This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.5! |
Thread Dump (threaddump
The threaddump
endpoint provides a thread dump from the application’s JVM.
Retrieving the Thread Dump as JSON
To retrieve the thread dump as JSON, make a GET
request to /actuator/threaddump
with an appropriate Accept
header, as shown in the following curl-based example:
$ curl 'http://localhost:8080/actuator/threaddump' -i -X GET \
-H 'Accept: application/json'
The resulting response is similar to the following:
HTTP/1.1 200 OK
Content-Type: application/json
Content-Length: 41131
"threads" : [ {
"threadName" : "Test worker",
"threadId" : 1,
"blockedTime" : -1,
"blockedCount" : 29,
"waitedTime" : -1,
"waitedCount" : 179,
"lockOwnerId" : -1,
"daemon" : false,
"inNative" : false,
"suspended" : false,
"threadState" : "RUNNABLE",
"priority" : 5,
"stackTrace" : [ {
"moduleName" : "java.management",
"moduleVersion" : "17.0.15",
"methodName" : "dumpThreads0",
"fileName" : "ThreadImpl.java",
"lineNumber" : -2,
"nativeMethod" : true,
"className" : "sun.management.ThreadImpl"
"methodName" : "dumpAllThreads",
"lineNumber" : 528,
"nativeMethod" : false,
"lineNumber" : 516,
"classLoaderName" : "app",
"methodName" : "getFormattedThreadDump",
"fileName" : "ThreadDumpEndpoint.java",
"lineNumber" : 52,
"className" : "org.springframework.boot.actuate.management.ThreadDumpEndpoint"
"methodName" : "threadDump",
"lineNumber" : 43,
"moduleName" : "java.base",
"methodName" : "invoke0",
"fileName" : "NativeMethodAccessorImpl.java",
"lineNumber" : -2,
"className" : "jdk.internal.reflect.NativeMethodAccessorImpl"
"methodName" : "invoke",
"lineNumber" : 77,
"fileName" : "DelegatingMethodAccessorImpl.java",
"lineNumber" : 43,
"className" : "jdk.internal.reflect.DelegatingMethodAccessorImpl"
"fileName" : "Method.java",
"lineNumber" : 569,
"className" : "java.lang.reflect.Method"
"methodName" : "invokeMethod",
"fileName" : "ReflectionUtils.java",
"lineNumber" : 281,
"className" : "org.springframework.util.ReflectionUtils"
"fileName" : "ReflectiveOperationInvoker.java",
"lineNumber" : 74,
"className" : "org.springframework.boot.actuate.endpoint.invoke.reflect.ReflectiveOperationInvoker"
"fileName" : "AbstractDiscoveredOperation.java",
"lineNumber" : 60,
"className" : "org.springframework.boot.actuate.endpoint.annotation.AbstractDiscoveredOperation"
"methodName" : "handle",
"fileName" : "AbstractWebMvcEndpointHandlerMapping.java",
"lineNumber" : 327,
"className" : "org.springframework.boot.actuate.endpoint.web.servlet.AbstractWebMvcEndpointHandlerMapping$ServletWebOperationAdapter"
"lineNumber" : 434,
"className" : "org.springframework.boot.actuate.endpoint.web.servlet.AbstractWebMvcEndpointHandlerMapping$OperationHandler"
"lineNumber" : -2,
"lineNumber" : 77,
"lineNumber" : 43,
"lineNumber" : 569,
"methodName" : "doInvoke",
"fileName" : "InvocableHandlerMethod.java",
"lineNumber" : 258,
"className" : "org.springframework.web.method.support.InvocableHandlerMethod"
"methodName" : "invokeForRequest",
"lineNumber" : 191,
"methodName" : "invokeAndHandle",
"fileName" : "ServletInvocableHandlerMethod.java",
"lineNumber" : 118,
"className" : "org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod"
"methodName" : "invokeHandlerMethod",
"fileName" : "RequestMappingHandlerAdapter.java",
"lineNumber" : 986,
"className" : "org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter"
"methodName" : "handleInternal",
"lineNumber" : 891,
"fileName" : "AbstractHandlerMethodAdapter.java",
"lineNumber" : 87,
"className" : "org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter"
"methodName" : "doDispatch",
"fileName" : "DispatcherServlet.java",
"lineNumber" : 1089,
"className" : "org.springframework.web.servlet.DispatcherServlet"
"methodName" : "doService",
"lineNumber" : 979,
"methodName" : "processRequest",
"fileName" : "FrameworkServlet.java",
"lineNumber" : 1014,
"className" : "org.springframework.web.servlet.FrameworkServlet"
"methodName" : "doGet",
"lineNumber" : 903,
"methodName" : "service",
"fileName" : "HttpServlet.java",
"lineNumber" : 527,
"className" : "jakarta.servlet.http.HttpServlet"
"lineNumber" : 885,
"fileName" : "TestDispatcherServlet.java",
