Exceptions
@Controller and @ControllerAdvice classes can have @ExceptionHandler methods to handle exceptions from controller methods. The following example includes such a handler method:spring-doc.cn
@Controller
public class SimpleController {
	@ExceptionHandler (1)
	public ResponseEntity<String> handle(IOException ex) {
1 Declaring an @ExceptionHandler.
@Controller
	fun handle(ex: IOException): ResponseEntity<String> {
The exception can match against a top-level exception being propagated (that is, a direct IOException being thrown) or against the immediate cause within a top-level wrapper exception (for example, an IOException wrapped inside an IllegalStateException).spring-doc.cn
For matching exception types, preferably declare the target exception as a method argument, as shown in the preceding example. Alternatively, the annotation declaration can narrow the exception types to match. We generally recommend being as specific as possible in the argument signature and to declare your primary root exception mappings on a @ControllerAdvice prioritized with a corresponding order. See the MVC section for details.spring-doc.cn
An @ExceptionHandler method in WebFlux supports the same method arguments and return values as a @RequestMapping method, with the exception of request body- and @ModelAttribute-related method arguments.
Support for @ExceptionHandler methods in Spring WebFlux is provided by the HandlerAdapter for @RequestMapping methods. See DispatcherHandler for more detail.spring-doc.cn
Method Arguments
@ExceptionHandler methods support the same method arguments as @RequestMapping methods, except the request body might have been consumed already.spring-doc.cn
Return Values
@ExceptionHandler methods support the same return values as @RequestMapping methods.spring-doc.cn
