Ahead-of-Time Processing With the JVM
It’s beneficial for the startup time to run your application using the AOT generated initialization code. First, you need to ensure that the jar you are building includes AOT generated code.spring-doc.cn
CDS and AOT can be combined to further improve startup time.
For Maven, this means that you should build with -Pnative to activate the native profile:spring-doc.cn
$ mvn -Pnative package
For Gradle, you need to ensure that your build includes the org.springframework.boot.aot plugin.spring-doc.cn
When the JAR has been built, run it with spring.aot.enabled system property set to true. For example:spring-doc.cn
$ java -Dspring.aot.enabled=true -jar myapplication.jar
........ Starting AOT-processed MyApplication ...
Beware that using the ahead-of-time processing has drawbacks. It implies the following restrictions:spring-doc.cn
To learn more about ahead-of-time processing, please see the Understanding Spring Ahead-of-Time Processing section.spring-doc.cn
