Path Matching
You can customize options related to path matching and treatment of the URL. For details on the individual options, see the PathMatchConfigurer javadoc.spring-doc.cn
The following example shows how to customize path matching in Java configuration:spring-doc.cn
@EnableWebMvc
	public void configurePathMatch(PathMatchConfigurer configurer) {
		configurer.addPathPrefix("/api", HandlerTypePredicate.forAnnotation(RestController.class));
	private PathPatternParser patternParser() {
@EnableWebMvc
	override fun configurePathMatch(configurer: PathMatchConfigurer) {
		configurer.addPathPrefix("/api", HandlerTypePredicate.forAnnotation(RestController::class.java))
	fun patternParser(): PathPatternParser {
The following example shows how to customize path matching in XML configuration:spring-doc.cn
<mvc:annotation-driven>
	<mvc:path-matching
		path-helper="pathHelper"
		path-matcher="pathMatcher"/>
</mvc:annotation-driven>
<bean id="pathHelper" class="org.example.app.MyPathHelper"/>
<bean id="pathMatcher" class="org.example.app.MyPathMatcher"/>
