View Resolvers
The MVC configuration simplifies the registration of view resolvers.spring-doc.cn
The following Java configuration example configures content negotiation view resolution by using JSP and Jackson as a default View for JSON rendering:spring-doc.cn
@EnableWebMvc
	public void configureViewResolvers(ViewResolverRegistry registry) {
		registry.enableContentNegotiation(new MappingJackson2JsonView());
		registry.jsp();
@EnableWebMvc
	override fun configureViewResolvers(registry: ViewResolverRegistry) {
		registry.enableContentNegotiation(MappingJackson2JsonView())
		registry.jsp()
The following example shows how to achieve the same configuration in XML:spring-doc.cn
<mvc:view-resolvers>
	<mvc:content-negotiation>
		<mvc:default-views>
			<bean class="org.springframework.web.servlet.view.json.MappingJackson2JsonView"/>
		</mvc:default-views>
	</mvc:content-negotiation>
	<mvc:jsp/>
</mvc:view-resolvers>
Note, however, that FreeMarker, Groovy Markup, and script templates also require configuration of the underlying view technology.spring-doc.cn
The MVC namespace provides dedicated elements. The following example works with FreeMarker:spring-doc.cn
		<mvc:default-views>
	<mvc:freemarker cache="false"/>
<mvc:freemarker-configurer>
	<mvc:template-loader-path location="/freemarker"/>
</mvc:freemarker-configurer>
In Java configuration, you can add the respective Configurer bean, as the following example shows:spring-doc.cn
@EnableWebMvc
		registry.freeMarker().cache(false);
	public FreeMarkerConfigurer freeMarkerConfigurer() {
		FreeMarkerConfigurer configurer = new FreeMarkerConfigurer();
		configurer.setTemplateLoaderPath("/freemarker");
		return configurer;
@EnableWebMvc
	fun freeMarkerConfigurer() = FreeMarkerConfigurer().apply {
