Supporting Other Build Systems
If you want to use a build tool other than Maven, Gradle, or Ant, you likely need to develop your own plugin. Executable jars need to follow a specific format and certain entries need to be written in an uncompressed form (see the executable jar format section in the appendix for details).spring-doc.cn
The Spring Boot Maven and Gradle plugins both make use of spring-boot-loader-tools to actually generate jars. If you need to, you may use this library directly.spring-doc.cn
Repackaging Archives
To repackage an existing archive so that it becomes a self-contained executable archive, use Repackager. The Repackager class takes a single constructor argument that refers to an existing jar or war archive. Use one of the two available repackage() methods to either replace the original file or write to a new destination. Various settings can also be configured on the repackager before it is run.spring-doc.cn
Nested Libraries
When repackaging an archive, you can include references to dependency files by using the Libraries interface. We do not provide any concrete implementations of Libraries here as they are usually build-system-specific.spring-doc.cn
If your archive already includes libraries, you can use Libraries.NONE.spring-doc.cn
Finding a Main Class
If you do not use Repackager.setMainClass() to specify a main class, the repackager uses ASM to read class files and tries to find a suitable class with a public static void main(String[] args) method. An exception is thrown if more than one candidate is found.spring-doc.cn
Example Repackage Implementation
The following example shows a typical repackage implementation:spring-doc.cn
import java.io.File;
import java.io.IOException;
import java.util.List;
import org.springframework.boot.loader.tools.Library;
import org.springframework.boot.loader.tools.LibraryCallback;
import org.springframework.boot.loader.tools.LibraryScope;
import org.springframework.boot.loader.tools.Repackager;
public class MyBuildTool {
	public void build() throws IOException {
		File sourceJarFile = ...
		Repackager repackager = new Repackager(sourceJarFile);
		repackager.setBackupSource(false);
		repackager.repackage(this::getLibraries);
	private void getLibraries(LibraryCallback callback) throws IOException {
		// Build system specific implementation, callback for each dependency
		for (File nestedJar : getCompileScopeJars()) {
			callback.library(new Library(nestedJar, LibraryScope.COMPILE));
	private List<File> getCompileScopeJars() {
		return ...
import java.io.File
class MyBuildTool {
	@Throws(IOException::class)
	fun build() {
		val sourceJarFile: File? =  ...
		val repackager = Repackager(sourceJarFile)
		repackager.repackage { callback: LibraryCallback -> getLibraries(callback) }
	private fun getLibraries(callback: LibraryCallback) {
		for (nestedJar in getCompileScopeJars()!!) {
			callback.library(Library(nestedJar, LibraryScope.COMPILE))
	private fun getCompileScopeJars(): List<File?>? {
		return  ...