"lineNumber" : 72,
"className" : "org.springframework.test.web.servlet.TestDispatcherServlet"
"lineNumber" : 614,
"methodName" : "doFilter",
"fileName" : "MockFilterChain.java",
"lineNumber" : 165,
"className" : "org.springframework.mock.web.MockFilterChain$ServletFilterProxy"
"lineNumber" : 132,
"className" : "org.springframework.mock.web.MockFilterChain"
"methodName" : "perform",
"fileName" : "MockMvc.java",
"lineNumber" : 201,
"className" : "org.springframework.test.web.servlet.MockMvc"
"methodName" : "getMvcResultOrFailure",
"fileName" : "MockMvcTester.java",
"lineNumber" : 387,
"className" : "org.springframework.test.web.servlet.assertj.MockMvcTester"
"lineNumber" : 376,
"methodName" : "exchange",
"lineNumber" : 402,
"lineNumber" : 461,
"className" : "org.springframework.test.web.servlet.assertj.MockMvcTester$MockMvcRequestBuilder"
"methodName" : "assertThat",
"lineNumber" : 487,
"lineNumber" : 426,
"fileName" : "AssertionsForInterfaceTypes.java",
"lineNumber" : 82,
"className" : "org.assertj.core.api.AssertionsForInterfaceTypes"
"fileName" : "Assertions.java",
"lineNumber" : 3371,
"className" : "org.assertj.core.api.Assertions"
"methodName" : "jsonThreadDump",
"fileName" : "ThreadDumpEndpointDocumentationTests.java",
"lineNumber" : 65,
"className" : "org.springframework.boot.actuate.autoconfigure.management.ThreadDumpEndpointDocumentationTests"
"lineNumber" : -2,
"lineNumber" : 77,
"lineNumber" : 43,
"lineNumber" : 569,
"lineNumber" : 767,
"className" : "org.junit.platform.commons.util.ReflectionUtils"
"methodName" : "proceed",
"fileName" : "MethodInvocation.java",
"lineNumber" : 60,
"className" : "org.junit.jupiter.engine.execution.MethodInvocation"
"fileName" : "InvocationInterceptorChain.java",
"lineNumber" : 131,
"className" : "org.junit.jupiter.engine.execution.InvocationInterceptorChain$ValidatingInvocation"
"methodName" : "intercept",
"fileName" : "TimeoutExtension.java",
"lineNumber" : 156,
"className" : "org.junit.jupiter.engine.extension.TimeoutExtension"
"methodName" : "interceptTestableMethod",
"lineNumber" : 147,
"methodName" : "interceptTestMethod",
"lineNumber" : 86,
"methodName" : "apply",
"lineNumber" : -1,
"className" : "org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor$$Lambda$220/0x00007f780025c678"
"methodName" : "lambda$ofVoidMethod$0",
"fileName" : "InterceptingExecutableInvoker.java",
"lineNumber" : 103,
"className" : "org.junit.jupiter.engine.execution.InterceptingExecutableInvoker$ReflectiveInterceptorCall"
"lineNumber" : -1,
"className" : "org.junit.jupiter.engine.execution.InterceptingExecutableInvoker$ReflectiveInterceptorCall$$Lambda$221/0x00007f780025ca98"
"methodName" : "lambda$invoke$0",
"lineNumber" : 93,
"className" : "org.junit.jupiter.engine.execution.InterceptingExecutableInvoker"
"lineNumber" : -1,
"className" : "org.junit.jupiter.engine.execution.InterceptingExecutableInvoker$$Lambda$543/0x00007f780030f9f0"
"lineNumber" : 106,
"className" : "org.junit.jupiter.engine.execution.InvocationInterceptorChain$InterceptedInvocation"
"lineNumber" : 64,
"className" : "org.junit.jupiter.engine.execution.InvocationInterceptorChain"
"methodName" : "chainAndInvoke",
"lineNumber" : 45,
"lineNumber" : 37,
"lineNumber" : 92,
"lineNumber" : 86,
"methodName" : "lambda$invokeTestMethod$8",
"fileName" : "TestMethodTestDescriptor.java",
"lineNumber" : 217,
"className" : "org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor"
"methodName" : "execute",
"lineNumber" : -1,
"className" : "org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor$$Lambda$1196/0x00007f7800718240"
"fileName" : "ThrowableCollector.java",
"lineNumber" : 73,
"className" : "org.junit.platform.engine.support.hierarchical.ThrowableCollector"
"methodName" : "invokeTestMethod",
"lineNumber" : 213,
"lineNumber" : 138,
"lineNumber" : 68,
"methodName" : "lambda$executeRecursively$6",
"fileName" : "NodeTestTask.java",
"lineNumber" : 156,
"className" : "org.junit.platform.engine.support.hierarchical.NodeTestTask"
"lineNumber" : -1,
"className" : "org.junit.platform.engine.support.hierarchical.NodeTestTask$$Lambda$342/0x00007f7800280000"
"lineNumber" : 73,
"methodName" : "lambda$executeRecursively$8",
