This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0!spring-doc.cn
java.util.function Interfaces Support
Starting with version 5.1, Spring Integration provides direct support for interfaces in the java.util.function package. All messaging endpoints, (Service Activator, Transformer, Filter, etc.) can now refer to Function (or Consumer) beans. The Messaging Annotations can be applied directly on these beans similar to regular MessageHandler definitions. For example if you have this Function bean definition:spring-doc.cn
public class FunctionConfiguration {
    public Function<String, String> functionAsService() {
        return String::toUpperCase;
You can use it as a simple reference in an XML configuration file:spring-doc.cn
<service-activator input-channel="processorViaFunctionChannel" ref="functionAsService"/>
When we configure our flow with Messaging Annotations, the code is straightforward:spring-doc.cn
@Transformer(inputChannel = "functionServiceChannel")
When the function returns an array, Collection (essentially, any Iterable), Stream or Reactor Flux, @Splitter can be used on such a bean to perform iteration over the result content.spring-doc.cn
The java.util.function.Consumer interface can be used for an <int:outbound-channel-adapter> or, together with the @ServiceActivator annotation, to perform the final step of a flow:spring-doc.cn
@ServiceActivator(inputChannel = "messageConsumerServiceChannel")
public Consumer<Message<?>> messageConsumerAsService() {
    // Has to be an anonymous class for proper type inference
    return new Consumer<Message<?>>() {
        public void accept(Message<?> e) {
            collector().add(e);
Also, pay attention to the comment in the code snippet above: if you would like to deal with the whole message in your Function/Consumer you cannot use a lambda definition. Because of Java type erasure we cannot determine the target type for the apply()/accept() method call.spring-doc.cn
The java.util.function.Supplier interface can simply be used together with the @InboundChannelAdapter annotation, or as a ref in an <int:inbound-channel-adapter>:spring-doc.cn
@InboundChannelAdapter(value = "inputChannel", poller = @Poller(fixedDelay = "1000"))
public Supplier<String> pojoSupplier() {
    return () -> "foo";
With the Java DSL we just need to use a reference to the function bean in the endpoint definitions. Meanwhile, an implementation of the Supplier interface can be used as regular MessageSource definition:spring-doc.cn
public Function<String, String> toUpperCaseFunction() {
public Supplier<String> stringSupplier() {
    return () -> "foo";
public IntegrationFlow supplierFlow() {
    return IntegrationFlow.from(stringSupplier())
                .transform(toUpperCaseFunction())
                .channel("suppliedChannel")
                .get();
This function support is useful when used together with the Spring Cloud Function framework, where we have a function catalog and can refer to its member functions from an integration flow definition.spring-doc.cn
Also, many Spring Integration channel adapters and patterns are implemented as functions auto-configuration in Spring Functions Catalog project.spring-doc.cn
