This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0!spring-doc.cn
Writing files
To write messages to the file system, you can use a FileWritingMessageHandler. This class can deal with the following payload types:spring-doc.cn
For a String payload, you can configure the encoding and the charset.spring-doc.cn
To make things easier, you can configure the FileWritingMessageHandler as part of an outbound channel adapter or outbound gateway by using the XML namespace.spring-doc.cn
Starting with version 4.3, you can specify the buffer size to use when writing files.spring-doc.cn
Starting with version 5.1, you can provide a BiConsumer<File, Message<?>> newFileCallback which is triggered if you use FileExistsMode.APPEND or FileExistsMode.APPEND_NO_FLUSH and a new file has to be created. This callback receives a newly created file and the message which triggered it. This callback could be used to write a CSV header defined in the message header, for an example.spring-doc.cn
Generating File Names
In its simplest form, the FileWritingMessageHandler requires only a destination directory for writing the files. The name of the file to be written is determined by the handler’s FileNameGenerator. The default implementation looks for a message header whose key matches the constant defined as FileHeaders.FILENAME.spring-doc.cn
Alternatively, you can specify an expression to be evaluated against the message to generate a file name — for example, headers['myCustomHeader'] + '.something'. The expression must evaluate to a String. For convenience, the DefaultFileNameGenerator also provides the setHeaderName method, letting you explicitly specify the message header whose value is to be used as the filename.spring-doc.cn
Once set up, the DefaultFileNameGenerator employs the following resolution steps to determine the filename for a given message payload:spring-doc.cn
  1. Evaluate the expression against the message and, if the result is a non-empty String, use it as the filename.spring-doc.cn
  2. Otherwise, if the payload is a java.io.File, use the File object’s filename.spring-doc.cn
  3. Otherwise, use the message ID appended with .msg as the filename.spring-doc.cn
When you use the XML namespace support, both the file outbound channel adapter and the file outbound gateway support the following mutually exclusive configuration attributes:spring-doc.cn
  • filename-generator (a reference to a FileNameGenerator implementation)spring-doc.cn
  • filename-generator-expression (an expression that evaluates to a String)spring-doc.cn
While writing files, a temporary file suffix is used (its default is .writing). It is appended to the filename while the file is being written. To customize the suffix, you can set the temporary-file-suffix attribute on both the file outbound channel adapter and the file outbound gateway.spring-doc.cn
When using the APPEND file mode, the temporary-file-suffix attribute is ignored, since the data is appended to the file directly.
Starting with ,version 4.2.5, the generated file name (as a result of filename-generator or filename-generator-expression evaluation) can represent a child path together with the target file name. It is used as a second constructor argument for File(File parent, String child) as before. However, in the past we did not create (mkdirs()) directories for the child path, assuming only the file name. This approach is useful for cases when we need to restore the file system tree to match the source directory — for example, when unzipping the archive and saving all the files in the target directory in the original order.spring-doc.cn
Specifying the Output Directory
Both, the file outbound channel adapter and the file outbound gateway provide two mutually exclusive configuration attributes for specifying the output directory:spring-doc.cn
Spring Integration 2.2 introduced the directory-expression attribute.
Using the directory Attribute
When you use the directory attribute, the output directory is set to a fixed value, which is set when the FileWritingMessageHandler is initialized. If you do not specify this attribute, you must use the directory-expression attribute.spring-doc.cn
Using the directory-expression Attribute
If you want to have full SpEL support, you can use the directory-expression attribute. This attribute accepts a SpEL expression that is evaluated for each message being processed. Thus, you have full access to a message’s payload and its headers when you dynamically specify the output file directory.spring-doc.cn
The SpEL expression must resolve to either a String, java.io.File or org.springframework.core.io.Resource. (The latter is evaluated into a File anyway.) Furthermore, the resulting String or File must point to a directory. If you do not specify the directory-expression attribute, then you must set the directory attribute.spring-doc.cn
Using the auto-create-directory Attribute
By default, if the destination directory does not exist, the respective destination directory and any non-existing parent directories are automatically created. To prevent that behavior, you can set the auto-create-directory attribute to false. This attribute applies to both the directory and the directory-expression attributes.spring-doc.cn
When using the directory attribute and auto-create-directory is false, the following change was made starting with Spring Integration 2.2:spring-doc.cn
Instead of checking for the existence of the destination directory when the adapter is initialized, this check is now performed for each message being processed.spring-doc.cn
Furthermore, if auto-create-directory is true and the directory was deleted between the processing of messages, the directory is re-created for each message being processed.spring-doc.cn
Dealing with Existing Destination Files
When you write files and the destination file already exists, the default behavior is to overwrite that target file. You can change this behavior by setting the mode attribute on the relevant file outbound components. The following options exist:spring-doc.cn
Spring Integration 2.2 introduced the mode attribute and the APPEND, FAIL, and IGNORE options.