"lineNumber" : 146,
"lineNumber" : -1,
"className" : "org.junit.platform.engine.support.hierarchical.NodeTestTask$$Lambda$341/0x00007f780027fd10"
"methodName" : "around",
"fileName" : "Node.java",
"lineNumber" : 137,
"className" : "org.junit.platform.engine.support.hierarchical.Node"
"methodName" : "lambda$executeRecursively$9",
"lineNumber" : 144,
"lineNumber" : -1,
"className" : "org.junit.platform.engine.support.hierarchical.NodeTestTask$$Lambda$340/0x00007f780027f8e8"
"lineNumber" : 73,
"methodName" : "executeRecursively",
"lineNumber" : 143,
"lineNumber" : 100,
"methodName" : "accept",
"lineNumber" : -1,
"className" : "org.junit.platform.engine.support.hierarchical.SameThreadHierarchicalTestExecutorService$$Lambda$346/0x00007f7800280b18"
"methodName" : "forEach",
"fileName" : "ArrayList.java",
"lineNumber" : 1511,
"className" : "java.util.ArrayList"
"methodName" : "invokeAll",
"fileName" : "SameThreadHierarchicalTestExecutorService.java",
"lineNumber" : 41,
"className" : "org.junit.platform.engine.support.hierarchical.SameThreadHierarchicalTestExecutorService"
"lineNumber" : 160,
"lineNumber" : -1,
"lineNumber" : 73,
"lineNumber" : 146,
"lineNumber" : -1,
"lineNumber" : 137,
"lineNumber" : 144,
"lineNumber" : -1,
"lineNumber" : 73,
"lineNumber" : 143,
"lineNumber" : 100,
"lineNumber" : -1,
"lineNumber" : 41,
"lineNumber" : 160,
"lineNumber" : -1,
"lineNumber" : 73,
"lineNumber" : 146,
"lineNumber" : -1,
"lineNumber" : 137,
"lineNumber" : 144,
"lineNumber" : -1,
"lineNumber" : 73,
"lineNumber" : 143,
"lineNumber" : 100,
"methodName" : "submit",
"lineNumber" : 35,
"fileName" : "HierarchicalTestExecutor.java",
"lineNumber" : 57,
"className" : "org.junit.platform.engine.support.hierarchical.HierarchicalTestExecutor"
"fileName" : "HierarchicalTestEngine.java",
"lineNumber" : 54,
"className" : "org.junit.platform.engine.support.hierarchical.HierarchicalTestEngine"
"fileName" : "EngineExecutionOrchestrator.java",
"lineNumber" : 198,
"className" : "org.junit.platform.launcher.core.EngineExecutionOrchestrator"
"lineNumber" : 169,
"lineNumber" : 93,
"methodName" : "lambda$execute$0",
"lineNumber" : 58,
"lineNumber" : -1,
"className" : "org.junit.platform.launcher.core.EngineExecutionOrchestrator$$Lambda$292/0x00007f7800268f58"
"methodName" : "withInterceptedStreams",
"lineNumber" : 141,
"lineNumber" : 57,
"fileName" : "DefaultLauncher.java",
"lineNumber" : 103,
"className" : "org.junit.platform.launcher.core.DefaultLauncher"
"lineNumber" : 85,
"fileName" : "DelegatingLauncher.java",
"lineNumber" : 47,
"className" : "org.junit.platform.launcher.core.DelegatingLauncher"
"methodName" : "processAllTestClasses",
"fileName" : "JUnitPlatformTestClassProcessor.java",
"lineNumber" : 124,
"className" : "org.gradle.api.internal.tasks.testing.junitplatform.JUnitPlatformTestClassProcessor$CollectAllTestClassesExecutor"
"methodName" : "access$000",
"lineNumber" : 99,
"methodName" : "stop",
"lineNumber" : 94,
"className" : "org.gradle.api.internal.tasks.testing.junitplatform.JUnitPlatformTestClassProcessor"
"fileName" : "SuiteTestClassProcessor.java",
"lineNumber" : 63,
"className" : "org.gradle.api.internal.tasks.testing.SuiteTestClassProcessor"
"lineNumber" : -2,
"lineNumber" : 77,
"lineNumber" : 43,
"lineNumber" : 569,
"methodName" : "dispatch",
"fileName" : "ReflectionDispatch.java",
"lineNumber" : 36,
"className" : "org.gradle.internal.dispatch.ReflectionDispatch"
"lineNumber" : 24,
"fileName" : "ContextClassLoaderDispatch.java",
"lineNumber" : 33,
"className" : "org.gradle.internal.dispatch.ContextClassLoaderDispatch"
"fileName" : "ProxyDispatchAdapter.java",
"lineNumber" : 92,
"className" : "org.gradle.internal.dispatch.ProxyDispatchAdapter$DispatchingInvocationHandler"
"moduleName" : "jdk.proxy1",
"lineNumber" : -1,
"className" : "jdk.proxy1.$Proxy4"
"methodName" : "run",
"fileName" : "TestWorker.java",
"lineNumber" : 200,
"className" : "org.gradle.api.internal.tasks.testing.worker.TestWorker$3"
"methodName" : "executeAndMaintainThreadName",
"lineNumber" : 132,
"className" : "org.gradle.api.internal.tasks.testing.worker.TestWorker"
"lineNumber" : 103,
"lineNumber" : 63,
"fileName" : "ActionExecutionWorker.java",
