This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
HTTP Outbound Components
This section describes Spring Integration’s HTTP outbound components.
Using HttpRequestExecutingMessageHandler
To configure the HttpRequestExecutingMessageHandler
, write a bean definition similar to the following:
<bean id="httpOutbound"
class="org.springframework.integration.http.outbound.HttpRequestExecutingMessageHandler">
<constructor-arg value="http://localhost:8080/example" />
<property name="outputChannel" ref="responseChannel" />
</bean>
This bean definition runs HTTP requests by delegating to a RestTemplate
That template, in turn, delegates to a list of HttpMessageConverter
instances to generate the HTTP request body from the Message
payload.
You can configure those converters as well as the ClientHttpRequestFactory
instance to use, as the following example shows:
<property name="messageConverters" ref="messageConverterList" />
<property name="requestFactory" ref="customRequestFactory" />
</bean>
By default, the HTTP request is generated by using an instance of SimpleClientHttpRequestFactory
, which uses the JDK HttpURLConnection
Use of the Apache Commons HTTP Client is also supported through CommonsClientHttpRequestFactory
, which you can inject (as shown earlier).
For the outbound gateway, the reply message produced by the gateway contains all the message headers that are present in the request message. |
Using Cookies
Basic cookie support is provided by the transfer-cookies
attribute on the outbound gateway.
When set to true
(the default is false
), a Set-Cookie
header received from the server in a response is converted to Cookie
in the reply message.
This header is then used on subsequent sends.
This enables simple stateful interactions, such as the following:
…→logonGateway→…→doWorkGateway→…→logoffGateway→…
If transfer-cookies
is false
, any Set-Cookie
header received remains as Set-Cookie
in the reply message and is dropped on subsequent sends.
Empty Response Bodies
HTTP is a request-response protocol.
However, the response may not have a body, only headers.
In this case, the |
expected-response-type
Further to the preceding note about empty response bodies, if a response does contain a body, you must provide an appropriate |
Starting with version 5.5, the HttpRequestExecutingMessageHandler
exposes an extractResponseBody
flag (which is true
by default) to return just the response body, or to return the whole ResponseEntity
as the reply message payload, independently of the provided expectedResponseType
If a body is not present in the ResponseEntity
, this flag is ignored and the whole ResponseEntity
is returned.