REPLACE
If the target file already exists, it is overwritten. If the mode attribute is not specified, this is the default behavior when writing files.spring-doc.cn
REPLACE_IF_MODIFIED
If the target file already exists, it is overwritten only if the last modified timestamp differs from that of the source file. For File payloads, the payload lastModified time is compared to the existing file. For other payloads, the FileHeaders.SET_MODIFIED (file_setModified) header is compared to the existing file. If the header is missing or has a value that is not a Number, the file is always replaced.spring-doc.cn
APPEND
This mode lets you append message content to the existing file instead of creating a new file each time. Note that this attribute is mutually exclusive with the temporary-file-suffix attribute because, when it appends content to the existing file, the adapter no longer uses a temporary file. The file is closed after each message.spring-doc.cn
APPEND_NO_FLUSH
This option has the same semantics as APPEND, but the data is not flushed and the file is not closed after each message. This can provide a significant performance at the risk of data loss in the event of a failure. See Flushing Files When Using APPEND_NO_FLUSH for more information.spring-doc.cn
FAIL
If the target file exists, a MessageHandlingException is thrown.spring-doc.cn
IGNORE
If the target file exists, the message payload is silently ignored.spring-doc.cn
When using a temporary file suffix (the default is .writing), the IGNORE option applies if either the final file name or the temporary file name exists.
The APPEND_NO_FLUSH mode was added in version 4.3. Using it can improve performance because the file is not closed after each message. However, this can cause data loss in the event of a failure.spring-doc.cn
Spring Integration provides several flushing strategies to mitigate this data loss:spring-doc.cn
  • Use flushInterval. If a file is not written to for this period of time, it is automatically flushed. This is approximate and may be up to 1.33x this time (with an average of 1.167x).spring-doc.cn
  • Send a message containing a regular expression to the message handler’s trigger method. Files with absolute path names matching the pattern are flushed.spring-doc.cn
  • Provide the handler with a custom MessageFlushPredicate implementation to modify the action taken when a message is sent to the trigger method.spring-doc.cn
  • Invoke one of the handler’s flushIfNeeded methods by passing in a custom FileWritingMessageHandler.FlushPredicate or FileWritingMessageHandler.MessageFlushPredicate implementation.spring-doc.cn
The predicates are called for each open file. See the Javadoc for these interfaces for more information. Note that, since version 5.0, the predicate methods provide another parameter: the time that the current file was first written to if new or previously closed.spring-doc.cn
When using flushInterval, the interval starts at the last write. The file is flushed only if it is idle for the interval. Starting with version 4.3.7, an additional property (flushWhenIdle) can be set to false, meaning that the interval starts with the first write to a previously flushed (or new) file.spring-doc.cn
File Timestamps
By default, the destination file’s lastModified timestamp is the time when the file was created (except that an in-place rename retains the current timestamp). Starting with version 4.3, you can now configure preserve-timestamp (or setPreserveTimestamp(true) when using Java configuration). For File payloads, this transfers the timestamp from the inbound file to the outbound (regardless of whether a copy was required). For other payloads, if the FileHeaders.SET_MODIFIED header (file_setModified) is present, it is used to set the destination file’s lastModified timestamp, as long as the header is a Number.spring-doc.cn
File Permissions
Starting with version 5.0, when writing files to a file system that supports Posix permissions, you can specify those permissions on the outbound channel adapter or gateway. The property is an integer and is usually supplied in the familiar octal format — for example, 0640, meaning that the owner has read/write permissions, the group has read-only permission, and others have no access.spring-doc.cn
File Outbound Channel Adapter
The following example configures a file outbound channel adapter:spring-doc.cn
<int-file:outbound-channel-adapter id="filesOut" directory="${input.directory.property}"/>
The namespace-based configuration also supports a delete-source-files attribute. If set to true, it triggers the deletion of the original source files after writing to a destination. The default value for that flag is false. The following example shows how to set it to true:spring-doc.cn
    directory="${output.directory}"
    delete-source-files="true"/>
The delete-source-files attribute has an effect only if the inbound message has a File payload or if the FileHeaders.ORIGINAL_FILE header value contains either the source File instance or a String representing the original file path.