"lineNumber" : 56,
"className" : "org.gradle.process.internal.worker.child.ActionExecutionWorker"
"methodName" : "call",
"fileName" : "SystemApplicationClassLoaderWorker.java",
"lineNumber" : 122,
"className" : "org.gradle.process.internal.worker.child.SystemApplicationClassLoaderWorker"
"lineNumber" : 72,
"fileName" : "GradleWorkerMain.java",
"lineNumber" : 69,
"className" : "worker.org.gradle.process.internal.worker.GradleWorkerMain"
"methodName" : "main",
"lineNumber" : 74,
"lockedMonitors" : [ ],
"lockedSynchronizers" : [ ]
"threadName" : "Reference Handler",
"threadId" : 2,
"blockedTime" : -1,
"blockedCount" : 3,
"waitedTime" : -1,
"waitedCount" : 0,
"lockOwnerId" : -1,
"daemon" : true,
"inNative" : false,
"priority" : 10,
"stackTrace" : [ {
"methodName" : "waitForReferencePendingList",
"fileName" : "Reference.java",
"lineNumber" : -2,
"className" : "java.lang.ref.Reference"
"methodName" : "processPendingReferences",
"lineNumber" : 253,
"lineNumber" : 215,
"className" : "java.lang.ref.Reference$ReferenceHandler"
"threadName" : "Finalizer",
"threadId" : 3,
"blockedTime" : -1,
"blockedCount" : 1,
"waitedTime" : -1,
"waitedCount" : 2,
"lockName" : "java.lang.ref.ReferenceQueue$Lock@78171169",
"lockOwnerId" : -1,
"daemon" : true,
"inNative" : false,
"threadState" : "WAITING",
"priority" : 8,
"stackTrace" : [ {
"methodName" : "wait",
"lineNumber" : -2,
"className" : "java.lang.Object"
"methodName" : "remove",
"fileName" : "ReferenceQueue.java",
"lineNumber" : 155,
"className" : "java.lang.ref.ReferenceQueue"
"lineNumber" : 176,
"fileName" : "Finalizer.java",
"lineNumber" : 172,
"className" : "java.lang.ref.Finalizer$FinalizerThread"
"lockedSynchronizers" : [ ],
"lockInfo" : {
"className" : "java.lang.ref.ReferenceQueue$Lock",
"identityHashCode" : 2014777705
Response Structure
The response contains details of the JVM’s threads. The following table describes the structure of the response:
Path | Type | Description |
JVM’s threads. |
Total number of times that the thread has been blocked. |
Time in milliseconds that the thread has spent blocked. -1 if thread contention monitoring is disabled. |
Whether the thread is a daemon thread. Only available on Java 9 or later. |
Whether the thread is executing native code. |
Description of the object on which the thread is blocked, if any. |
Object for which the thread is blocked waiting. |
Fully qualified class name of the lock object. |
Identity hash code of the lock object. |
Monitors locked by this thread, if any |
Class name of the lock object. |
Stack depth where the monitor was locked. |
Stack frame that locked the monitor. |
Synchronizers locked by this thread. |
Class name of the locked synchronizer. |
Identity hash code of the locked synchronizer. |
ID of the thread that owns the object on which the thread is blocked. |
Name of the thread that owns the object on which the thread is blocked, if any. |
Priority of the thread. Only available on Java 9 or later. |
Stack trace of the thread. |
Name of the class loader of the class that contains the execution point identified by this entry, if any. Only available on Java 9 or later. |
Name of the class that contains the execution point identified by this entry. |
Name of the source file that contains the execution point identified by this entry, if any. |
Line number of the execution point identified by this entry. Negative if unknown. |
Name of the method. |
Name of the module that contains the execution point identified by this entry, if any. Only available on Java 9 or later. |
Version of the module that contains the execution point identified by this entry, if any. Only available on Java 9 or later. |
Whether the execution point is a native method. |
Whether the thread is suspended. |
ID of the thread. |
Name of the thread. |
State of the thread ( |
Total number of times that the thread has waited for notification. |
Time in milliseconds that the thread has spent waiting. -1 if thread contention monitoring is disabled |
Retrieving the Thread Dump as Text
To retrieve the thread dump as text, make a GET
that
accepts text/plain
-H 'Accept: text/plain'
HTTP/1.1 200 OK
Content-Type: text/plain;charset=UTF-8
