MVC Config API
In Java configuration, you can implement the WebMvcConfigurer interface, as the following example shows:spring-doc.cn
@EnableWebMvc
	// Implement configuration methods...
@EnableWebMvc
In XML, you can check attributes and sub-elements of <mvc:annotation-driven/>. You can view the Spring MVC XML schema or use the code completion feature of your IDE to discover what attributes and sub-elements are available.spring-doc.cn
