This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Advising Filters
There is an additional consideration when advising Filter
advices.
By default, any discard actions (when the filter returns false
) are performed within the scope of the advice chain.
This could include all the flow downstream of the discard channel.
So, for example, if an element downstream of the discard channel throws an exception and there is a retry advice, the process is retried.
Also, if throwExceptionOnRejection
is set to true
(the exception is thrown within the scope of the advice).
Setting discard-within-advice
to false
modifies this behavior and the discard (or exception) occurs after the advice chain is called.
