Spring JUnit 4 Testing Annotations
@IfProfileValue
@IfProfileValue indicates that the annotated test is enabled for a specific testing environment. If the configured ProfileValueSource returns a matching value for the provided name, the test is enabled. Otherwise, the test is disabled and, effectively, ignored.spring-doc.cn
You can apply @IfProfileValue at the class level, the method level, or both. Class-level usage of @IfProfileValue takes precedence over method-level usage for any methods within that class or its subclasses. Specifically, a test is enabled if it is enabled both at the class level and at the method level. The absence of @IfProfileValue means the test is implicitly enabled. This is analogous to the semantics of JUnit 4’s @Ignore annotation, except that the presence of @Ignore always disables a test.spring-doc.cn
The following example shows a test that has an @IfProfileValue annotation:spring-doc.cn
@IfProfileValue(name="java.vendor", value="Oracle Corporation") (1)
@Test
public void testProcessWhichRunsOnlyOnOracleJvm() {
	// some logic that should run only on Java VMs from Oracle Corporation
1 Run this test only when the Java vendor is "Oracle Corporation".
@Test
fun testProcessWhichRunsOnlyOnOracleJvm() {
Alternatively, you can configure @IfProfileValue with a list of values (with OR semantics) to achieve TestNG-like support for test groups in a JUnit 4 environment. Consider the following example:spring-doc.cn
@IfProfileValue(name="test-groups", values={"unit-tests", "integration-tests"}) (1)
@Test
public void testProcessWhichRunsForUnitOrIntegrationTestGroups() {
	// some logic that should run only for unit and integration test groups
1 Run this test for unit tests and integration tests.
@IfProfileValue(name="test-groups", values=["unit-tests", "integration-tests"]) (1)
@Test
fun testProcessWhichRunsForUnitOrIntegrationTestGroups() {
@ProfileValueSourceConfiguration
@ProfileValueSourceConfiguration is a class-level annotation that specifies what type of ProfileValueSource to use when retrieving profile values configured through the @IfProfileValue annotation. If @ProfileValueSourceConfiguration is not declared for a test, SystemProfileValueSource is used by default. The following example shows how to use @ProfileValueSourceConfiguration:spring-doc.cn
@ProfileValueSourceConfiguration(CustomProfileValueSource.class) (1)
public class CustomProfileValueSourceTests {
	// class body...
1 Use a custom profile value source.
@ProfileValueSourceConfiguration(CustomProfileValueSource::class) (1)
	// class body...
@Timed
@Timed indicates that the annotated test method must finish execution in a specified time period (in milliseconds). If the text execution time exceeds the specified time period, the test fails.spring-doc.cn
The time period includes running the test method itself, any repetitions of the test (see @Repeat), as well as any setting up or tearing down of the test fixture. The following example shows how to use it:spring-doc.cn
@Timed(millis = 1000) (1)
public void testProcessWithOneSecondTimeout() {
	// some logic that should not take longer than 1 second to run
1 Set the time period for the test to one second.
fun testProcessWithOneSecondTimeout() {
Spring’s @Timed annotation has different semantics than JUnit 4’s @Test(timeout=…​) support. Specifically, due to the manner in which JUnit 4 handles test execution timeouts (that is, by executing the test method in a separate Thread), @Test(timeout=…​) preemptively fails the test if the test takes too long. Spring’s @Timed, on the other hand, does not preemptively fail the test but rather waits for the test to complete before failing.spring-doc.cn
@Repeat
@Repeat indicates that the annotated test method must be run repeatedly. The number of times that the test method is to be run is specified in the annotation.spring-doc.cn
The scope of execution to be repeated includes execution of the test method itself as well as any setting up or tearing down of the test fixture. When used with the SpringMethodRule, the scope additionally includes preparation of the test instance by TestExecutionListener implementations. The following example shows how to use the @Repeat annotation:spring-doc.cn
@Repeat(10) (1)
@Test
public void testProcessRepeatedly() {
1 Repeat this test ten times.
@Repeat(10) (1)
@Test
fun testProcessRepeatedly() {
