Loggers (loggers)
The loggers endpoint provides access to the application’s loggers and the configuration of their levels.spring-doc.cn
Retrieving All Loggers
To retrieve the application’s loggers, make a GET request to /actuator/loggers, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/loggers' -i -X GET
The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 791
  "levels" : [ "OFF", "FATAL", "ERROR", "WARN", "INFO", "DEBUG", "TRACE" ],
  "loggers" : {
    "ROOT" : {
      "configuredLevel" : "INFO",
      "effectiveLevel" : "INFO"
    "com.example" : {
      "configuredLevel" : "DEBUG",
      "effectiveLevel" : "DEBUG"
  "groups" : {
    "test" : {
      "members" : [ "test.member1", "test.member2" ]
    "web" : {
      "members" : [ "org.springframework.core.codec", "org.springframework.http", "org.springframework.web", "org.springframework.boot.actuate.endpoint.web", "org.springframework.boot.web.servlet.ServletContextInitializerBeans" ]
    "sql" : {
      "members" : [ "org.springframework.jdbc.core", "org.hibernate.SQL", "org.jooq.tools.LoggerListener" ]
Response Structure
The response contains details of the application’s loggers. The following table describes the structure of the response:spring-doc.cn
Path Type Description
levelsspring-doc.cn
Arrayspring-doc.cn
Levels support by the logging system.spring-doc.cn
loggersspring-doc.cn
Objectspring-doc.cn
Loggers keyed by name.spring-doc.cn
groupsspring-doc.cn
Objectspring-doc.cn
Logger groups keyed by namespring-doc.cn
loggers.*.configuredLevelspring-doc.cn
Stringspring-doc.cn
Configured level of the logger, if any.spring-doc.cn
loggers.*.effectiveLevelspring-doc.cn
Stringspring-doc.cn
Effective level of the logger.spring-doc.cn
groups.*.configuredLevelspring-doc.cn
Stringspring-doc.cn
Configured level of the logger group, if any.spring-doc.cn
groups.*.membersspring-doc.cn
Arrayspring-doc.cn
Loggers that are part of this groupspring-doc.cn
Retrieving a Single Logger
To retrieve a single logger, make a GET request to /actuator/loggers/{logger.name}, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/loggers/com.example' -i -X GET
The preceding example retrieves information about the logger named com.example. The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Disposition: inline;filename=f.txt
Content-Length: 61
Response Structure
The response contains details of the requested logger. The following table describes the structure of the response:spring-doc.cn
Stringspring-doc.cn
Stringspring-doc.cn
Retrieving a Single Group
To retrieve a single group, make a GET request to /actuator/loggers/{group.name}, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/loggers/test' -i -X GET
The preceding example retrieves information about the logger group named test. The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Length: 82
Response Structure
The response contains details of the requested group. The following table describes the structure of the response:spring-doc.cn
Stringspring-doc.cn
Arrayspring-doc.cn
Setting a Log Level
To set the level of a logger, make a POST request to /actuator/loggers/{logger.name} with a JSON body that specifies the configured level for the logger, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/loggers/com.example' -i -X POST \
    -H 'Content-Type: application/json' \
    -d '{"configuredLevel":"debug"}'
The preceding example sets the configuredLevel of the com.example logger to DEBUG.spring-doc.cn
Request Structure
The request specifies the desired level of the logger. The following table describes the structure of the request:spring-doc.cn
Stringspring-doc.cn
Level for the logger. May be omitted to clear the level.spring-doc.cn
Setting a Log Level for a Group
To set the level of a logger, make a POST request to /actuator/loggers/{group.name} with a JSON body that specifies the configured level for the logger group, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/loggers/test' -i -X POST \
The preceding example sets the configuredLevel of the test logger group to DEBUG.spring-doc.cn
Request Structure
The request specifies the desired level of the logger group. The following table describes the structure of the request:spring-doc.cn
Stringspring-doc.cn
Clearing a Log Level
To clear the level of a logger, make a POST request to /actuator/loggers/{logger.name} with a JSON body containing an empty object, as shown in the following curl-based example:spring-doc.cn
    -d '{}'
The preceding example clears the configured level of the com.example logger.spring-doc.cn
