Testing Client Applications
You can use client-side tests to test code that internally uses the RestTemplate. The idea is to declare expected requests and to provide “stub” responses so that you can focus on testing the code in isolation (that is, without running a server). The following example shows how to do so:spring-doc.cn
RestTemplate restTemplate = new RestTemplate();
MockRestServiceServer mockServer = MockRestServiceServer.bindTo(restTemplate).build();
mockServer.expect(requestTo("/greeting")).andRespond(withSuccess());
// Test code that uses the above RestTemplate ...
mockServer.verify();
val restTemplate = RestTemplate()
val mockServer = MockRestServiceServer.bindTo(restTemplate).build()
mockServer.verify()
In the preceding example, MockRestServiceServer (the central class for client-side REST tests) configures the RestTemplate with a custom ClientHttpRequestFactory that asserts actual requests against expectations and returns “stub” responses. In this case, we expect a request to /greeting and want to return a 200 response with text/plain content. We can define additional expected requests and stub responses as needed. When we define expected requests and stub responses, the RestTemplate can be used in client-side code as usual. At the end of testing, mockServer.verify() can be used to verify that all expectations have been satisfied.spring-doc.cn
By default, requests are expected in the order in which expectations were declared. You can set the ignoreExpectOrder option when building the server, in which case all expectations are checked (in order) to find a match for a given request. That means requests are allowed to come in any order. The following example uses ignoreExpectOrder:spring-doc.cn
server = MockRestServiceServer.bindTo(restTemplate).ignoreExpectOrder(true).build();
Even with unordered requests by default, each request is allowed to run once only. The expect method provides an overloaded variant that accepts an ExpectedCount argument that specifies a count range (for example, once, manyTimes, max, min, between, and so on). The following example uses times:spring-doc.cn
mockServer.expect(times(2), requestTo("/something")).andRespond(withSuccess());
mockServer.expect(times(3), requestTo("/somewhere")).andRespond(withSuccess());
mockServer.verify()
Note that, when ignoreExpectOrder is not set (the default), and, therefore, requests are expected in order of declaration, then that order applies only to the first of any expected request. For example if "/something" is expected two times followed by "/somewhere" three times, then there should be a request to "/something" before there is a request to "/somewhere", but, aside from that subsequent "/something" and "/somewhere", requests can come at any time.spring-doc.cn
As an alternative to all of the above, the client-side test support also provides a ClientHttpRequestFactory implementation that you can configure into a RestTemplate to bind it to a MockMvc instance. That allows processing requests using actual server-side logic but without running a server. The following example shows how to do so:spring-doc.cn
MockMvc mockMvc = MockMvcBuilders.webAppContextSetup(this.wac).build();
this.restTemplate = new RestTemplate(new MockMvcClientHttpRequestFactory(mockMvc));
val mockMvc = MockMvcBuilders.webAppContextSetup(this.wac).build()
restTemplate = RestTemplate(MockMvcClientHttpRequestFactory(mockMvc))
In some cases it may be necessary to perform an actual call to a remote service instead of mocking the response. The following example shows how to do that through ExecutingResponseCreator:spring-doc.cn
// Create ExecutingResponseCreator with the original request factory
ExecutingResponseCreator withActualResponse = new ExecutingResponseCreator(restTemplate.getRequestFactory());
mockServer.expect(requestTo("/profile")).andRespond(withSuccess());
mockServer.expect(requestTo("/quoteOfTheDay")).andRespond(withActualResponse);
val withActualResponse = new ExecutingResponseCreator(restTemplate.getRequestFactory())
mockServer.verify()
In the preceding example, we create the ExecutingResponseCreator using the ClientHttpRequestFactory from the RestTemplate before MockRestServiceServer replaces it with a different one that mocks responses. Then we define expectations with two kinds of responses:spring-doc.cn
  • a stub 200 response for the /profile endpoint (no actual request will be executed)spring-doc.cn
  • a response obtained through a call to the /quoteOfTheDay endpointspring-doc.cn
In the second case, the request is executed through the ClientHttpRequestFactory that was captured earlier. This generates a response that could e.g. come from an actual remote server, depending on how the RestTemplate was originally configured.spring-doc.cn
Static Imports
As with server-side tests, the fluent API for client-side tests requires a few static imports. Those are easy to find by searching for MockRest*. Eclipse users should add MockRestRequestMatchers.* and MockRestResponseCreators.* as “favorite static members” in the Eclipse preferences under Java → Editor → Content Assist → Favorites. That allows using content assist after typing the first character of the static method name. Other IDEs (such IntelliJ) may not require any additional configuration. Check for the support for code completion on static members.spring-doc.cn
Further Examples of Client-side REST Tests
Spring MVC Test’s own tests include example tests of client-side REST tests.spring-doc.cn
