This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Annotation-Based Configuration
The following example from the samples repository shows some of the configuration options available when you use annotations instead of XML:
@EnableIntegration (1)
@IntegrationComponentScan (2)
public static class Config {
@Value(${some.port})
private int port;
@MessagingGateway(defaultRequestChannel="toTcp") (3)
public interface Gateway {
String viaTcp(String in);
@ServiceActivator(inputChannel="toTcp") (4)
public MessageHandler tcpOutGate(AbstractClientConnectionFactory connectionFactory) {
TcpOutboundGateway gate = new TcpOutboundGateway();
gate.setConnectionFactory(connectionFactory);
gate.setOutputChannelName("resultToString");
return gate;
@Bean (5)
public TcpInboundGateway tcpInGate(AbstractServerConnectionFactory connectionFactory) {
TcpInboundGateway inGate = new TcpInboundGateway();
inGate.setConnectionFactory(connectionFactory);
inGate.setRequestChannel(fromTcp());
return inGate;
public MessageChannel fromTcp() {
return new DirectChannel();
@MessageEndpoint
public static class Echo { (6)
@Transformer(inputChannel="fromTcp", outputChannel="toEcho")
public String convert(byte[] bytes) {
return new String(bytes);
@ServiceActivator(inputChannel="toEcho")
public String upCase(String in) {
return in.toUpperCase();
@Transformer(inputChannel="resultToString")
public String convertResult(byte[] bytes) {
public AbstractClientConnectionFactory clientCF() { (7)
return new TcpNetClientConnectionFactory("localhost", this.port);
public AbstractServerConnectionFactory serverCF() { (8)
return new TcpNetServerConnectionFactory(this.port);
1 | Standard Spring Integration annotation enabling the infrastructure for an integration application. |
2 | Searches for @MessagingGateway interfaces. |
3 | The entry point to the client-side of the flow.
The calling application can use @Autowired for this Gateway bean and invoke its method. |
4 | Outbound endpoints consist of a MessageHandler and a consumer that wraps it.
In this scenario, the @ServiceActivator configures the endpoint, according to the channel type. |
5 | Inbound endpoints (in the TCP/UDP module) are all message-driven and so only need to be declared as simple @Bean instances. |
6 | This class provides a number of POJO methods for use in this sample flow (a @Transformer and @ServiceActivator on the server side and a @Transformer on the client side). |
7 | The client-side connection factory. |
8 | The server-side connection factory. |