Content-Length: 25522
2025-05-13 08:02:34
Full thread dump OpenJDK 64-Bit Server VM (17.0.15+10-LTS mixed mode, sharing):
"Test worker" - Thread t@1
java.lang.Thread.State: RUNNABLE
at [email protected]/sun.management.ThreadImpl.dumpThreads0(Native Method)
at [email protected]/sun.management.ThreadImpl.dumpAllThreads(ThreadImpl.java:528)
at [email protected]/sun.management.ThreadImpl.dumpAllThreads(ThreadImpl.java:516)
at app//org.springframework.boot.actuate.management.ThreadDumpEndpoint.getFormattedThreadDump(ThreadDumpEndpoint.java:52)
at app//org.springframework.boot.actuate.management.ThreadDumpEndpoint.textThreadDump(ThreadDumpEndpoint.java:48)
at [email protected]/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at [email protected]/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at [email protected]/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at [email protected]/java.lang.reflect.Method.invoke(Method.java:569)
at app//org.springframework.util.ReflectionUtils.invokeMethod(ReflectionUtils.java:281)
at app//org.springframework.boot.actuate.endpoint.invoke.reflect.ReflectiveOperationInvoker.invoke(ReflectiveOperationInvoker.java:74)
at app//org.springframework.boot.actuate.endpoint.annotation.AbstractDiscoveredOperation.invoke(AbstractDiscoveredOperation.java:60)
at app//org.springframework.boot.actuate.endpoint.web.servlet.AbstractWebMvcEndpointHandlerMapping$ServletWebOperationAdapter.handle(AbstractWebMvcEndpointHandlerMapping.java:327)
at app//org.springframework.boot.actuate.endpoint.web.servlet.AbstractWebMvcEndpointHandlerMapping$OperationHandler.handle(AbstractWebMvcEndpointHandlerMapping.java:434)
at app//org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:258)
at app//org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:191)
at app//org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:118)
at app//org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:986)
at app//org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:891)
at app//org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at app//org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1089)
at app//org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:979)
at app//org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1014)
at app//org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:903)
at app//jakarta.servlet.http.HttpServlet.service(HttpServlet.java:527)
at app//org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:885)
at app//org.springframework.test.web.servlet.TestDispatcherServlet.service(TestDispatcherServlet.java:72)
at app//jakarta.servlet.http.HttpServlet.service(HttpServlet.java:614)
at app//org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:165)
at app//org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:132)
at app//org.springframework.test.web.servlet.MockMvc.perform(MockMvc.java:201)
at app//org.springframework.test.web.servlet.assertj.MockMvcTester.getMvcResultOrFailure(MockMvcTester.java:387)
at app//org.springframework.test.web.servlet.assertj.MockMvcTester.perform(MockMvcTester.java:376)
at app//org.springframework.test.web.servlet.assertj.MockMvcTester.exchange(MockMvcTester.java:402)
at app//org.springframework.test.web.servlet.assertj.MockMvcTester$MockMvcRequestBuilder.exchange(MockMvcTester.java:461)
at app//org.springframework.test.web.servlet.assertj.MockMvcTester$MockMvcRequestBuilder.assertThat(MockMvcTester.java:487)
at app//org.springframework.test.web.servlet.assertj.MockMvcTester$MockMvcRequestBuilder.assertThat(MockMvcTester.java:426)
at app//org.assertj.core.api.AssertionsForInterfaceTypes.assertThat(AssertionsForInterfaceTypes.java:82)
at app//org.assertj.core.api.Assertions.assertThat(Assertions.java:3371)
at app//org.springframework.boot.actuate.autoconfigure.management.ThreadDumpEndpointDocumentationTests.textThreadDump(ThreadDumpEndpointDocumentationTests.java:180)
at app//org.junit.platform.commons.util.ReflectionUtils.invokeMethod(ReflectionUtils.java:767)
at app//org.junit.jupiter.engine.execution.MethodInvocation.proceed(MethodInvocation.java:60)
at app//org.junit.jupiter.engine.execution.InvocationInterceptorChain$ValidatingInvocation.proceed(InvocationInterceptorChain.java:131)
