This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.0! |
Order of Messages
Messages from the broker are published to the clientOutboundChannel
, from where they are
written to WebSocket sessions. As the channel is backed by a ThreadPoolExecutor
, messages
are processed in different threads, and the resulting sequence received by the client may
not match the exact order of publication.
To enable ordered publishing, set the setPreservePublishOrder
flag as follows:
@EnableWebSocketMessageBroker
public class MyConfig implements WebSocketMessageBrokerConfigurer {
protected void configureMessageBroker(MessageBrokerRegistry registry) {
registry.setPreservePublishOrder(true);
The following example shows the XML configuration equivalent of the preceding example:
xmlns:websocket="http://www.springframework.org/schema/websocket"
xsi:schemaLocation="
https://www.springframework.org/schema/websocket/spring-websocket.xsd">
<websocket:message-broker preserve-publish-order="true">
</websocket:message-broker>
</beans>
When the flag is set, messages within the same client session are published to the
one at a time, so that the order of publication is guaranteed.
Note that this incurs a small performance overhead, so you should enable it only if it is required.
The same also applies to messages from the client, which are sent to the clientInboundChannel
from where they are handled according to their destination prefix. As the channel is backed by
, messages are processed in different threads, and the resulting sequence
of handling may not match the exact order in which they were received.
To enable ordered publishing, set the setPreserveReceiveOrder
flag as follows:
public void registerStompEndpoints(StompEndpointRegistry registry) {
registry.setPreserveReceiveOrder(true);
