JSON
Spring Boot provides integration with three JSON mapping libraries:spring-doc.cn
Jackson is the preferred and default library.spring-doc.cn
Jackson
Auto-configuration for Jackson is provided and Jackson is part of spring-boot-starter-json. When Jackson is on the classpath an ObjectMapper bean is automatically configured. Several configuration properties are provided for customizing the configuration of the ObjectMapper.spring-doc.cn
Custom Serializers and Deserializers
If you use Jackson to serialize and deserialize JSON data, you might want to write your own JsonSerializer and JsonDeserializer classes. Custom serializers are usually registered with Jackson through a module, but Spring Boot provides an alternative @JsonComponent annotation that makes it easier to directly register Spring Beans.spring-doc.cn
You can use the @JsonComponent annotation directly on JsonSerializer, JsonDeserializer or KeyDeserializer implementations. You can also use it on classes that contain serializers/deserializers as inner classes, as shown in the following example:spring-doc.cn
import java.io.IOException;
import com.fasterxml.jackson.core.JsonGenerator;
import com.fasterxml.jackson.core.JsonParser;
import com.fasterxml.jackson.core.ObjectCodec;
import com.fasterxml.jackson.databind.DeserializationContext;
import com.fasterxml.jackson.databind.JsonDeserializer;
import com.fasterxml.jackson.databind.JsonNode;
import com.fasterxml.jackson.databind.JsonSerializer;
import com.fasterxml.jackson.databind.SerializerProvider;
import org.springframework.boot.jackson.JsonComponent;
@JsonComponent
public class MyJsonComponent {
	public static class Serializer extends JsonSerializer<MyObject> {
		public void serialize(MyObject value, JsonGenerator jgen, SerializerProvider serializers) throws IOException {
			jgen.writeStartObject();
			jgen.writeStringField("name", value.getName());
			jgen.writeNumberField("age", value.getAge());
			jgen.writeEndObject();
	public static class Deserializer extends JsonDeserializer<MyObject> {
		public MyObject deserialize(JsonParser jsonParser, DeserializationContext ctxt) throws IOException {
			ObjectCodec codec = jsonParser.getCodec();
			JsonNode tree = codec.readTree(jsonParser);
			String name = tree.get("name").textValue();
			int age = tree.get("age").intValue();
			return new MyObject(name, age);
import com.fasterxml.jackson.core.JsonProcessingException
@JsonComponent
	class Serializer : JsonSerializer<MyObject>() {
		@Throws(IOException::class)
		override fun serialize(value: MyObject, jgen: JsonGenerator, serializers: SerializerProvider) {
			jgen.writeStringField("name", value.name)
			jgen.writeNumberField("age", value.age)
	class Deserializer : JsonDeserializer<MyObject>() {
		@Throws(IOException::class, JsonProcessingException::class)
		override fun deserialize(jsonParser: JsonParser, ctxt: DeserializationContext): MyObject {
			val codec = jsonParser.codec
			val tree = codec.readTree<JsonNode>(jsonParser)
			val name = tree["name"].textValue()
			val age = tree["age"].intValue()
			return MyObject(name, age)
All @JsonComponent beans in the ApplicationContext are automatically registered with Jackson. Because @JsonComponent is meta-annotated with @Component, the usual component-scanning rules apply.spring-doc.cn
Spring Boot also provides JsonObjectSerializer and JsonObjectDeserializer base classes that provide useful alternatives to the standard Jackson versions when serializing objects. See JsonObjectSerializer and JsonObjectDeserializer in the API documentation for details.spring-doc.cn
The example above can be rewritten to use JsonObjectSerializer and JsonObjectDeserializer as follows:spring-doc.cn
import org.springframework.boot.jackson.JsonObjectDeserializer;
import org.springframework.boot.jackson.JsonObjectSerializer;
@JsonComponent
	public static class Serializer extends JsonObjectSerializer<MyObject> {
		protected void serializeObject(MyObject value, JsonGenerator jgen, SerializerProvider provider)
	public static class Deserializer extends JsonObjectDeserializer<MyObject> {
		protected MyObject deserializeObject(JsonParser jsonParser, DeserializationContext context, ObjectCodec codec,
				JsonNode tree) throws IOException {
			String name = nullSafeValue(tree.get("name"), String.class);
			int age = nullSafeValue(tree.get("age"), Integer.class);
@JsonComponent
	class Serializer : JsonObjectSerializer<MyObject>() {
		override fun serializeObject(value: MyObject, jgen: JsonGenerator, provider: SerializerProvider) {
	class Deserializer : JsonObjectDeserializer<MyObject>() {
		override fun deserializeObject(jsonParser: JsonParser, context: DeserializationContext,
				codec: ObjectCodec, tree: JsonNode): MyObject {
			val name = nullSafeValue(tree["name"], String::class.java)
			val age = nullSafeValue(tree["age"], Int::class.java)
Mixins
Jackson has support for mixins that can be used to mix additional annotations into those already declared on a target class. Spring Boot’s Jackson auto-configuration will scan your application’s packages for classes annotated with @JsonMixin and register them with the auto-configured ObjectMapper. The registration is performed by Spring Boot’s JsonMixinModule.spring-doc.cn
Gson
Auto-configuration for Gson is provided. When Gson is on the classpath a Gson bean is automatically configured. Several spring.gson.* configuration properties are provided for customizing the configuration. To take more control, one or more GsonBuilderCustomizer beans can be used.spring-doc.cn
JSON-B
Auto-configuration for JSON-B is provided. When the JSON-B API and an implementation are on the classpath a Jsonb bean will be automatically configured. The preferred JSON-B implementation is Eclipse Yasson for which dependency management is provided.spring-doc.cn
