Metadata Format
Configuration metadata files are located inside jars under META-INF/spring-configuration-metadata.json. They use a JSON format with items categorized under either “groups” or “properties” and additional values hints categorized under "hints", as shown in the following example:spring-doc.cn
{"groups": [
		"name": "server",
		"type": "org.springframework.boot.autoconfigure.web.ServerProperties",
		"sourceType": "org.springframework.boot.autoconfigure.web.ServerProperties"
		"name": "spring.jpa.hibernate",
		"type": "org.springframework.boot.autoconfigure.orm.jpa.JpaProperties$Hibernate",
		"sourceType": "org.springframework.boot.autoconfigure.orm.jpa.JpaProperties",
		"sourceMethod": "getHibernate()"
],"properties": [
		"name": "server.port",
		"type": "java.lang.Integer",
		"name": "server.address",
		"type": "java.net.InetAddress",
		  "name": "spring.jpa.hibernate.ddl-auto",
		  "type": "java.lang.String",
		  "description": "DDL mode. This is actually a shortcut for the \"hibernate.hbm2ddl.auto\" property.",
		  "sourceType": "org.springframework.boot.autoconfigure.orm.jpa.JpaProperties$Hibernate"
],"hints": [
		"values": [
				"value": "none",
				"description": "Disable DDL handling."
				"value": "validate",
				"description": "Validate the schema, make no changes to the database."
				"value": "update",
				"description": "Update the schema if necessary."
				"value": "create",
				"description": "Create the schema and destroy previous data."
				"value": "create-drop",
				"description": "Create and then destroy the schema at the end of the session."
Each “property” is a configuration item that the user specifies with a given value. For example, server.port and server.address might be specified in your application.properties/application.yaml, as follows:spring-doc.cn
server.port=9090
server.address=127.0.0.1
server:
  port: 9090
  address: 127.0.0.1
The “groups” are higher level items that do not themselves specify a value but instead provide a contextual grouping for properties. For example, the server.port and server.address properties are part of the server group.spring-doc.cn
It is not required that every “property” has a “group”. Some properties might exist in their own right.
Finally, “hints” are additional information used to assist the user in configuring a given property. For example, when a developer is configuring the spring.jpa.hibernate.ddl-auto property, a tool can use the hints to offer some auto-completion help for the none, validate, update, create, and create-drop values.spring-doc.cn
Group Attributes
The JSON object contained in the groups array can contain the attributes shown in the following table:spring-doc.cn
Name Type Purpose
namespring-doc.cn
Stringspring-doc.cn
The full name of the group. This attribute is mandatory.spring-doc.cn
typespring-doc.cn
Stringspring-doc.cn
The class name of the data type of the group. For example, if the group were based on a class annotated with @ConfigurationProperties, the attribute would contain the fully qualified name of that class. If it were based on a @Bean method, it would be the return type of that method. If the type is not known, the attribute may be omitted.spring-doc.cn
descriptionspring-doc.cn
Stringspring-doc.cn
A short description of the group that can be displayed to users. If no description is available, it may be omitted. It is recommended that descriptions be short paragraphs, with the first line providing a concise summary. The last line in the description should end with a period (.).spring-doc.cn
sourceTypespring-doc.cn
Stringspring-doc.cn
The class name of the source that contributed this group. For example, if the group were based on a @Bean method annotated with @ConfigurationProperties, this attribute would contain the fully qualified name of the @Configuration class that contains the method. If the source type is not known, the attribute may be omitted.spring-doc.cn
sourceMethodspring-doc.cn
Stringspring-doc.cn
The full name of the method (include parenthesis and argument types) that contributed this group (for example, the name of a @ConfigurationProperties annotated @Bean method). If the source method is not known, it may be omitted.spring-doc.cn
Property Attributes
The JSON object contained in the properties array can contain the attributes described in the following table:spring-doc.cn
Name Type Purpose
namespring-doc.cn
Stringspring-doc.cn
The full name of the property. Names are in lower-case period-separated form (for example, server.address). This attribute is mandatory.spring-doc.cn
typespring-doc.cn
Stringspring-doc.cn
The full signature of the data type of the property (for example, String) but also a full generic type (such as java.util.Map<java.lang.String,com.example.MyEnum>). You can use this attribute to guide the user as to the types of values that they can enter. For consistency, the type of a primitive is specified by using its wrapper counterpart (for example, boolean becomes Boolean). Note that this class may be a complex type that gets converted from a String as values are bound. If the type is not known, it may be omitted.spring-doc.cn
Stringspring-doc.cn
A short description of the property that can be displayed to users. If no description is available, it may be omitted. It is recommended that descriptions be short paragraphs, with the first line providing a concise summary. The last line in the description should end with a period (.).spring-doc.cn
Stringspring-doc.cn
The class name of the source that contributed this property. For example, if the property were from a class annotated with @ConfigurationProperties, this attribute would contain the fully qualified name of that class. If the source type is unknown, it may be omitted.spring-doc.cn
defaultValuespring-doc.cn
Objectspring-doc.cn
