Safe Navigation Operator
The safe navigation operator (?) is used to avoid a NullPointerException and comes from the Groovy language. Typically, when you have a reference to an object, you might need to verify that it is not null before accessing methods or properties of the object. To avoid this, the safe navigation operator returns null for the particular null-safe operation instead of throwing an exception.spring-doc.cn
When the safe navigation operator evaluates to null for a particular null-safe operation within a compound expression, the remainder of the compound expression will still be evaluated.spring-doc.cn
Safe Property and Method Access
The following example shows how to use the safe navigation operator for property access (?.).spring-doc.cn
ExpressionParser parser = new SpelExpressionParser();
EvaluationContext context = SimpleEvaluationContext.forReadOnlyDataBinding().build();
Inventor tesla = new Inventor("Nikola Tesla", "Serbian");
tesla.setPlaceOfBirth(new PlaceOfBirth("Smiljan"));
// evaluates to "Smiljan"
String city = parser.parseExpression("placeOfBirth?.city") (1)
		.getValue(context, tesla, String.class);
tesla.setPlaceOfBirth(null);
// evaluates to null - does not throw NullPointerException
city = parser.parseExpression("placeOfBirth?.city") (2)
1 Use safe navigation operator on non-null placeOfBirth property
2 Use safe navigation operator on null placeOfBirth property
val parser = SpelExpressionParser()
val context = SimpleEvaluationContext.forReadOnlyDataBinding().build()
val tesla = Inventor("Nikola Tesla", "Serbian")
tesla.setPlaceOfBirth(PlaceOfBirth("Smiljan"))
var city = parser.parseExpression("placeOfBirth?.city") (1)
		.getValue(context, tesla, String::class.java)
The safe navigation operator also applies to method invocations on an object.spring-doc.cn
For example, the expression #calculator?.max(4, 2) evaluates to null if the #calculator variable has not been configured in the context. Otherwise, the max(int, int) method will be invoked on the #calculator.spring-doc.cn
Safe Collection Selection and Projection
The Spring Expression Language supports safe navigation for collection selection and collection projection via the following operators.spring-doc.cn
The following example shows how to use the safe navigation operator for collection selection (?.?).spring-doc.cn
IEEE society = new IEEE();
StandardEvaluationContext context = new StandardEvaluationContext(society);
String expression = "members?.?[nationality == 'Serbian']"; (1)
// evaluates to [Inventor("Nikola Tesla")]
List<Inventor> list = (List<Inventor>) parser.parseExpression(expression)
		.getValue(context);
society.members = null;
// evaluates to null - does not throw a NullPointerException
		.getValue(context);
1 Use null-safe selection operator on potentially null members list
val society = IEEE()
val context = StandardEvaluationContext(society)
val expression = "members?.?[nationality == 'Serbian']" (1)
var list = parser.parseExpression(expression)
		.getValue(context) as List<Inventor>
The following example shows how to use the "null-safe select first" operator for collections (?.^).spring-doc.cn
String expression =
	"members?.^[nationality == 'Serbian' || nationality == 'Idvor']"; (1)
// evaluates to Inventor("Nikola Tesla")
Inventor inventor = parser.parseExpression(expression)
		.getValue(context, Inventor.class);
1 Use "null-safe select first" operator on potentially null members list
val expression =
	"members?.^[nationality == 'Serbian' || nationality == 'Idvor']" (1)
var inventor = parser.parseExpression(expression)
		.getValue(context, Inventor::class.java)
The following example shows how to use the "null-safe select last" operator for collections (?.$).spring-doc.cn
String expression =
	"members?.$[nationality == 'Serbian' || nationality == 'Idvor']"; (1)
// evaluates to Inventor("Pupin")
1 Use "null-safe select last" operator on potentially null members list
val expression =
	"members?.$[nationality == 'Serbian' || nationality == 'Idvor']" (1)
The following example shows how to use the safe navigation operator for collection projection (?.!).spring-doc.cn
// evaluates to ["Smiljan", "Idvor"]
List placesOfBirth = parser.parseExpression("members?.![placeOfBirth.city]") (1)
		.getValue(context, List.class);
placesOfBirth = parser.parseExpression("members?.![placeOfBirth.city]") (2)
1 Use null-safe projection operator on non-null members list
2 Use null-safe projection operator on null members list
var placesOfBirth = parser.parseExpression("members?.![placeOfBirth.city]") (1)
		.getValue(context, List::class.java)
Null-safe Operations in Compound Expressions
As mentioned at the beginning of this section, when the safe navigation operator evaluates to null for a particular null-safe operation within a compound expression, the remainder of the compound expression will still be evaluated. This means that the safe navigation operator must be applied throughout a compound expression in order to avoid any unwanted NullPointerException.spring-doc.cn
Given the expression #person?.address.city, if #person is null the safe navigation operator (?.) ensures that no exception will be thrown when attempting to access the address property of #person. However, since #person?.address evaluates to null, a NullPointerException will be thrown when attempting to access the city property of null. To address that, you can apply null-safe navigation throughout the compound expression as in #person?.address?.city. That expression will safely evaluate to null if either #person or #person?.address evaluates to null.spring-doc.cn
The following example demonstrates how to use the "null-safe select first" operator (?.^) on a collection combined with null-safe property access (?.) within a compound expression. If members is null, the result of the "null-safe select first" operator (members?.^[nationality == 'Serbian']) evaluates to null, and the additional use of the safe navigation operator (?.name) ensures that the entire compound expression evaluates to null instead of throwing an exception.spring-doc.cn
String expression = "members?.^[nationality == 'Serbian']?.name"; (1)
// evaluates to "Nikola Tesla"
String name = parser.parseExpression(expression)
		.getValue(context, String.class);
1 Use "null-safe select first" and null-safe property access operators within compound expression.
val expression = "members?.^[nationality == 'Serbian']?.name" (1)
		.getValue(context, String::class.java)
