This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Changes between 5.0 and 5.1
New Components
The following components are new in 5.1:
Improved Function Support
The java.util.function
interfaces now have improved integration support in the Framework components.
Also, Kotlin lambdas now can be used for handler and source methods.
General Changes
The following changes have been made in version 5.1:
Java DSL
The IntegrationFlowContext
is now an interface and IntegrationFlowRegistration
is an inner interface of IntegrationFlowContext
A new logAndReply()
operator has been introduced for convenience when you wish to log at the end of a flow for request-reply configurations.
This avoids confusion with log()
which is treated as a one-way end flow component.
A generated bean name for any NamedComponent
within an integration flow is now based on the component type for better readability from visual tools, logs analyzers and metrics collectors.
The GenericHandler.handle()
now excepts a MessageHeaders
type for the second argument.
Dispatcher Exceptions
Exceptions caught and re-thrown by AbstractDispatcher
are now more consistent:
A
MessagingException
of any kind that has afailedMessage
property is re-thrown unchanged. -
All other exceptions are wrapped in a
MessageDeliveryException
with thefailedMessage
property set.
Previously:
A
MessagingException
property was re-thrown unchanged -
A
MessagingException
that had nofailedMessage
property was wrapped in aMessagingException
property set. -
Other
RuntimeException
instances were re-thrown unchanged. -
Checked exceptions were wrapped in a
property set.
Global Channel Interceptors
Global channel interceptors now apply to dynamically registered channels, such as through the IntegrationFlowContext
when using the Java DSL or beans that are initialized using beanFactory.initializeBean()
Previously, when beans were created after the application context was refreshed, interceptors were not applied.
ChannelInterceptor.postReceive()
is no longer called when no message is received; it is no longer necessary to check for a null
Message<?>
Previously, the method was called.
If you have an interceptor that relies on the previous behavior, implement afterReceiveCompleted()
instead, since that method is invoked, regardless of whether a message is received or not.
Furthermore, the PolledAmqpChannel
and PolledJmsChannel
previously did not invoke afterReceiveCompleted()
with null
; they now do.
ObjectToJsonTransformer
A new ResultType.BYTES
mode is introduced for the ObjectToJsonTransformer
See JSON Transformers for more information.
Integration Flows: Generated Bean Names
Starting with version 5.0.5, generated bean names for the components in an IntegrationFlow
include the flow bean name, followed by a dot, as a prefix.
For example, if a flow bean were named flowBean
, a generated bean might be named flowBean.generatedBean
See Working With Message Flows for more information.
Aggregator Changes
If the groupTimeout
is evaluated to a negative value, an aggregator now expires the group immediately.
Only null
is considered as a signal to do nothing for the current message.
A new popSequence
property has been introduced to allow (by default) to call a MessageBuilder.popSequenceDetails()
for the output message.
Also an AbstractAggregatingMessageGroupProcessor
returns now an AbstractIntegrationMessageBuilder
instead of the whole Message
for optimization.
See Aggregator for more information.
@Publisher annotation changes
Starting with version 5.1, you must explicitly turn on the @Publisher
AOP functionality by using @EnablePublisher
or by using the <int:enable-publisher>
child element on <int:annotation-config>
Also the proxy-target-class
and order
attributes have been added for tuning the ProxyFactory
configuration.
See Annotation-driven Configuration with the @Publisher
Annotation for more information.
Files Changes
If you are using FileExistsMode.APPEND
or FileExistsMode.APPEND_NO_FLUSH
you can provide a newFileCallback
that will be called when creating a new file.
This callback receives the newly created file and the message that triggered the callback.
This could be used to write a CSV header, for an example.
The FileReadingMessageSource
now doesn’t check and create a directory until its start()
is called.
So, if an Inbound Channel Adapter for the FileReadingMessageSource
has autoStartup = false
, there are no failures against the file system during application start up.
See File Support for more information.
AMQP Changes
We have made ID
and Timestamp
header mapping changes in the DefaultAmqpHeaderMapper
See the note near the bottom of AMQP Message Headers for more information.
The contentType
header is now correctly mapped as an entry in the general headers map.
See contentType Header for more information.