at app//org.junit.jupiter.engine.extension.TimeoutExtension.intercept(TimeoutExtension.java:156)
at app//org.junit.jupiter.engine.extension.TimeoutExtension.interceptTestableMethod(TimeoutExtension.java:147)
at app//org.junit.jupiter.engine.extension.TimeoutExtension.interceptTestMethod(TimeoutExtension.java:86)
at app//org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor$$Lambda$220/0x00007f780025c678.apply(Unknown Source)
at app//org.junit.jupiter.engine.execution.InterceptingExecutableInvoker$ReflectiveInterceptorCall.lambda$ofVoidMethod$0(InterceptingExecutableInvoker.java:103)
at app//org.junit.jupiter.engine.execution.InterceptingExecutableInvoker$ReflectiveInterceptorCall$$Lambda$221/0x00007f780025ca98.apply(Unknown Source)
at app//org.junit.jupiter.engine.execution.InterceptingExecutableInvoker.lambda$invoke$0(InterceptingExecutableInvoker.java:93)
at app//org.junit.jupiter.engine.execution.InterceptingExecutableInvoker$$Lambda$543/0x00007f780030f9f0.apply(Unknown Source)
at app//org.junit.jupiter.engine.execution.InvocationInterceptorChain$InterceptedInvocation.proceed(InvocationInterceptorChain.java:106)
at app//org.junit.jupiter.engine.execution.InvocationInterceptorChain.proceed(InvocationInterceptorChain.java:64)
at app//org.junit.jupiter.engine.execution.InvocationInterceptorChain.chainAndInvoke(InvocationInterceptorChain.java:45)
at app//org.junit.jupiter.engine.execution.InvocationInterceptorChain.invoke(InvocationInterceptorChain.java:37)
at app//org.junit.jupiter.engine.execution.InterceptingExecutableInvoker.invoke(InterceptingExecutableInvoker.java:92)
at app//org.junit.jupiter.engine.execution.InterceptingExecutableInvoker.invoke(InterceptingExecutableInvoker.java:86)
at app//org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor.lambda$invokeTestMethod$8(TestMethodTestDescriptor.java:217)
at app//org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor$$Lambda$1196/0x00007f7800718240.execute(Unknown Source)
at app//org.junit.platform.engine.support.hierarchical.ThrowableCollector.execute(ThrowableCollector.java:73)
at app//org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor.invokeTestMethod(TestMethodTestDescriptor.java:213)
at app//org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor.execute(TestMethodTestDescriptor.java:138)
at app//org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor.execute(TestMethodTestDescriptor.java:68)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$6(NodeTestTask.java:156)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask$$Lambda$342/0x00007f7800280000.execute(Unknown Source)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$8(NodeTestTask.java:146)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask$$Lambda$341/0x00007f780027fd10.invoke(Unknown Source)
at app//org.junit.platform.engine.support.hierarchical.Node.around(Node.java:137)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$9(NodeTestTask.java:144)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask$$Lambda$340/0x00007f780027f8e8.execute(Unknown Source)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask.executeRecursively(NodeTestTask.java:143)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask.execute(NodeTestTask.java:100)
at app//org.junit.platform.engine.support.hierarchical.SameThreadHierarchicalTestExecutorService$$Lambda$346/0x00007f7800280b18.accept(Unknown Source)
at [email protected]/java.util.ArrayList.forEach(ArrayList.java:1511)
at app//org.junit.platform.engine.support.hierarchical.SameThreadHierarchicalTestExecutorService.invokeAll(SameThreadHierarchicalTestExecutorService.java:41)
at app//org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$6(NodeTestTask.java:160)
at app//org.junit.platform.engine.support.hierarchical.SameThreadHierarchicalTestExecutorService.submit(SameThreadHierarchicalTestExecutorService.java:35)
at app//org.junit.platform.engine.support.hierarchical.HierarchicalTestExecutor.execute(HierarchicalTestExecutor.java:57)
at app//org.junit.platform.engine.support.hierarchical.HierarchicalTestEngine.execute(HierarchicalTestEngine.java:54)
