This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Advising Endpoints Using Annotations
When configuring certain endpoints by using annotations (@Filter
, @ServiceActivator
, @Splitter
, and @Transformer
), you can supply a bean name for the advice chain in the adviceChain
attribute.
In addition, the @Filter
annotation also has the discardWithinAdvice
attribute, which can be used to configure the discard behavior, as discussed in Advising Filters.
The following example causes the discard to be performed after the advice:
@MessageEndpoint
public class MyAdvisedFilter {
@Filter(inputChannel="input", outputChannel="output",
adviceChain="adviceChain", discardWithinAdvice="false")
public boolean filter(String s) {
return s.contains("good");
