This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0!spring-doc.cn
Outbound Gateways
The JPA inbound channel adapter lets you poll a database to retrieve one or more JPA entities. The retrieved data is consequently used to start a Spring Integration flow that uses the retrieved data as message payload.spring-doc.cn
Additionally, you can use JPA outbound channel adapters at the end of your flow in order to persist data, essentially stopping the flow at the end of the persistence operation.spring-doc.cn
However, how can you execute JPA persistence operations in the middle of a flow? For example, you may have business data that you are processing in your Spring Integration message flow and that you would like to persist, yet you still need to use other components further downstream. Alternatively, instead of polling the database using a poller, you need to execute JPQL queries and actively retrieve data, which is then processed in subsequent components within your flow.spring-doc.cn
This is where JPA Outbound Gateways come into play. They give you the ability to persist data as well as retrieving data. To facilitate these uses, Spring Integration provides two types of JPA outbound gateways:spring-doc.cn
Whenever the outbound gateway is used to perform an action that saves, updates, or solely deletes some records in the database, you need to use an updating outbound gateway. If, for example, you use an entity to persist it, a merged and persisted entity is returned as a result. In other cases, the number of records affected (updated or deleted) is returned instead.spring-doc.cn
When retrieving (selecting) data from the database, we use a retrieving outbound gateway. With a retrieving outbound gateway, we can use JPQL, Named Queries (native or JPQL-based), or Native Queries (SQL) for selecting the data and retrieving the results.spring-doc.cn
An updating outbound gateway is functionally similar to an outbound channel adapter, except that an updating outbound gateway sends a result to the gateway’s reply channel after performing the JPA operation.spring-doc.cn
A retrieving outbound gateway is similar to an inbound channel adapter.spring-doc.cn
We recommend you first read the Outbound Channel Adapter section and the Inbound Channel Adapter sections earlier in this chapter, as most of the common concepts are explained there.
This similarity was the main factor to use the central JpaExecutor class to unify common functionality as much as possible.spring-doc.cn
Common for all JPA outbound gateways and similar to the outbound-channel-adapter, we can use for performing various JPA operations:spring-doc.cn
For configuration examples see JPA Outbound Gateway Samples.spring-doc.cn
Common Configuration Parameters
JPA Outbound Gateways always have access to the Spring Integration Message as input. Consequently, the following parameters is available:spring-doc.cn
parameter-source-factory
An instance of o.s.i.jpa.support.parametersource.ParameterSourceFactory used to get an instance of o.s.i.jpa.support.parametersource.ParameterSource. The ParameterSource is used to resolve the values of the parameters provided in the query. If you perform operations by using a JPA entity, the parameter-source-factory attribute is ignored. The parameter sub-elements are mutually exclusive with the parameter-source-factory and they have to be configured on the provided ParameterSourceFactory. Optional.spring-doc.cn
use-payload-as-parameter-source
If set to true, the payload of the Message is used as a source for parameters. If set to false, the entire Message is available as a source for parameters. If no JPA Parameters are passed in, this property defaults to true. This means that, if you use a default BeanPropertyParameterSourceFactory, the bean properties of the payload are used as a source for parameter values for the JPA query. However, if JPA Parameters are passed in, this property, by default, evaluates to false. The reason is that JPA Parameters let you provide SpEL Expressions. Therefore, it is highly beneficial to have access to the entire Message, including the headers. Optional.spring-doc.cn
Updating Outbound Gateway
The following listing shows all the attributes that you can set on an updating-outbound-gateway and describes the key attributes:spring-doc.cn
<int-jpa:updating-outbound-gateway request-channel=""  (1)
    auto-startup="true"
    entity-class=""
    entity-manager=""
    entity-manager-factory=""
    id=""
    jpa-operations=""
    jpa-query=""
    named-query=""
    native-query=""
    order=""
    parameter-source-factory=""
    persist-mode="MERGE"
    reply-channel=""  (2)
    reply-timeout=""  (3)
    use-payload-as-parameter-source="true">
    <int:poller/>
    <int-jpa:transactional/>
    <int-jpa:parameter name="" type="" value=""/>
    <int-jpa:parameter name="" expression=""/>
</int-jpa:updating-outbound-gateway>
1 The channel from which the outbound gateway receives messages for performing the desired operation. This attribute is similar to the channel attribute of the outbound-channel-adapter. Optional.
2 The channel to which the gateway send the response after performing the required JPA operation. If this attribute is not defined, the request message must have a replyChannel header. Optional.