Starting with version 5.1.3, if a message conversion exception occurs when using manual acknowledgments, and an error channel is defined, the payload is a ManualAckListenerExecutionFailedException
with additional channel
and deliveryTag
properties.
This enables the error flow to ack/nack the original message.
See Inbound Message Conversion for more information.
JDBC Changes
A confusing max-rows-per-poll
property on the JDBC Inbound Channel Adapter and JDBC Outbound Gateway has been deprecated in favor of the newly introduced max-rows
property.
The JdbcMessageHandler
supports now a batchUpdate
functionality when the payload of the request message is an instance of an Iterable
type.
The indexes for the INT_CHANNEL_MESSAGE
table (for the JdbcChannelMessageStore
) have been optimized.
If you have large message groups in such a store, you may wish to alter the indexes.
See JDBC Support for more information.
FTP and SFTP Changes
A RotatingServerAdvice
is now available to poll multiple servers and directories with the inbound channel adapters.
See Inbound Channel Adapters: Polling Multiple Servers and Directories and Inbound Channel Adapters: Polling Multiple Servers and Directories for more information.
Also, inbound adapter localFilenameExpression
instances can contain the #remoteDirectory
variable, which contains the remote directory being polled.
The generic type of the comparators (used to sort the fetched file list for the streaming adapters) has changed from Comparator<AbstractFileInfo<F>>
to Comparator<F>
See FTP Streaming Inbound Channel Adapter and SFTP Streaming Inbound Channel Adapter for more information.
In addition, the synchronizers for inbound channel adapters can now be provided with a Comparator
This is useful when using maxFetchSize
to limit the files retrieved.
The CachingSessionFactory
has a new property testSession
which, when true, causes the factory to perform a test()
operation on the Session
when checking out an existing session from the cache.
See SFTP Session Caching and FTP Session Caching for more information.
The outbound gateway MPUT command now supports a message payload with a collection of files or strings. See SFTP Outbound Gateway and FTP Outbound Gateway for more information.
TCP Support
When using SSL, host verification is now enabled, by default, to prevent man-in-the-middle attacks with a trusted certificate. See Host Verification for more information.
In addition the key and trust store types can now be configured on the DefaultTcpSSLContextSupport
Twitter Support
Since the Spring Social project has moved to end of life status, Twitter support in Spring Integration has been moved to the Extensions project. See Spring Integration Social Twitter for more information.
JMS Support
The JmsSendingMessageHandler
now provides deliveryModeExpression
and timeToLiveExpression
options to determine respective QoS options for JMS message to send at runtime.
The DefaultJmsHeaderMapper
now allows to map inbound JMSDeliveryMode
and JMSExpiration
properties via setting to true
respective setMapInboundDeliveryMode()
and setMapInboundExpiration()
options.
When a JmsMessageDrivenEndpoint
or JmsInboundGateway
is stopped, the associated listener container is now shut down; this closes its shared connection and any consumers.
You can configure the endpoints to revert to the previous behavior.
See JMS Support for more information.
HTTP/WebFlux Support
The statusCodeExpression
(and Function
) is now supplied with the RequestEntity<?>
as a root object for evaluation context, so request headers, method, URI and body are available for target status code calculation.
See HTTP Support and WebFlux Support for more information.
JMX Changes
Object name key values are now quoted if they contain any characters other than those allowed in a Java identifier (or period .
For example org.springframework.integration:type=MessageChannel,
name="input:foo.myGroup.errors"
This has the side effect that previously "allowed" names, with such characters, will now be quoted.
name="input#foo.myGroup.errors"
Micrometer Support Changes
It is now simpler to customize the standard Micrometer meters created by the framework. See Micrometer Integration for more information.
Integration Graph Customization
It is now possible to add additional properties to the IntegrationNode
s via Function<NamedComponent, Map<String, Object>> additionalPropertiesCallback
on the IntegrationGraphServer
See Integration Graph for more information.
Integration Global Properties
The Integration global properties (including defaults) can now be printed in the logs, when a DEBUG
logic level is turned on for the org.springframework.integration
category.
See Global Properties for more information.
The receiveTimeout
for @Poller
The @Poller
annotation now provides a receiveTimeout
option for convenience.
See Using the @Poller
