This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.5! |
Prometheus (prometheus
The prometheus
endpoint provides Spring Boot application’s metrics in the format required for scraping by a Prometheus server.
Retrieving All Metrics
To retrieve all metrics, make a GET
request to /actuator/prometheus
, as shown in the following curl-based example:
$ curl 'http://localhost:8080/actuator/prometheus' -i -X GET
The resulting response is similar to the following:
HTTP/1.1 200 OK
Content-Type: text/plain;version=0.0.4;charset=utf-8
Content-Length: 3087
# HELP jvm_buffer_count_buffers An estimate of the number of buffers in the pool
# TYPE jvm_buffer_count_buffers gauge
jvm_buffer_count_buffers{id="direct"} 3.0
jvm_buffer_count_buffers{id="mapped"} 0.0
jvm_buffer_count_buffers{id="mapped - 'non-volatile memory'"} 0.0
# HELP jvm_buffer_memory_used_bytes An estimate of the memory that the Java virtual machine is using for this buffer pool
# TYPE jvm_buffer_memory_used_bytes gauge
jvm_buffer_memory_used_bytes{id="direct"} 45056.0
jvm_buffer_memory_used_bytes{id="mapped"} 0.0
jvm_buffer_memory_used_bytes{id="mapped - 'non-volatile memory'"} 0.0
# HELP jvm_buffer_total_capacity_bytes An estimate of the total capacity of the buffers in this pool
# TYPE jvm_buffer_total_capacity_bytes gauge
jvm_buffer_total_capacity_bytes{id="direct"} 45056.0
jvm_buffer_total_capacity_bytes{id="mapped"} 0.0
jvm_buffer_total_capacity_bytes{id="mapped - 'non-volatile memory'"} 0.0
# HELP jvm_memory_committed_bytes The amount of memory in bytes that is committed for the Java virtual machine to use
# TYPE jvm_memory_committed_bytes gauge
jvm_memory_committed_bytes{area="heap",id="G1 Eden Space"} 5.3477376E7
jvm_memory_committed_bytes{area="heap",id="G1 Old Gen"} 1.09051904E8
jvm_memory_committed_bytes{area="heap",id="G1 Survivor Space"} 4194304.0
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'non-nmethods'"} 2555904.0
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4128768.0
jvm_memory_committed_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 1.8481152E7
jvm_memory_committed_bytes{area="nonheap",id="Compressed Class Space"} 1.1206656E7
jvm_memory_committed_bytes{area="nonheap",id="Metaspace"} 7.8905344E7
# HELP jvm_memory_max_bytes The maximum amount of memory in bytes that can be used for memory management
# TYPE jvm_memory_max_bytes gauge
jvm_memory_max_bytes{area="heap",id="G1 Eden Space"} -1.0
jvm_memory_max_bytes{area="heap",id="G1 Old Gen"} 1.073741824E9
jvm_memory_max_bytes{area="heap",id="G1 Survivor Space"} -1.0
jvm_memory_max_bytes{area="nonheap",id="CodeHeap 'non-nmethods'"} 5836800.0
jvm_memory_max_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 1.22912768E8
jvm_memory_max_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 1.22908672E8
jvm_memory_max_bytes{area="nonheap",id="Compressed Class Space"} 1.073741824E9
jvm_memory_max_bytes{area="nonheap",id="Metaspace"} -1.0
# HELP jvm_memory_used_bytes The amount of used memory
# TYPE jvm_memory_used_bytes gauge
jvm_memory_used_bytes{area="heap",id="G1 Eden Space"} 9437184.0
jvm_memory_used_bytes{area="heap",id="G1 Old Gen"} 8.3251712E7
jvm_memory_used_bytes{area="heap",id="G1 Survivor Space"} 3603072.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-nmethods'"} 1384832.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4108160.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 1.8467072E7
jvm_memory_used_bytes{area="nonheap",id="Compressed Class Space"} 1.0799744E7
jvm_memory_used_bytes{area="nonheap",id="Metaspace"} 7.810216E7
The default response content type is text/plain;version=0.0.4
The endpoint can also produce application/openmetrics-text;version=1.0.0
when called with an appropriate Accept
header, as shown in the following curl-based example:
$ curl 'http://localhost:8080/actuator/prometheus' -i -X GET \
-H 'Accept: application/openmetrics-text; version=1.0.0; charset=utf-8'
HTTP/1.1 200 OK
Content-Type: application/openmetrics-text;version=1.0.0;charset=utf-8
Content-Length: 3093
jvm_memory_committed_bytes{area="nonheap",id="Compressed Class Space"} 1.114112E7
jvm_memory_committed_bytes{area="nonheap",id="Metaspace"} 7.8708736E7
jvm_memory_used_bytes{area="heap",id="G1 Eden Space"} 7340032.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4087936.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 1.8422912E7
jvm_memory_used_bytes{area="nonheap",id="Compressed Class Space"} 1.0787128E7
jvm_memory_used_bytes{area="nonheap",id="Metaspace"} 7.7956928E7
# EOF
Retrieving Filtered Metrics
To retrieve metrics matching specific names, make a GET
with the includedNames
query parameter, as shown in the following curl-based example:
$ curl 'http://localhost:8080/actuator/prometheus?includedNames=jvm_memory_used_bytes%2Cjvm_memory_committed_bytes' -i -X GET
HTTP/1.1 200 OK
Content-Length: 1462
jvm_memory_used_bytes{area="heap",id="G1 Eden Space"} 1.048576E7
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'non-profiled nmethods'"} 4108928.0
jvm_memory_used_bytes{area="nonheap",id="CodeHeap 'profiled nmethods'"} 1.8475008E7
jvm_memory_used_bytes{area="nonheap",id="Compressed Class Space"} 1.0800344E7
jvm_memory_used_bytes{area="nonheap",id="Metaspace"} 7.8105256E7
