This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Delayed Message Exchange
Spring AMQP supports the RabbitMQ Delayed Message Exchange Plugin.
For inbound messages, the x-delay
header is mapped to the AmqpHeaders.RECEIVED_DELAY
header.
Setting the AMQPHeaders.DELAY
header causes the corresponding x-delay
header to be set in outbound messages.
You can also specify the delay
and delayExpression
properties on outbound endpoints (delay-expression
when using XML configuration).
These properties take precedence over the AmqpHeaders.DELAY
header.
