This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.5! |
Info (info
The info
endpoint provides general information about the application.
Retrieving the Info
To retrieve the information about the application, make a GET
request to /actuator/info
, as shown in the following curl-based example:
$ curl 'http://localhost:8080/actuator/info' -i -X GET
The resulting response is similar to the following:
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 231
"git" : {
"branch" : "main",
"commit" : {
"id" : "df027cf",
"time" : "2025-05-13T08:02:26Z"
"build" : {
"artifact" : "application",
"version" : "1.0.3",
"group" : "com.example"
Response Structure
The response contains general information about the application.
Each section of the response is contributed by an InfoContributor
Spring Boot provides several contributors that are described below.
Build Response Structure
The following table describe the structure of the build
section of the response:
Path | Type | Description |
Artifact ID of the application, if any. |
Group ID of the application, if any. |
Name of the application, if any. |
Version of the application, if any. |
Timestamp of when the application was built, if any. |
Git Response Structure
The following table describes the structure of the git
Name of the Git branch, if any. |
Details of the Git commit, if any. |
Timestamp of the commit, if any. |
ID of the commit, if any. |
This is the "simple" output. The contributor can also be configured to output all available data. |