Starting with version 4.2, the FileWritingMessageHandler supports an append-new-line option. If set to true, a new line is appended to the file after a message is written. The default attribute value is false. The following example shows how to use the append-new-line option:spring-doc.cn
<int-file:outbound-channel-adapter id="newlineAdapter"
	append-new-line="true"
    directory="${output.directory}"/>
Outbound Gateway
In cases where you want to continue processing messages based on the written file, you can use the outbound-gateway instead. It plays a role similar to that of the outbound-channel-adapter. However, after writing the file, it also sends it to the reply channel as the payload of a message.spring-doc.cn
The following example configures an outbound gateway:spring-doc.cn
<int-file:outbound-gateway id="mover" request-channel="moveInput"
    reply-channel="output"
    mode="REPLACE" delete-source-files="true"/>
As mentioned earlier, you can also specify the mode attribute, which defines the behavior of how to deal with situations where the destination file already exists. See Dealing with Existing Destination Files for further details. Generally, when using the file outbound gateway, the result file is returned as the message payload on the reply channel.spring-doc.cn
This also applies when specifying the IGNORE mode. In that case the pre-existing destination file is returned. If the payload of the request message was a file, you still have access to that original file through the message header. See FileHeaders.ORIGINAL_FILE.spring-doc.cn
The 'outbound-gateway' works well in cases where you want to first move a file and then send it through a processing pipeline. In such cases, you may connect the file namespace’s inbound-channel-adapter element to the outbound-gateway and then connect that gateway’s reply-channel to the beginning of the pipeline.
If you have more elaborate requirements or need to support additional payload types as input to be converted to file content, you can extend the FileWritingMessageHandler, but a much better option is to rely on a Transformer.spring-doc.cn
Configuring with Java Configuration
The following Spring Boot application shows an example of how to configure the inbound adapter with Java configuration:spring-doc.cn
@SpringBootApplication
@IntegrationComponentScan
public class FileWritingJavaApplication {
        ConfigurableApplicationContext context =
                      new SpringApplicationBuilder(FileWritingJavaApplication.class)
                              .web(false)
                              .run(args);
             MyGateway gateway = context.getBean(MyGateway.class);
             gateway.writeToFile("foo.txt", new File(tmpDir.getRoot(), "fileWritingFlow"), "foo");
    @ServiceActivator(inputChannel = "writeToFileChannel")
    public MessageHandler fileWritingMessageHandler() {
         Expression directoryExpression = new SpelExpressionParser().parseExpression("headers.directory");
         FileWritingMessageHandler handler = new FileWritingMessageHandler(directoryExpression);
         handler.setFileExistsMode(FileExistsMode.APPEND);
         return handler;
    @MessagingGateway(defaultRequestChannel = "writeToFileChannel")
    public interface MyGateway {
        void writeToFile(@Header(FileHeaders.FILENAME) String fileName,
                       @Header(FileHeaders.FILENAME) File directory, String data);
Configuring with the Java DSL
The following Spring Boot application shows an example of how to configure the inbound adapter with the Java DSL:spring-doc.cn
                         .web(false)
                         .run(args);
        MessageChannel fileWritingInput = context.getBean("fileWritingInput", MessageChannel.class);
        fileWritingInput.send(new GenericMessage<>("foo"));
   	public IntegrationFlow fileWritingFlow() {
   	    return IntegrationFlow.from("fileWritingInput")
   		        .enrichHeaders(h -> h.header(FileHeaders.FILENAME, "foo.txt")
   		                  .header("directory", new File(tmpDir.getRoot(), "fileWritingFlow")))
   	            .handle(Files.outboundGateway(m -> m.getHeaders().get("directory")))
   	            .channel(MessageChannels.queue("fileWritingResultChannel"))
   	            .get();