at app//org.junit.platform.launcher.core.EngineExecutionOrchestrator.execute(EngineExecutionOrchestrator.java:198)
at app//org.junit.platform.launcher.core.EngineExecutionOrchestrator.execute(EngineExecutionOrchestrator.java:169)
at app//org.junit.platform.launcher.core.EngineExecutionOrchestrator.execute(EngineExecutionOrchestrator.java:93)
at app//org.junit.platform.launcher.core.EngineExecutionOrchestrator.lambda$execute$0(EngineExecutionOrchestrator.java:58)
at app//org.junit.platform.launcher.core.EngineExecutionOrchestrator$$Lambda$292/0x00007f7800268f58.accept(Unknown Source)
at app//org.junit.platform.launcher.core.EngineExecutionOrchestrator.withInterceptedStreams(EngineExecutionOrchestrator.java:141)
at app//org.junit.platform.launcher.core.EngineExecutionOrchestrator.execute(EngineExecutionOrchestrator.java:57)
at app//org.junit.platform.launcher.core.DefaultLauncher.execute(DefaultLauncher.java:103)
at app//org.junit.platform.launcher.core.DefaultLauncher.execute(DefaultLauncher.java:85)
at app//org.junit.platform.launcher.core.DelegatingLauncher.execute(DelegatingLauncher.java:47)
at org.gradle.api.internal.tasks.testing.junitplatform.JUnitPlatformTestClassProcessor$CollectAllTestClassesExecutor.processAllTestClasses(JUnitPlatformTestClassProcessor.java:124)
at org.gradle.api.internal.tasks.testing.junitplatform.JUnitPlatformTestClassProcessor$CollectAllTestClassesExecutor.access$000(JUnitPlatformTestClassProcessor.java:99)
at org.gradle.api.internal.tasks.testing.junitplatform.JUnitPlatformTestClassProcessor.stop(JUnitPlatformTestClassProcessor.java:94)
at org.gradle.api.internal.tasks.testing.SuiteTestClassProcessor.stop(SuiteTestClassProcessor.java:63)
at org.gradle.internal.dispatch.ReflectionDispatch.dispatch(ReflectionDispatch.java:36)
at org.gradle.internal.dispatch.ReflectionDispatch.dispatch(ReflectionDispatch.java:24)
at org.gradle.internal.dispatch.ContextClassLoaderDispatch.dispatch(ContextClassLoaderDispatch.java:33)
at org.gradle.internal.dispatch.ProxyDispatchAdapter$DispatchingInvocationHandler.invoke(ProxyDispatchAdapter.java:92)
at jdk.proxy1/jdk.proxy1.$Proxy4.stop(Unknown Source)
at org.gradle.api.internal.tasks.testing.worker.TestWorker$3.run(TestWorker.java:200)
at org.gradle.api.internal.tasks.testing.worker.TestWorker.executeAndMaintainThreadName(TestWorker.java:132)
at org.gradle.api.internal.tasks.testing.worker.TestWorker.execute(TestWorker.java:103)
at org.gradle.api.internal.tasks.testing.worker.TestWorker.execute(TestWorker.java:63)
at org.gradle.process.internal.worker.child.ActionExecutionWorker.execute(ActionExecutionWorker.java:56)
at org.gradle.process.internal.worker.child.SystemApplicationClassLoaderWorker.call(SystemApplicationClassLoaderWorker.java:122)
at org.gradle.process.internal.worker.child.SystemApplicationClassLoaderWorker.call(SystemApplicationClassLoaderWorker.java:72)
at app//worker.org.gradle.process.internal.worker.GradleWorkerMain.run(GradleWorkerMain.java:69)
at app//worker.org.gradle.process.internal.worker.GradleWorkerMain.main(GradleWorkerMain.java:74)
Locked ownable synchronizers:
- None
"Reference Handler" - Thread t@2
at [email protected]/java.lang.ref.Reference.waitForReferencePendingList(Native Method)
at [email protected]/java.lang.ref.Reference.processPendingReferences(Reference.java:253)
at [email protected]/java.lang.ref.Reference$ReferenceHandler.run(Reference.java:215)
- None
"Finalizer" - Thread t@3
java.lang.Thread.State: WAITING
at [email protected]/java.lang.Object.wait(Native Method)
- waiting on <78171169> (a java.lang.ref.ReferenceQueue$Lock)
at [email protected]/java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:155)
at [email protected]/java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:176)
at [email protected]/java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:172)
- None
"Signal Dispatcher" - Thread t@4
- None
"Common-Cleaner" - Thread t@11
java.lang.Thread.State: TIMED_WAITING
- waiting on <1c388703> (a java.lang.ref.ReferenceQueue$Lock)
at [email protected]/jdk.internal.ref.CleanerImpl.run(CleanerImpl.java:140)
at [email protected]/java.lang.Thread.run(Thread.java:840)