3 Specifies the time the gateway waits to send the result to the reply channel. Only applies when the reply channel itself might block the send operation (for example, a bounded QueueChannel that is currently full). The value is specified in milliseconds. Optional.
The remaining attributes are described earlier in this chapter. See Configuration Parameter Reference and Configuration Parameter Reference.spring-doc.cn
Configuring with Java Configuration
The following Spring Boot application shows an example of how configure the outbound adapter with Java:spring-doc.cn
@SpringBootApplication
@EntityScan(basePackageClasses = StudentDomain.class)
@IntegrationComponentScan
public class JpaJavaApplication {
        new SpringApplicationBuilder(JpaJavaApplication.class)
            .web(false)
            .run(args);
    @Autowired
    private EntityManagerFactory entityManagerFactory;
    @MessagingGateway
    interface JpaGateway {
       @Gateway(requestChannel = "jpaUpdateChannel")
       @Transactional
       void updateStudent(StudentDomain payload);
    @ServiceActivator(channel = "jpaUpdateChannel")
    public MessageHandler jpaOutbound() {
        JpaOutboundGateway adapter =
               new JpaOutboundGateway(new JpaExecutor(this.entityManagerFactory));
        adapter.setOutputChannelName("updateResults");
        return adapter;
Configuring with the Java DSL
The following Spring Boot application shows an example of how to configure the outbound adapter using the Java DSL:spring-doc.cn
            .web(false)
            .run(args);
    @Autowired
    public IntegrationFlow updatingGatewayFlow() {
        return f -> f
                .handle(Jpa.updatingGateway(this.entityManagerFactory),
                        e -> e.transactional(true))
                .channel(c -> c.queue("updateResults"));
Retrieving Outbound Gateway
The following example demonstrates how to configure a retrieving outbound gateway:spring-doc.cn
            .web(false)
            .run(args);
    @Autowired
    public IntegrationFlow retrievingGatewayFlow() {
        return f -> f
                .handle(Jpa.retrievingGateway(this.entityManagerFactory)
                       .jpaQuery("from Student s where s.id = :id")
                       .expectSingleResult(true)
                       .parameterExpression("id", "payload"))
                .channel(c -> c.queue("retrieveResults"));
fun retrievingGatewayFlow() =
    integrationFlow {
        channel { queue("retrieveResults") }
            .web(false)
            .run(args);
    @Autowired
    public JpaExecutor jpaExecutor() {
        JpaExecutor executor = new JpaExecutor(this.entityManagerFactory);
        jpaExecutor.setJpaQuery("from Student s where s.id = :id");
        executor.setJpaParameters(Collections.singletonList(new JpaParameter("id", null, "payload")));
        jpaExecutor.setExpectSingleResult(true);
        return executor;
    @ServiceActivator(channel = "jpaRetrievingChannel")
        JpaOutboundGateway adapter = new JpaOutboundGateway(jpaExecutor());
        adapter.setOutputChannelName("retrieveResults");
        adapter.setGatewayType(OutboundGatewayType.RETRIEVING);
        return adapter;
<int-jpa:retrieving-outbound-gateway request-channel=""
    auto-startup="true"
    delete-after-poll="false"
    delete-in-batch="false"
    entity-class=""
    id-expression=""              (1)
    entity-manager=""
    expect-single-result="false"  (2)
    id=""
    jpa-operations=""
    jpa-query=""
    max-results=""                (3)
    max-results-expression=""     (4)
    first-result=""               (5)
    first-result-expression=""    (6)
    named-query=""
    native-query=""
    order=""
    reply-channel=""
    reply-timeout=""
    <int:poller></int:poller>
</int-jpa:retrieving-outbound-gateway>
1 (Since Spring Integration 4.0) The SpEL expression that determines the primaryKey value for EntityManager.find(Class entityClass, Object primaryKey) method against the requestMessage as the root object of evaluation context. The entityClass argument is determined from the entity-class attribute, if present. Otherwise, it is determined from the payload class. All other attributes are disallowed if you use id-expression. Optional.
2 A boolean flag indicating whether the select operation is expected to return a single result or a List of results. If this flag is set to true, a single entity is sent as the payload of the message. If multiple entities are returned, an exception thrown. If false, the List of entities sent as the payload of the message. It defaults to false. Optional.
3 This non-zero, non-negative integer value tells the adapter not to select more than the specified number of rows on execution of the select operation. By default, if this attribute is not set, all the possible records are selected by given query. This attribute is mutually exclusive with max-results-expression. Optional.
4 An expression that can be used to find the maximum number of results in a result set. It is mutually exclusive with max-results. Optional.
