications. This section addresses those questions.spring-doc.cn
Conditions
Ahead-of-time processing optimizes the application and evaluates @Conditional annotations based on the environment at build time. Profiles are implemented through conditions and are therefore affected, too.spring-doc.cn
If you want beans that are created based on a condition in an ahead-of-time optimized application, you have to set up the environment when building the application. The beans which are created while ahead-of-time processing at build time are then always created when running the application and can’t be switched off. To do this, you can set the profiles which should be used when building the application.spring-doc.cn
For Maven, this works by setting the profiles configuration of the spring-boot-maven-plugin:process-aot execution:spring-doc.cn
<profile>
    <id>native</id>
    <build>
        <pluginManagement>
            <plugins>
                <plugin>
                    <executions>
                        <execution>
                            <id>process-aot</id>
                            <configuration>
                                <profiles>profile-a,profile-b</profiles>
                            </configuration>
                        </execution>
                    </executions>
                </plugin>
            </plugins>
        </pluginManagement>
    </build>
</profile>
For Gradle, you need to configure the ProcessAot task:spring-doc.cn
tasks.withType(org.springframework.boot.gradle.tasks.aot.ProcessAot).configureEach {
    args('--spring.profiles.active=profile-a,profile-b')
Profiles which only change configuration properties that don’t influence conditions are supported without limitations when running ahead-of-time optimized applications.spring-doc.cn
