This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.5! |
Sessions (sessions
The sessions
endpoint provides information about the application’s HTTP sessions that are managed by Spring Session.
Retrieving Sessions
To retrieve the sessions, make a GET
request to /actuator/sessions
, as shown in the following curl-based example:
$ curl 'http://localhost:8080/actuator/sessions?username=alice' -i -X GET
The preceding examples retrieves all of the sessions for the user whose username is alice
The resulting response is similar to the following:
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 789
"sessions" : [ {
"id" : "4db5efcc-99cb-4d05-a52c-b49acfbb7ea9",
"attributeNames" : [ ],
"creationTime" : "2025-05-13T03:02:39.531082962Z",
"lastAccessedTime" : "2025-05-13T08:02:02.531085376Z",
"maxInactiveInterval" : 1800,
"expired" : false
"id" : "c5861aae-d0d3-45bc-bb22-95aa4860b3b7",
"creationTime" : "2025-05-12T20:02:39.530167996Z",
"lastAccessedTime" : "2025-05-13T08:01:54.530174509Z",
"expired" : false
"id" : "75243438-186c-47de-85cb-f2c340d79b90",
"creationTime" : "2025-05-13T06:02:39.531088061Z",
"lastAccessedTime" : "2025-05-13T08:02:27.531088762Z",
"expired" : false
Query Parameters
The endpoint uses query parameters to limit the sessions that it returns. The following table shows the single required query parameter:
Parameter | Description |
Name of the user. |
Response Structure
The response contains details of the matching sessions. The following table describes the structure of the response:
Path | Type | Description |
Sessions for the given username. |
ID of the session. |
Names of the attributes stored in the session. |
Timestamp of when the session was created. |
Timestamp of when the session was last accessed. |
Maximum permitted period of inactivity, in seconds, before the session will expire. |
Whether the session has expired. |
Retrieving a Single Session
To retrieve a single session, make a GET
request to /actuator/sessions/{id}
$ curl 'http://localhost:8080/actuator/sessions/4db5efcc-99cb-4d05-a52c-b49acfbb7ea9' -i -X GET
The preceding example retrieves the session with the id
of 4db5efcc-99cb-4d05-a52c-b49acfbb7ea9
HTTP/1.1 200 OK
Content-Length: 208
{"id":"4db5efcc-99cb-4d05-a52c-b49acfbb7ea9","attributeNames":[],"creationTime":"2025-05-13T03:02:39.531082962Z","lastAccessedTime":"2025-05-13T08:02:02.531085376Z","maxInactiveInterval":1800,"expired":false}
Response Structure
The response contains details of the requested session. The following table describes the structure of the response:
Deleting a Session
To delete a session, make a DELETE
$ curl 'http://localhost:8080/actuator/sessions/4db5efcc-99cb-4d05-a52c-b49acfbb7ea9' -i -X DELETE
The preceding example deletes the session with the id
