This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.5! |
Hot Swapping
Spring Boot supports hot swapping. This section answers questions about how it works.
Reload Static Content
There are several options for hot reloading.
The recommended approach is to use spring-boot-devtools
, as it provides additional development-time features, such as support for fast application restarts and LiveReload as well as sensible development-time configuration (such as template caching).
Devtools works by monitoring the classpath for changes.
This means that static resource changes must be "built" for the change to take effect.
By default, this happens automatically in Eclipse when you save your changes.
In IntelliJ IDEA, the Make Project command triggers the necessary build.
Due to the default restart exclusions, changes to static resources do not trigger a restart of your application.
They do, however, trigger a live reload.
Alternatively, running in an IDE (especially with debugging on) is a good way to do development (all modern IDEs allow reloading of static resources and usually also allow hot-swapping of Java class changes).
Finally, the Maven and Gradle plugins can be configured (see the addResources
property) to support running from the command line with reloading of static files directly from source.
You can use that with an external css/js compiler process if you are writing that code with higher-level tools.
Reload Templates without Restarting the Container
Most of the templating technologies supported by Spring Boot include a configuration option to disable caching (described later in this document).
If you use the spring-boot-devtools
module, these properties are automatically configured for you at development time.
Thymeleaf Templates
If you use Thymeleaf, set spring.thymeleaf.cache
to false
See ThymeleafAutoConfiguration
for other Thymeleaf customization options.
FreeMarker Templates
If you use FreeMarker, set spring.freemarker.cache
to false
See FreeMarkerAutoConfiguration
for other FreeMarker customization options.
Template caching for FreeMarker is not supported with WebFlux. |
Groovy Templates
If you use Groovy templates, set spring.groovy.template.cache
to false
See GroovyTemplateAutoConfiguration
for other Groovy customization options.
Fast Application Restarts
The spring-boot-devtools
module includes support for automatic application restarts.
While not as fast as technologies such as JRebel it is usually significantly faster than a “cold start”.
You should probably give it a try before investigating some of the more complex reload options discussed later in this document.
For more details, see the Developer Tools section.
Reload Java Classes without Restarting the Container
Many modern IDEs (Eclipse, IDEA, and others) support hot swapping of bytecode. Consequently, if you make a change that does not affect class or method signatures, it should reload cleanly with no side effects.