The default value, which is used if the property is not specified. If the type of the property is an array, it can be an array of value(s). If the default value is unknown, it may be omitted.spring-doc.cn
deprecationspring-doc.cn
Deprecationspring-doc.cn
Specify whether the property is deprecated. If the field is not deprecated or if that information is not known, it may be omitted. The next table offers more detail about the deprecation attribute.spring-doc.cn
The JSON object contained in the deprecation attribute of each properties element can contain the following attributes:spring-doc.cn
Name Type Purpose
levelspring-doc.cn
Stringspring-doc.cn
The level of deprecation, which can be either warning (the default) or error. When a property has a warning deprecation level, it should still be bound in the environment. However, when it has an error deprecation level, the property is no longer managed and is not bound.spring-doc.cn
reasonspring-doc.cn
Stringspring-doc.cn
A short description of the reason why the property was deprecated. If no reason is available, it may be omitted. It is recommended that descriptions be short paragraphs, with the first line providing a concise summary. The last line in the description should end with a period (.).spring-doc.cn
replacementspring-doc.cn
Stringspring-doc.cn
The full name of the property that replaces this deprecated property. If there is no replacement for this property, it may be omitted.spring-doc.cn
sincespring-doc.cn
Stringspring-doc.cn
The version in which the property became deprecated. Can be omitted.spring-doc.cn
Prior to Spring Boot 1.3, a single deprecated boolean attribute can be used instead of the deprecation element. This is still supported in a deprecated fashion and should no longer be used. If no reason and replacement are available, an empty deprecation object should be set.
Deprecation can also be specified declaratively in code by adding the @DeprecatedConfigurationProperty annotation to the getter exposing the deprecated property. For instance, assume that the my.app.target property was confusing and was renamed to my.app.name. The following example shows how to handle that situation:spring-doc.cn
import org.springframework.boot.context.properties.ConfigurationProperties;
import org.springframework.boot.context.properties.DeprecatedConfigurationProperty;
@ConfigurationProperties("my.app")
public class MyProperties {
	private String name;
	public String getName() {
		return this.name;
	public void setName(String name) {
		this.name = name;
	@Deprecated
	@DeprecatedConfigurationProperty(replacement = "my.app.name")
	public String getTarget() {
		return this.name;
	@Deprecated
	public void setTarget(String target) {
		this.name = target;
There is no way to set a level. warning is always assumed, since code is still handling the property.
The preceding code makes sure that the deprecated property still works (delegating to the name property behind the scenes). Once the getTarget and setTarget methods can be removed from your public API, the automatic deprecation hint in the metadata goes away as well. If you want to keep a hint, adding manual metadata with an error deprecation level ensures that users are still informed about that property. Doing so is particularly useful when a replacement is provided.spring-doc.cn
Hint Attributes
The JSON object contained in the hints array can contain the attributes shown in the following table:spring-doc.cn
Name Type Purpose
namespring-doc.cn
Stringspring-doc.cn
The full name of the property to which this hint refers. Names are in lower-case period-separated form (such as spring.mvc.servlet.path). If the property refers to a map (such as system.contexts), the hint either applies to the keys of the map (system.contexts.keys) or the values (system.contexts.values) of the map. This attribute is mandatory.spring-doc.cn
valuesspring-doc.cn
ValueHint[]spring-doc.cn
A list of valid values as defined by the ValueHint object (described in the next table). Each entry defines the value and may have a description.spring-doc.cn
providersspring-doc.cn
ValueProvider[]spring-doc.cn
A list of providers as defined by the ValueProvider object (described later in this document). Each entry defines the name of the provider and its parameters, if any.spring-doc.cn
The JSON object contained in the values attribute of each hint element can contain the attributes described in the following table:spring-doc.cn
Name Type Purpose
valuespring-doc.cn
Objectspring-doc.cn
A valid value for the element to which the hint refers. If the type of the property is an array, it can also be an array of value(s). This attribute is mandatory.spring-doc.cn
Stringspring-doc.cn
A short description of the value that can be displayed to users. If no description is available, it may be omitted. It is recommended that descriptions be short paragraphs, with the first line providing a concise summary. The last line in the description should end with a period (.).spring-doc.cn
The JSON object contained in the providers attribute of each hint element can contain the attributes described in the following table:spring-doc.cn
Name Type Purpose
namespring-doc.cn
Stringspring-doc.cn
The name of the provider to use to offer additional content assistance for the element to which the hint refers.spring-doc.cn
parametersspring-doc.cn
JSON objectspring-doc.cn
Any additional parameter that the provider supports (check the documentation of the provider for more details).spring-doc.cn
Repeated Metadata Items
Objects with the same “property” and “group” name can appear multiple times within a metadata file. For example, you could bind two separate classes to the same prefix, with each having potentially overlapping property names. While the same names appearing in the metadata multiple times should not be common, consumers of metadata should take care to ensure that they support it.spring-doc.cn
