This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Distributed Locks
In many situations the action against some context (or even single message) has to be performed in an exclusive manner.
One example is an aggregator component where we have to check the message group state for the current message to determine whether we can release the group or just add that message for future consideration.
For this purpose Java provides an API with java.util.concurrent.locks.Lock
implementations.
However, the problem becomes more complex when an application is distributed and/or run in the cluster.
The locking in this case is challenging and requires some shared state and its specific approach to achieve the exclusivity requirement.
Spring Integration provides a LockRegistry
abstraction with an in-memory DefaultLockRegistry
implementation based on the ReentrantLock
API.
The obtain(Object)
method of the LockRegistry
requires a lock key
for specific context.
For example, an aggregator uses a correlationKey
to lock operations around its group.
This way different locks can be used concurrently.
This obtain(Object)
method returns a java.util.concurrent.locks.Lock
instance (depending on the LockRegistry
implementation), therefore the rest of the logic is the same as standard Java Concurrency algorithm.
Starting with version 6.2, the LockRegistry
provides an executeLocked()
API (default
methods in this interface) to perform some task while locked.
The behavior of this API is similar to well-known JdbcTemplate
, JmsTemplate
or RestTemplate
The following example demonstrates the usage of this API:
LockRegistry registry = new DefaultLockRegistry();
registry.executeLocked("someLockKey", () -> someExclusiveResourceCall());
The method rethrows an exception from the task call, throws an InterruptedException
if Lock
is interrupted.
In addition, a variant with Duration
throws a java.util.concurrent.TimeoutException
when lock.tryLock()
returns false
Spring Integration provides these LockRegistry
implementations for distributed locks:
Spring Integration AWS extension also implements a DynamoDbLockRegistry
