Security
This section addresses questions about security when working with Spring Boot, including questions that arise from using Spring Security with Spring Boot.spring-doc.cn
For more about Spring Security, see the Spring Security project page.spring-doc.cn
Switch Off the Spring Boot Security Configuration
If you define a @Configuration with a SecurityFilterChain bean in your application, this action switches off the default webapp security settings in Spring Boot.spring-doc.cn
Change the UserDetailsService and Add User Accounts
If you provide a @Bean of type AuthenticationManager, AuthenticationProvider, or UserDetailsService, the default @Bean for InMemoryUserDetailsManager is not created. This means you have the full feature set of Spring Security available (such as various authentication options).spring-doc.cn
The easiest way to add user accounts is by providing your own UserDetailsService bean.spring-doc.cn
Enable HTTPS When Running Behind a Proxy Server
Ensuring that all your main endpoints are only available over HTTPS is an important chore for any application. If you use Tomcat as a servlet container, then Spring Boot adds Tomcat’s own RemoteIpValve automatically if it detects some environment settings, allowing you to rely on the HttpServletRequest to report whether it is secure or not (even downstream of a proxy server that handles the real SSL termination). The standard behavior is determined by the presence or absence of certain request headers (x-forwarded-for and x-forwarded-proto), whose names are conventional, so it should work with most front-end proxies. You can switch on the valve by adding some entries to application.properties, as shown in the following example:spring-doc.cn
server.tomcat.remoteip.remote-ip-header=x-forwarded-for
server.tomcat.remoteip.protocol-header=x-forwarded-proto
server:
  tomcat:
    remoteip:
      remote-ip-header: "x-forwarded-for"
      protocol-header: "x-forwarded-proto"
(The presence of either of those properties switches on the valve. Alternatively, you can add the RemoteIpValve by customizing the TomcatServletWebServerFactory using a WebServerFactoryCustomizer bean.)spring-doc.cn
To configure Spring Security to require a secure channel for all (or some) requests, consider adding your own SecurityFilterChain bean that adds the following HttpSecurity configuration:spring-doc.cn
import org.springframework.security.config.annotation.web.builders.HttpSecurity;
import org.springframework.security.web.SecurityFilterChain;
public class MySecurityConfig {
	public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
		// Customize the application security ...
		http.requiresChannel((channel) -> channel.anyRequest().requiresSecure());
		return http.build();
	fun securityFilterChain(http: HttpSecurity): SecurityFilterChain {
		http.requiresChannel { requests -> requests.anyRequest().requiresSecure() }
		return http.build()
