This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Using RemoteFileTemplate
Spring Integration version 3.0 provides a new abstraction over the SftpSession
object.
The template provides methods to send, retrieve (as an InputStream
), remove, and rename files.
In addition, we provide an execute
method to let the caller run multiple operations on the session.
In all cases, the template takes care of reliably closing the session.
For more information, see the Javadoc for RemoteFileTemplate
There is a subclass for SFTP: SftpRemoteFileTemplate
We added additional methods in version 4.1, including getClientInstance()
It provides access to the underlying ChannelSftp
, which enables access to low-level APIs.
Version 5.0 introduced the RemoteFileOperations.invoke(OperationsCallback<F, T> action)
method.
This method lets several RemoteFileOperations
calls be called in the scope of the same thread-bounded Session
This is useful when you need to perform several high-level operations of the RemoteFileTemplate
as one unit of work.
For example, AbstractRemoteFileOutboundGateway
uses it with the mput
command implementation, where we perform a put
operation for each file in the provided directory and recursively for its sub-directories.
See the Javadoc for more information.
