This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Context Holder Advice
Starting with version 6.1, the ContextHolderRequestHandlerAdvice
has been introduced.
This advice takes some value from the request message as and stores it in the context holder.
The value is clear from the context when an execution is finished on the target MessageHandler
The best way to think about this advice is similar to the programming flow where we store some value into a ThreadLocal
, get access to it from the target call and then clean up the ThreadLocal
after execution.
The ContextHolderRequestHandlerAdvice
requires these constructor arguments: a Function<Message<?>, Object>
as a value provider, Consumer<Object>
as a context set callback and Runnable
as a context clean up hook.
Following is a sample how a ContextHolderRequestHandlerAdvice
can be used in combination with a o.s.i.file.remote.session.DelegatingSessionFactory
DelegatingSessionFactory<?> dsf(SessionFactory<?> one, SessionFactory<?> two) {
return new DelegatingSessionFactory<>(Map.of("one", one, "two", two), null);
ContextHolderRequestHandlerAdvice contextHolderRequestHandlerAdvice(DelegatingSessionFactory<String> dsf) {
return new ContextHolderRequestHandlerAdvice(message -> message.getHeaders().get("FACTORY_KEY"),
dsf::setThreadKey, dsf::clearThreadKey);
@ServiceActivator(inputChannel = "in", adviceChain = "contextHolderRequestHandlerAdvice")
FtpOutboundGateway ftpOutboundGateway(DelegatingSessionFactory<?> sessionFactory) {
return new FtpOutboundGateway(sessionFactory, "ls", "payload");
And it is just enough to send a message to the in
channel with a FACTORY_KEY
header set to either one
or two
sets the value from that header into a DelegatingSessionFactory
via its setThreadKey
Then when FtpOutboundGateway
executes an ls
command a proper delegating SessionFactory
is chosen from the DelegatingSessionFactory
according to the value in its ThreadLocal
When the result is produced from the FtpOutboundGateway
, a ThreadLocal
value in the DelegatingSessionFactory
is cleared according to the clearThreadKey()
call from the ContextHolderRequestHandlerAdvice
See Delegating Session Factory for more information.