at [email protected]/jdk.internal.misc.InnocuousThread.run(InnocuousThread.java:162)
- None
"Notification Thread" - Thread t@12
- None
"/127.0.0.1:58042 to /127.0.0.1:41747 workers" - Thread t@14
at [email protected]/jdk.internal.misc.Unsafe.park(Native Method)
- parking to wait for <3c1ca89c> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at [email protected]/java.util.concurrent.locks.LockSupport.park(LockSupport.java:341)
at [email protected]/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionNode.block(AbstractQueuedSynchronizer.java:506)
at [email protected]/java.util.concurrent.ForkJoinPool.unmanagedBlock(ForkJoinPool.java:3465)
at [email protected]/java.util.concurrent.ForkJoinPool.managedBlock(ForkJoinPool.java:3436)
at [email protected]/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:1630)
at org.gradle.internal.remote.internal.hub.queue.EndPointQueue.take(EndPointQueue.java:49)
at org.gradle.internal.remote.internal.hub.MessageHub$Handler.run(MessageHub.java:403)
at org.gradle.internal.concurrent.ExecutorPolicy$CatchAndRecordFailures.onExecute(ExecutorPolicy.java:64)
at org.gradle.internal.concurrent.AbstractManagedExecutor$1.run(AbstractManagedExecutor.java:48)
at [email protected]/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
at [email protected]/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
- Locked <3e84448c> (a java.util.concurrent.ThreadPoolExecutor$Worker)
"/127.0.0.1:58042 to /127.0.0.1:41747 workers Thread 2" - Thread t@15
- parking to wait for <4f162df8> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at org.gradle.internal.remote.internal.hub.MessageHub$ConnectionDispatch.run(MessageHub.java:322)
- Locked <32502377> (a java.util.concurrent.ThreadPoolExecutor$Worker)
"/127.0.0.1:58042 to /127.0.0.1:41747 workers Thread 3" - Thread t@16
at [email protected]/sun.nio.ch.EPoll.wait(Native Method)
at [email protected]/sun.nio.ch.EPollSelectorImpl.doSelect(EPollSelectorImpl.java:118)
at [email protected]/sun.nio.ch.SelectorImpl.lockAndDoSelect(SelectorImpl.java:129)
- locked <fcaf12a> (a sun.nio.ch.Util$2)
- locked <e937569> (a sun.nio.ch.EPollSelectorImpl)
at [email protected]/sun.nio.ch.SelectorImpl.select(SelectorImpl.java:146)
at org.gradle.internal.remote.internal.inet.SocketConnection$SocketInputStream.read(SocketConnection.java:187)
at com.esotericsoftware.kryo.io.Input.fill(Input.java:146)
at com.esotericsoftware.kryo.io.Input.require(Input.java:178)
at com.esotericsoftware.kryo.io.Input.readByte(Input.java:295)
at org.gradle.internal.serialize.kryo.KryoBackedDecoder.readByte(KryoBackedDecoder.java:88)
at org.gradle.internal.remote.internal.hub.InterHubMessageSerializer$MessageReader.read(InterHubMessageSerializer.java:64)
at org.gradle.internal.remote.internal.hub.InterHubMessageSerializer$MessageReader.read(InterHubMessageSerializer.java:52)
at org.gradle.internal.remote.internal.inet.SocketConnection.receive(SocketConnection.java:83)
at org.gradle.internal.remote.internal.hub.MessageHub$ConnectionReceive.run(MessageHub.java:270)
- Locked <550dbc7a> (a java.util.concurrent.ThreadPoolExecutor$Worker)
"process reaper" - Thread t@20
- parking to wait for <7094f0ae> (a java.util.concurrent.SynchronousQueue$TransferStack)
at [email protected]/java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:252)
at [email protected]/java.util.concurrent.SynchronousQueue$TransferStack.transfer(SynchronousQueue.java:401)
at [email protected]/java.util.concurrent.SynchronousQueue.poll(SynchronousQueue.java:903)
at [email protected]/java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1061)
at [email protected]/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1122)
- None
"Attach Listener" - Thread t@21
- None
"HikariPool-1 housekeeper" - Thread t@32
- parking to wait for <280f0c37> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at [email protected]/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:1679)
at [email protected]/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1182)
at [email protected]/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:899)
at [email protected]/java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1062)
- None
