This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0!spring-doc.cn
Groovy DSL
The Groovy DSL is a wrapper and extension to Java DSL. The main goal we pursue here is to make Spring Integration development on Groovy as smooth and straightforward as is it possible with interoperability with existing Java DSL and some Groovy extensions or language-specific structures. The implementation is a part of Groovy Support module.spring-doc.cn
All you need to get started is just an import for import static org.springframework.integration.groovy.dsl.IntegrationGroovyDsl.integrationFlow - a class containing overloaded factory methods for the Groovy DSL.spring-doc.cn
For IntegrationFlow definitions as lambdas we typically don’t need anything else from Groovy and just declare a bean like this:spring-doc.cn
IntegrationFlow oddFlow() {
    { IntegrationFlowDefinition flow ->
	    flow.handle(Object, { p, h -> 'odd' })
In this case Groovy understands that the closure should be translated into an IntegrationFlow anonymous instance and the target Java DSL processor parses this construction properly into Java objects.spring-doc.cn
As an alternative to the construction above and for consistency with use-cases explained below, the spring-integration-groovy module provides a Groovy-specific DSL for declaring integration flows in a builder pattern style:spring-doc.cn
flowLambda() {
    integrationFlow {
        filter String, { it == 'test' }, { id 'filterEndpoint' }
        wireTap integrationFlow {
            channel { queue 'wireTapChannel' }
        delay {
		    messageGroupId 'delayGroup'
		    defaultDelay 100
        transform {
		    transformer { it.toUpperCase() }
            expectedType String
Such a global integrationFlow() function expects a closure in the builder style for a GroovyIntegrationFlowDefinition (a Groovy wrapper for the IntegrationFlowDefinition) and produces a regular IntegrationFlow lambda implementation. See more overloaded integrationFlow() variants below.spring-doc.cn
Many other scenarios require an IntegrationFlow to be started from the source of data (e.g. JdbcPollingChannelAdapter, JmsInboundGateway or just an existing MessageChannel). For this purpose, Spring Integration Java DSL provides an IntegrationFlow factory with a number of overloaded from() methods. This factory can be used in groovy as well:spring-doc.cn
flowFromSupplier() {
    IntegrationFlow.fromSupplier({ 'bar' }) { e -> e.poller { p -> p.fixedDelay(10).maxMessagesPerPoll(1) } }
            .channel({ c -> c.queue('fromSupplierQueue') } as Function)
            .get()
But unfortunately not all from() methods are compatible with Groovy structures. To solve this, Spring Integration provides a Groovy DSL factory around the IntegrationFlow factory. It is implemented as a set of overloaded integrationFlow() functions. With a consumer for a GroovyIntegrationFlowDefinition to declare the remainder of the flow as an IntegrationFlow closure to reuse the mentioned above experience and also avoid the need for a get() call in the end. For example:spring-doc.cn
functionFlow() {
    integrationFlow Function<byte[], String>,
            { beanName 'functionGateway' },
                transform {
		            transformer Transformers.objectToString()
                    id 'objectToStringTransformer'
                transform {
                    expectedType String
                splitWith {
                    expectedType Message<?>
                    function { it.payload }
                splitWith {
                    expectedType Object
                    id 'splitterEndpoint'
                    function { it }
                resequence()
                aggregate {
                    id 'aggregator'
                    outputProcessor { it.one }
someFlow() {
    integrationFlow ({ 'test' },
                poller { it.trigger new OnlyOnceTrigger() }
                id 'pollingSource'
                log LoggingHandler.Level.WARN, 'test.category'
                channel { queue 'pollerResultChannel' }