5 This non-zero, non-negative integer value tells the adapter the first record from which results are to be retrieved. This attribute is mutually exclusive with first-result-expression. Version 3.0 introduced this attribute. Optional.
6 This expression is evaluated against the message, to find the position of the first record in the result set. This attribute is mutually exclusive to first-result. Version 3.0 introduced this attribute. Optional.
When you choose to delete entities upon retrieval, and you have retrieved a collection of entities, by default, entities are deleted on a per-entity basis. This may cause performance issues.spring-doc.cn
Alternatively, you can set attribute deleteInBatch to true, which performs a batch delete. However, the limitation of doing so is that cascading deletes are not supported.spring-doc.cn
JSR 317: Java™ Persistence 2.0 states in chapter 4.10, “Bulk Update and Delete Operations” that:spring-doc.cn
“A delete operation only applies to entities of the specified class and its subclasses. It does not cascade to related entities.”spring-doc.cn
Starting with version 6.0, the Jpa.retrievingGateway() returns an empty list result when there are no entities returned by the query. Previously null was returned ending the flow, or throwing an exception, depending on requiresReply. Or, to revert to the previous behavior, add a filter after the gateway to filter out empty lists. It requires extra configuration in applications where empty list handling is a part of the downstream logic. See Splitter Discard Channel for possible empty list handling options.
This section contains various examples of using the updating outbound gateway and the retrieving outbound gateway:spring-doc.cn
Update by Using an Entity Class
In the following example, an updating outbound gateway is persisted by using the org.springframework.integration.jpa.test.entity.Student entity class as a JPA defining parameter:spring-doc.cn
<int-jpa:updating-outbound-gateway request-channel="entityRequestChannel"  (1)
    reply-channel="entityResponseChannel"  (2)
    entity-class="org.springframework.integration.jpa.test.entity.Student"
    entity-manager="em"/>
1 This is the request channel for the outbound gateway. It is similar to the channel attribute of the outbound-channel-adapter.
2 This is where a gateway differs from an outbound adapter. This is the channel over which the reply from the JPA operation is received. If, however, you are not interested in the reply received and want only to perform the operation, using a JPA outbound-channel-adapter is the appropriate choice. In this example, where we use an entity class, the reply is the entity object that was created or merged as a result of the JPA operation.
Update using JPQL
The following example updates an entity by using the Java Persistence Query Language (JPQL), which mandates using an updating outbound gateway:spring-doc.cn
<int-jpa:updating-outbound-gateway request-channel="jpaqlRequestChannel"
  reply-channel="jpaqlResponseChannel"
  jpa-query="update Student s set s.lastName = :lastName where s.rollNumber = :rollNumber"  (1)
  entity-manager="em">
    <int-jpa:parameter name="lastName" expression="payload"/>
    <int-jpa:parameter name="rollNumber" expression="headers['rollNumber']"/>
1 The JPQL query that the gateway executes. Since we used updating outbound gateway, only update and delete JPQL queries would be sensible choices.
When you send a message with a String payload that also contains a header called rollNumber with a long value, the last name of the student with the specified roll number is updated to the value in the message payload. When using an updating gateway, the return value is always an integer value, which denotes the number of records affected by execution of the JPA QL.spring-doc.cn
Retrieving an Entity using JPQL
The following example uses a retrieving outbound gateway and JPQL to retrieve (select) one or more entities from the database:spring-doc.cn
<int-jpa:retrieving-outbound-gateway request-channel="retrievingGatewayReqChannel"
    reply-channel="retrievingGatewayReplyChannel"
    jpa-query="select s from Student s where s.firstName = :firstName and s.lastName = :lastName"
    <int-jpa:parameter name="firstName" expression="payload"/>
    <int-jpa:parameter name="lastName" expression="headers['lastName']"/>
</int-jpa:outbound-gateway>
Retrieving an Entity by Using id-expression
The following example uses a retrieving outbound gateway with id-expression to retrieve (find) one and only one entity from the database: The primaryKey is the result of id-expression evaluation. The entityClass is a class of Message payload.spring-doc.cn
    id-expression="payload.id"
Update using a Named Query
Using a named query is basically the same as using a JPQL query directly. The difference is that the named-query attribute is used instead, as the following example shows:spring-doc.cn
<int-jpa:updating-outbound-gateway request-channel="namedQueryRequestChannel"
    reply-channel="namedQueryResponseChannel"
    named-query="updateStudentByRollNumber"
You can find a complete sample application that uses Spring Integration’s JPA adapter here.
